realbabilu
Post by realbabilu » Thu Sep 01, 2022 7:24 pm
proximus wrote:
Wed Aug 31, 2022 1:04 am
First of all excuse me for my English, I'm not English speaking at the base :)
I need your help .. I read many many pages on this forum but I remain in misunderstanding:
I'm trying to extract DV data from an MKV file, like this: Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
and reinject them into an MKV file that only contains HDR10 data, like this: SMPTE ST 2086, HDR10 compatible
Can someone give me the step by step I need to do? With what software or scripts, step by step like I was 8 years old lol
I've been trying to do this for months :(
Thanks a lot !
Best way is convert to dvhe 08.06 or hdr10 compatible with rpu. the profile 8.1 is compatible with mkv / mp4 container for hdr10 tv.
It already tested with donaldfaq DDVT tool above. https://forum.doom9.org/showthread.php?t=183479
maybe also can done it reset999 Dovi_script revised one (i will tested later).
First download donalfaq DDVT tools above
drag mkv to the DDVT_DEMUXER.cmd to extract RPU.bin (can be cropped or not, if it DDVT_INJECTOR later said rpu pixel mismatch with video, use cropped by press 5)
export as profile DV8.1 by press 4 if not
press S to Start extraction and convert rpu
 == SETTINGS ==
SAVE HDR BL         : [NO]
SAVE DoVI EL        : [NO]
SAVE RPU            : [YES]
CONVERT RPU         : [PROFILE 8.1 HDR]
CROP RPU            : [YES]
you will have rpu.bin in sub folder [extracted]
copy rpu.bin in sub folder into same folder as mkv file, the folder will be have mkv and rpu.bin for dv8.1
drag mkv to DDVT_INJECTOR.cmd to create 8.1 mkv
make sure it match pixels with rpu
 ==  VIDEO INPUT ==
Video Info = [Resolution = 3836x1600] [Codec = HEVC-10Bit-YUV-4:2:0] [Frames = 145630] [FPS = 23.976]
HDR Info   = [Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible]
Borders    = [LEFT=0 px], [TOP=0 px], [RIGHT=0 px], [BOTTOM=0 px] [MATCH WITH RPU]
 == RPU INPUT ==
Filename   = [RPU.bin]
RPU Info   = [DV Profile = 8] [CM Version = 2.9] [Frames = 145630]
Borders    = [LEFT=0 px], [TOP=0 px], [RIGHT=0 px], [BOTTOM=0 px] [MATCH WITH VIDEO]
match L6 by press 2 for YES. (well i assume it needed)
create MKV directly by muxing all stream and converted 8.1 video by press 4 for YES
press S to start.
If you want to remove DV completely use DDVT_REMOVER
Drag the mkv file to DDVT_REMOVER.cmd and remove Dolby Vision metadata to yes
HDR Info   = [Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible]
Remove Dolby Vision Metadata : [YES]
press S to start.
DonaldFaQ
Post by DonaldFaQ » Fri Sep 02, 2022 10:06 am
1. If the DV7 mkv extracted using DDVT_DEMUXER with crop off by default. i got rpu.bin that different range (rpu has 280x) as video range (0px)
so i got restarted again with DDVT_DEMUXER, crop on right?
2. When i got the rpu.bin it should be same folder as input mkv right, by using DDVT_INJECTOR to get mkv DV8, right?
3. What the best for budget DV TV: DV 8.1 or DV 8 HLG format from DV7 mkv.
*1 if you demux a P7 single layer file, you have 2 options. First, you can save the RPU only and you can crop this RPU if u will. Second, you can save the BL and the EL layer (or only BL, or only EL). If you save both layers you can build a UHD with TS-Muxer for example. If you crop the RPU and extract that binary, the RPU in the EL layer will be untouched.. Only the own extracted RPU will be edited.
*2 Yes right. If the RPU.bin in the same folder as the input file, RPU inject options will triggered. If a EL.hevc in the same folder, P7 mux settings will be triggered. if a custom.json file in the same folder, this script will be processed during the mux process. Attention! All settings from the custom.json script will be processed BEFORE the intern tool scripts processed.
*3 I don't know. I have an LG OLED TV with a Nvidia Shield pro as player and using HDR + P8. FEL Layers obsolete because no media player supports FEL playback. Exception the Oppo Player (or the clone) with files in ISO format. With this combi you can watch P7 FEL. All other players i know playbacks only MEL .
