Any issues ripping directly to a network share?
jmichael99
After I'm done with a disk I copy it to a network share on my server for Plex, would I be ok just making that my output directory for makemkv?
Re: Any issues ripping directly to a network share?
Speed is the only issue I've seen. A 10mb/s network connection is rather slow; 100mb/s becomes adequate. 1000mb/s works faster than local for most work.
exitguy
Yeh, I do that all the time. Set the default save address to where you want it to go and all done.jmichael99 wrote: Sun Sep 04, 2022 12:21 am After I'm done with a disk I copy it to a network share on my server for Plex, would I be ok just making that my output directory for makemkv?
Using a PC and a Synology NAS all connected via Ethernet - works a treat and goes straight into the directory that Kodi accesses to play from.
