Grantchester
RoyGBiv
Grantchester
#1 Post by RoyGBiv » Sun Aug 28, 2016 2:23 pm
Has anyone successfully copied season 2 disc 1 of Grantchester?
I get an error message about mult titles, then when I try to copy what it lets me, it tells me 3 of four titles have copied, but then the folder is completely empty.
SMK
grabski2011@att.net
Re: Grantchester
#2 Post by grabski2011@att.net » Thu Sep 08, 2016 5:58 pm
I have the same problem only it says it only found 2 episodes. Plus the nine million errors it lists underneath the final message.
Re: Grantchester
#3 Post by Woodstock » Fri Sep 09, 2016 2:22 pm
Without seeing logs, it is very hard to guess at what the issue would be.
I'd suggest both of you follow the procedures outlined in the FAQ in my signature, including mailing the files to support@makemkv.com so that Mike can look at them.
toddInPortland
Re: Grantchester
#4 Post by toddInPortland » Sat Oct 17, 2020 4:45 pm
There's something different about season 2 of Grantchester. Both disk one and disk 2 displayed 2 episodes rather than three. And when ripping, I could not get any episodes out of disk 1, and only 2 out of disk 2. I got the same results on two different drives.
I should note that my dvd player had no problem playing all episodes on both disks.
Here's the drive info:
OS device name: /dev/sr0
Current profile: DVD-ROM
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: M0CJ4C82018
Highest AACS version: 70
Firmware version: 1.02
Here is the log from season 2, disk 1:
MakeMKV v1.15.0 linux(x64-release) started
Debug logging enabled, log will be saved as /home/toddb/MakeMKV_log_1.txt
The new version 1.15.3 is available for download at http://www.makemkv.com/download/
Title #5 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 was added (2 cell(s), 0:03:00)
Title #7 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 was added (1 cell(s), 0:19:00)
Title #16 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #26 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #31 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #36 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 10551311 at g:CB7v*&t~otU*-9:213142496
DEBUG: Code 0 at g:CB7v*&t~otU*-9:121274998
DEBUG: Code 0 at b\#G`/_UvNz^*=ufYo:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Title #41 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #46 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #51 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #56 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #61 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #66 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #71 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #76 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #81 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Region setting of drive HL-DT-ST:DVDRAM GH24NS90 does not match the region of currently inserted disc, trying to work around...
Saving 2 titles into directory /archive1/backup/movies
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '16515072'
Error 'Posix error - Input/output error' occurred while reading '/dev/sr1' at offset '16515072'
DEBUG: Code 1073741829 at &Xj\#n'x>MmaQx+P-2:29394758
DEBUG: Code 100864256 at &Xj\#n'x>MmaQx+P-2:29394758
DEBUG: Code 0 at J.~EqaC$dgn8?u'?WE2j:29395011
DEBUG: Code 0 at /hqzi.In N|R@6oR-ZJ:213129915
DEBUG: Code 0 at J.~EqaC$dgn8?u'?WE2j:29394459
DEBUG: Code 8064 at J.~EqaC$dgn8?u'?WE2j:29393286
DEBUG: Code 0 at >bt0VCvH-awV ^%XinF1X:213136608
DEBUG: Code 0 at sR7Z&b4NZwQDZT3a\0Hb:29394022
DEBUG: Code 0 at sR7Z&b4NZwQDZT3a\0Hb:213140932
DEBUG: Code 0 at sR7Z&b4NZwQDZT3a\0Hb:213141438
DEBUG: Code 0 at sR7Z&b4NZwQDZT3a\0Hb:121271502
DEBUG: Code 0 at [if%&LiqW4<%Ruz,:29395908
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 1 to file /archive1/backup/movies/Grantchester S2 D1_t01.mkv
Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
1 titles saved, 1 failed
Re: Grantchester
#5 Post by Woodstock » Sat Oct 17, 2020 5:37 pm
The information in this topic apply to DVDs as well as Blurays.
There are errors reading the directory structure, as well as reading the VOB files. The most usual cause for this is things like fingerprints or smudges on the disk, but even if the disk looks clean, it can still have a film on it that causes issues with reading. The unreadable area doesn't move around, so it could also be a scratch.
dmitche3
Re: Grantchester
#6 Post by dmitche3 » Thu Aug 25, 2022 9:57 pm
Same issues with season 3. The three discs have three episodes each yet only one full episode shows up when I go to rip a disc. And then the files aren't there or the disc fails to rip with errors. :( I'll just use windows capture (gamebar) to make a close-enough backup.
