Offtopic a bit: playing 3d mkv or m2ts or other on oppo 203?
I created the 3d mkv file. It plays on my oppo but in 2d
I tried tsmux to m2ts file ( made sure the 3d-mvc is below the main file)
It sees it as an incompatible file
I then tried Adding the year (2020) 3d-SBS in the name (not sure i understood this...didnt work.
I tried downloading the bd3d2mk3d software on my windows parelles however it kept asking for something called avisynth install first.
Tried 3 different download and none of the versions worked. (Not sure i had the right one)
Anyone who can offer direction or advice appreciated.
Im using an oppo 203 to a lg oled tv.
Re: Offtopic a bit: playing 3d mkv or m2ts or other on oppo 203?
Figured it, for some reason if the first audio track is lossless it wont work.
You have to out a lower audio first before muxing.
If anyone is curious.
The reason is, that your equipment cannot cannot handle this type of HD track. Many "Smart TVs" cannot play DTS or DTS HD tracks.
Good Luck
![Smile :)](./images/smilies/icon_smile.gif)
Thanks !
although confused. I have an oppo running to a pioneer receiver running out to speakers. This cannot play dts hd tracks? Is there a setting or something to correct? The tv speakers arent connected.
Update: i looked into it and it seems to play dts hd ma 5.1. Could it be something else or maybe run the bitstream?
Hi can you give a step guide to get this to work. Thanks.Jman5150 wrote: ↑Mon Jul 20, 2020 2:24 amThanks !