Post by RESET_9999 » Fri Sep 02, 2022 2:48 pm
Hi, I added P7 support in Mode.I (1) in DoVi_Scripts_1.5.4.
You can Re-sync, Crop, Edit L5 (manual or auto).
ArArdin
Post by ArArdin » Fri Sep 02, 2022 3:37 pm
Thanks @RESET_9999 for the continuous work on the scripts.
Not having used them for a while, latest version (1.5.4) seems to reject work/destination folder with spaces in its name (or path). Is this by design?
Post by RESET_9999 » Fri Sep 02, 2022 3:42 pm
Possibly, I never work with output or temp path that contains space or special characters so I never really test that.
I'll check it out. thanks!
EDIT: yes I know why, there are unnecessary " " for the output and temp path.
This will take a while to fix but I will.
ArArdin
Post by ArArdin » Fri Sep 02, 2022 4:16 pm
Thanks for checking. No worries, no hurries.
daddy
Post by daddy » Fri Sep 02, 2022 4:53 pm
Hi all
What will be the process to build a dual track mp4 file (dvhe.07.06 BL and a EL+RPU) from a dvhe 08.06 DV mkv file ?
Post by RESET_9999 » Fri Sep 02, 2022 5:41 pm
Hi all
I could be wrong but I don't think it's possible if you don't have the original EL.
staknhalo
Post by staknhalo » Fri Sep 02, 2022 9:35 pm
Anyone here make DVH1 P5 mp4 on Windows for iOS playback? What are you using for generation with the DVH1 flag? mp4muxer doesn't do it right? Or does it have a flag for it? Not at my desktop ATM with all my stuff so can't easily check.
DVH1 still works on Android/Windows - so for the few P5 I have (because mostly P8 or P7) I'm gonna make them DVH1 (from DVHE) just for 'maximum compatibility).
Post by RESET_9999 » Fri Sep 02, 2022 10:26 pm
mp4muxer --dv-profile 5 --input-file BL.hevc --input-file audio.ec3 --dvh1flag 0 --output-file output.mp4
Post by RESET_9999 » Sat Sep 03, 2022 1:33 am
now that the DV bug with cinema mode configuration is fixed on my C2, I can resume testing the internal player VS my x800m2.
With this new firmware, now L1 High contrast no longer clip(Internal & shield). Internal player looks perfect to me but I think I see a better L1 response on the x800m2 since the C2 update. Still quite different though.
staknhalo
Post by staknhalo » Sat Sep 03, 2022 2:30 am
thank you
sw5163
Post by sw5163 » Sat Sep 03, 2022 7:44 am
thank you
Don't use mp4muxer to change dvhe->dvh1 for iOS device.
Currently some files changed this way will lead to black screen on iOS device.(On mac will be fine)
I'm guessing it's because mp4muxer only change codec ID in hex instead of repackaging it.
Same as https://github.com/rixtox/mp4dovi/issues/9
Use mp4box instead
https://www.avsforum.com/threads/apple- ... t-61936696
yusesope wrote:
Fri Oct 23, 2020 10:45 am
The correct codec ID (for profile 8.1) should be "hvc1" in place of "hev1". But be careful, these boxes are not random: they indicate to the decoder how the information for the initialization of the latter is stored within the file. Changing the header with a hex editor isn't always enough!
yusesope wrote:
Sat Oct 24, 2020 10:30 am
As I said, very often it is not enough to change the header of a box for the file to be played. QuickTime is perhaps smarter and can retrieve the information needed to initialize the decoder. The iPad player may not be capable of it!
Trees
Post by Trees » Sat Sep 03, 2022 8:18 am
Hello everyone.
After years of lurking, and mastering hybriding 4K films and series, I'm looking to hybrid an RPU taken from an already hybrided film (P5 to P8.1) to a 1080p *.264 codec as opposed to a *.x265/HEVC codec.
I've found that a certain films look much much better in 1080p than they do in 2160p (caps-a-holic can confirm this), the upscaling has been done very poorly.
Is what I'm asking possible at all with public tools? I am not able to get content directly from streaming services so I'm relying on public tools to get this job done.
Looking forward to your replies.
TL;DR: I want to inject an Dolby Vision P8. 1 RPU into an 1080p film, how?
kazuma
Post by kazuma » Sat Sep 03, 2022 11:08 am
what was the path for eac3to334? i've the program but forgot this.
