ASUS BC-12D2HT 3.12
phantom0308
ASUS BC-12D2HT 3.12
#1 Post by phantom0308 » Fri Sep 02, 2022 4:40 pm
I bought a 12D2HT which fw version is 3.12,obviously it can not be flashed by asus odd fw changer or sdftool.
What kind of files should I upload that somebody could slove this ?
OS device name: F:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.12
Serial number: KLQM6K94003
Firmware date: 2120-12-02 10:32
Bus encryption flags: 1E
Re: ASUS BC-12D2HT 3.12
#2 Post by Billycar11 » Fri Sep 02, 2022 5:22 pm
it can be flashed
just use enc and choose asus 3.10
if you want email me for an auto flash kit that will do it all for you for $25
phantom0308
#3 Post by phantom0308 » Sun Jan 15, 2023 2:27 pm
it can be flashed
Thank you for your advise! I have solve the problem by the old version sdftool with check enc in the past. Sorry about forgeting to feedback to you in time since I haven't logged in the forum almost 1 year.
