MakeMKV incorrectly displaying disc length of 8 hour disc as only 5 hours
BlueScreenOfTOM
Post by BlueScreenOfTOM » Mon Aug 29, 2022 7:18 pm
Hey folks, big fan of the software, been using it for years.
I have a home-made DVD disc that I'm trying to rip. I have a Toshiba VHS-to-DVD recorder unit that I used to create the DVD disc from VHS source material. I recorded the disc on the super long play (admittedly garbage quality) mode, which produces an 8 hour recording on a single 4.7GB DVD-R disc. So far so good.
When I put the disc in my PC and open it up in VLC, I see the full title length (8:02:08) and it plays just fine all the way to the end. When I scan/rip the disc in MakeMKV, however, it only shows up as 5:01:28. I did the rip and checked the file and, indeed, it is truncated at 5:01:28.
Any suggestions?
Related log after scanning the disc:
MakeMKV v1.17.1 win(x64-release) started
Using LibreDrive mode (v06.3 id=10F16E86E12A)
Cells 153-244 were removed from title end
Title #1 was added (152 cell(s), 5:01:28)
Ezatoka
Re: MakeMKV incorrectly displaying disc length of 8 hour disc as only 5 hours
Post by Ezatoka » Tue Aug 30, 2022 8:48 am
Does the output change, when you change the DVD Opening Mode?
viewtopic.php?f=7&t=28541
How do the available titles look, when you open the DVD manually?
BlueScreenOfTOM
Post by BlueScreenOfTOM » Tue Aug 30, 2022 11:53 pm
CellTrim did the trick, thanks! I still don't fully understand why, but I was able to rip the full 8-hour file this way. Thanks again.
Ezatoka
Post by Ezatoka » Wed Aug 31, 2022 1:05 pm
Glad it worked for you :)
