Spider-Man No Way Home
AzurePanda
Post by AzurePanda »
Had a bunch of errors every time I try to rip this, multiple different versions of this same thing
DEBUG: Code 3221225486 at qfmN#a{sFwgf"zj2mo:213131502
Error 'OS error - The volume for a file has been externally altered such that the opened file is no longer valid' occurred while reading '\Device\CdRom1' at offset '40764045312'
No idea what's going on as I don't have anything going during rips.
Any help would be greatly appreciated
Re: Spider-Man No Way Home
usb drive?
if so try using both cables or get a high powered usb hub
AzurePanda wrote: Tue Aug 30, 2022 7:43 am Had a bunch of errors every time I try to rip this, multiple different versions of this same thing
i look at your other posts you seem to have power errors on bd100 discs its time for a high powered usb hub
https://smile.amazon.com/gp/product/B00 ... VXLJ&psc=1
it used to be $40 idk why its $80 now but that what i use to test 4+ BU40Ns at a time and no problem with bd100's
AzurePanda
Billycar11 wrote: Tue Aug 30, 2022 9:12 am
It's only on very specific disks however. Even as I type this I've ripped 3 other 4k disks and a standard blu-ray. The standard blu-ray of this movie even worked. I don't know why I'm having issues with just particular disks. Also I have been using both cables.
AzurePanda wrote: Tue Aug 30, 2022 10:55 am
Yes a standard bluray is not a bd100 it's BD 25 or 50 a BD100 requires more power to rip
I bet most of those specific discs are bd100s most UHD blurays are bd66 but bd100 is becoming more popular lately
