Poirot series 6 disk 1
EmmettBrown
Post by EmmettBrown »
Tried both my personal as well as my library's disc... as well as ISOs created from them....
I get the same result... Thanks in advance to you crazy people who know waaaayyy too much about this and will be able to help me... :)
Debug log started at Tue Mar 03 05:25:59 2020 , written by MakeMKV v1.14.7 win(x64-release)
001005:0000 MakeMKV v1.14.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\hflowers/MakeMKV_log.txt
WinCdArb=v1.0.0_tiny win(x64-release)
No SDF v06d: ASUS_DRW-24B1ST___c_1.05_D1D0CL135163
SDF id v06d: ASUS_DRW-24B1ST___c_1.05_D1D0CL135163
SDF v06d: ASUS_BW-12B1ST___a_1.00_211304231147_K9EE5MI3344
No SDF v06d: HL-DT-ST_DVDRAM_GP50NB40_1.02_201509031336_KO4F3K41345
SDF id v06d: HL-DT-ST_DVDRAM_GP50NB40_1.02_201509031336_KO4F3K41345
003028:0000 Title #1 was added (11 cell(s), 1:47:03)
003025:0000 Title #2 has length of 61 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #3 has length of 74 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #4 has length of 115 seconds which is less than minimum title length of 300 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory G:/Video/POIROT_SERIES6_DISC1
001003:0020 DEBUG: Code 4294966822 at %3VSbJFKJLZK[g`ZAr$M:213143209
001003:0020 DEBUG: Code 0 at %3VSbJFKJLZK[g`ZAr$M:29404119
001003:0020 DEBUG: Code 0 at a\;2X|KY0-z5BQ^r{QzKS:213136608
001003:0020 DEBUG: Code 0 at *~hnCI|G[w/I^^d}:29395908
001003:0020 DEBUG: Code 0 at %\#Rf#g+*H<yf9zBe:213132698
001003:0020 DEBUG: Code 0 at %\#Rf#g+*H<yf9zBe:213132146
001003:0020 DEBUG: Code 0 at %\#Rf#g+*H<yf9zBe:29393769
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
004007:0010 AV synchronization issues were found in file 'G:/Video/POIROT_SERIES6_DISC1/title_t00.mkv' (title #1)
004047:0010 AV sync issue in stream 0 at 0:00:00 : video frame timecode differs by -7.907s
005003:0000 Failed to save title 0 to file G:/Video/POIROT_SERIES6_DISC1/title_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Tue Mar 03 05:36:02 2020
WillerZ
Re: Poirot series 6 disk 1
Post by WillerZ »
I have the same problem. I worked around it using these linux command-line commands:
cvlc --play-and-exit file:///Media/TV/Poirot/Series\ 6/Disc\ 1/poirot6-1.iso#1-1 -I dummy --sout file/mp4:/home/willerz/title_t00.m4v --sout-mux-caching=8000
That didn't exit cleanly, I had to Ctrl-C it. That leaves an unfinished mkv file. I then used:
ffmpeg -i title_t00.mkv -c copy -map 0 /Media/TV/Poirot/Series\ 6/Disc\ 1/title_t00.mkv
Which results in a readable mkv file. Compared to what I get from makemkv the only thing missing is the subtitles track, which I can currently live without.
kyrra
Post by kyrra »
I'm hitting this same issue.
As a Windows user, I don't have cvlc (and the Debian WSL was not working easily for me). Any recommendations on how to get the MKV file from this disk?
I was able to rip the disk to an ISO using imgburn, but I was having problems still trying to get an MKV out of it. Below is the output from MakeMKV when trying to rip title 1 from the ISO.
Debug log started at Sun Aug 21 18:43:05 2022 , written by MakeMKV v1.17.1 win(x64-release)
001005:0000 MakeMKV v1.17.1 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\kyrra/MakeMKV_log.txt
DEBUG: Code 3 at W3_5mn~z2cnbOYW#o~Zq,@E{:29395310
SDF  v08d: HL-DT-ST_BD-RE_BP60NB10_1.02_212005070935_SIM03M4PB2449
003342:0204 It appears that you are opening the disc processed by DvdFab/MacTheRipper which is known to produce damaged VOB files. Errors may follow - please use original disc instead.
