ASUS BC-12D2HT 3.12
phantom0308
ASUS BC-12D2HT 3.12
Post by phantom0308 »
I bought a 12D2HT which fw version is 3.12,obviously it can not be flashed by asus odd fw changer or sdftool.
What kind of files should I upload that somebody could slove this ?
OS device name: F:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.12
Serial number: KLQM6K94003
Firmware date: 2120-12-02 10:32
Bus encryption flags: 1E
Re: ASUS BC-12D2HT 3.12
it can be flashed
just use enc and choose asus 3.10
if you want email me for an auto flash kit that will do it all for you for $25
phantom0308
Billycar11 wrote: Fri Sep 02, 2022 5:22 pm it can be flashed
Thank you for your advise! I have solve the problem by the old version sdftool with check enc in the past. Sorry about forgeting to feedback to you in time since I haven't logged in the forum almost 1 year.
