Hi, I have made the same tests over the internal player of the Panasonic HZ1000 OLED TV, and it has passed correctly every of them (well, to be honest, my eyes couldn't see any change in picture in a pair or them). So that, the TV supports both CMv2.9 and CMv4.0.yossSP wrote: ↑Fri Aug 19, 2022 4:51 pmTests made on Chromecast with Google TV over both TV-LED and Player-LED modes.
I have played the eight "RPU p8.1/4 L1.L2..._cmv29/cmv40" files.
I can't see any change in picture in L2_trim_chroma_weight, L2_ms_weight, nor any L3 and L8 tests.
Please, can you explain to me what this means? It suposses any problem to Dolby Vision FEL/MEL processing on this device?
Thanks in advance RESET_9999.
The Chromecast with GoogleTV passes almost all the L1 and L2 tests, but neither the L3 and L8 ones, so it supports CMv2.9 but not the newer v4.0.
With the CCwGTV the tests are the same regardless the DV mode asigned in the Chromecast settings (Standard or Low Latency). I supossed that in TV-LED mode the CCwGTV passes the raw DV source with the original CM version (4.0 or 2.9) to the TV so the TV could process the CMv4.0 correctly, but it doesn't happen.
