BU40N (on Mac-USB) did not update
wallace27
Post by wallace27 »
OS device name: /dev/rdisk5
Product: BD-RE BU40N
Revision: 1.02
Serial number:
Bus encryption flags: 1F
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Enclosure is the Archgon MD-8017-U3. Mac System Profiler reports it as the following:
MD-810x:
Product ID: 0x3910
Vendor ID: 0x13fd (Initio Corporation)
Version: 2.17
Serial Number: 30303030303030303030303030303030
Speed: Up to 480 Mb/sec
Manufacturer: Archgon
I followed the instructions for mac, but at the end, the firmware is still reporting the drive is 1.02 even after the command line tool said it successfully updated.
[MakeMKV.app/contents/macos] wallace% ./makemkvcon f -d '/IOBDServices/E3C16F37' -f /Users/wallace/Downloads/sdf.bin rawflash main -i /Users/wallace/Downloads/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Reading input file /Users/wallace/Downloads/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO1LC2B2038
yes
 100% Operation finished
Done successfully
[MakeMKV.app/contents/macos] wallace% ./makemkvcon f -l
Found 2 drives(s)
00: /IODVDServices/737CDE29
  HL-DT-ST_DVDRW__GA32N_KE06_K0DBCF13116
01: /IOBDServices/E3C16F37
wallace27
Re: BU40N (on Mac-USB) did not update
Post by wallace27 »
After reviewing this forum (countless searches), I saw some threads that said to use the encrypted option (enc) instead of "main". I tried the following command, and it seems to have worked. NOTE that this is not what the instructions say to do. So maybe the instructions aren't up to date for macs?
[MakeMKV.app/contents/macos] wallace% ./makemkvcon f -d '/IOBDServices/E3C16F37' -f /Users/wallace/Downloads/sdf.bin rawflash enc -i /Users/wallace/Downloads/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
yes
Done successfully
[MakeMKV.app/contents/macos] wallace% ./makemkvcon f -l        Found 2 drives(s)
  HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MO1LC2B2038
You forgot enc
Your command was:
Adding enc to the command would change it to:
Notice that 'main' was replaced by 'enc'. This allows the flashing program to deal with the encrypted firmware that's on your optical drive.
wallace27
Post by wallace27 »
That's what I eventually figured. The strange things are (in no particular order):
The help info for makemkvcon doesn't explain this.
The drives article doesn't explain this (the flashing for macs section).
MakeMKVcon reported success, even though the flashing actually failed.
wallace27 wrote: Sun Sep 04, 2022 4:48 pm That's what I eventually figured. The strange things are (in no particular order):
Billycar11 updated Ultimate UHD Drives Flashing Guide with an example of the 'enc' version of the command.
neilsudoku
Post by neilsudoku »
Hi there,
I'm having some problems with my BU40N drive. I'm not very good at things like this. I've been reading all the pages on flashing the BU40N drive etc. So I'm not lazy. I just don't understand it. Could any of you read my drive settings/info and tell me if it looks right or not? Would really appreciate it!
I've attached a screenshot of the drive info.
