Any issues ripping directly to a network share?
jmichael99
#1 Post by jmichael99 » Sun Sep 04, 2022 12:21 am
After I'm done with a disk I copy it to a network share on my server for Plex, would I be ok just making that my output directory for makemkv?
Re: Any issues ripping directly to a network share?
#2 Post by Woodstock » Sun Sep 04, 2022 12:40 am
Speed is the only issue I've seen. A 10mb/s network connection is rather slow; 100mb/s becomes adequate. 1000mb/s works faster than local for most work.
exitguy
#3 Post by exitguy » Sun Sep 04, 2022 11:32 am
Yeh, I do that all the time. Set the default save address to where you want it to go and all done.
Using a PC and a Synology NAS all connected via Ethernet - works a treat and goes straight into the directory that Kodi accesses to play from.