DEBUG: Code 0 at ~Oj8uSNce UgECuT):121262164
DEBUG: Code 2 at +5ZIKvxeTqz?.{MeG:121263199
DEBUG: Code 3 at +5ZIKvxeTqz?.{MeG:121263199
DEBUG: Code 4 at +5ZIKvxeTqz?.{MeG:121263199
Launching C:\Program Files (x86)\MakeMKV\mmgplsrv64.exe
003028:0000 Title #1 was added (12 cell(s), 1:47:04)
003025:0000 Title #2 has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4 has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory file://D:/plex/POIROT_SERIES6_DISC1
004004:0000 The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 27424768-27652096, attempting to work around
001003:0020 DEBUG: Code 4294966822 at zF[onU|G@0{~z,1>^k|G:213143669
001003:0020 DEBUG: Code 0 at zF[onU|G@0{~z,1>^k|G:213140702
001003:0020 DEBUG: Code 0 at fRe7Tf.X>q:*CJ*_~hmr?:213137068
001003:0020 DEBUG: Code 0 at K+^!y(H;K$sp\yJ3:213132537
001003:0020 DEBUG: Code 0 at PbM)RS_G$5$e7+O[D:121264464
001003:0020 DEBUG: Code 0 at PbM)RS_G$5$e7+O[D:121263912
001003:0020 DEBUG: Code 0 at PbM)RS_G$5$e7+O[D:213130145
---- Failed D:/plex/POIROT_SERIES6_DISC1/B1_t00.mkv
ch_0           4396392000 0
ch_1           4936932000 0
ch_2           5477472000 0
ch_3           6018012000 0
ch_4           6558552000 0
ch_5           7099092000 0
ch_6           7639632000 0
ch_7           8108100000 0
mt=000001F63095ACE0 n=3
s=0 n=1 o=237971456
    0  24252 000011     8108100000       36036000 D30B654F 000001B32D01E02417ED2382101010101010101010101010101010101010101010101010101010101212121010101010101010101212121412121212121414141414181818181C1C1E22222B08080808080808080808080808080808080808080808080808080808080808080808080808080808080808080808080808080808
s=1 n=1 o=4853760
    1    768 000001     8121600000       34560000 80334F50 0B775424144043FFF306F362DD07070604A0A0A0C11F56443E754A93E854DE5C553613F7C96158715EBBE73712C374FD2BE86F9FA57CFD955BA5D155680E954286F613ED86FABD7EFD4AEB0AD22B5CF6BBF535DF3EA4FA6556F374F550657755A1528E86D35DA466D448FEBBE7AFB7BD8DC14BF7CF9F3EB2DE8B468D201D706C
s=2 n=1 o=36749312
    2   1224 000011     8828820000     8638464000 D55B8F20 04C804A900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
mt=000001F63093D540 n=3
s=0 n=1 o=237971456
    0  13132 000018     8036028000       36036000 150806F1 00000100001FFFFBB8000000000001B583344B1C0000000000000101125602028AC0000000000102125602028AC0000000000103125602028AC0000000000104125602028AC0000000000105125602028AC000000000010612560FCF13C2B80BC007B28E0165DDE9FC0D7DC545168F20B409DE9388D251F0BA70B70D908B2190
s=1 n=20 o=4853760
    1    768 002001     8156160000       34560000 6B4FD1F0 0B772EED144043FFF306F362DD07060504A0A0E0E11F5643C77D49F3F5499CC37D0953E7CF6BD34B5D3264B616EAAEF9F3E8EA9F3E7E9569C37DC86AA4EAD0AA7F46221A53703EA6B9246E94D2BF5E85F538549F3E5EA65A70DF72E95A0124B49F528835320D8EA0D7530AE3DA69954DD899DA5730AA25B2DE8C48912016DA78
    1    768 002001     8190720000       34560000 98D273B4 0B771DF7144043FFF306F362DD08080703A08080A13F5644A4D56DFA64CF9F91530DF3E54F9D2B4CA2DD77371EC2A6FAA0CD521CBE7EA59616755E143CCF9FBE74FDF3AA6738A57EF9EAEBA8672A7D069C4175D5BA4CFA65859D58EB5D73E7CFD0D286961A0E0F6BBE7AFEBD348FDF424CF600CAEF75D3B2DE874E9D200B50E7
    1    768 002001     8225280000       34560000 C5FEE5E5 0B7735D0144043FFF306F362DD07080905A0A080611F5DC1F449C2AE02EFA6EF8635EDCA6E69AE854DCC3731133A74F9D3F7CB9D2A850995C8376694E8736AC47481FEB44E636B54E9FD586F9EBF76EA00BB04D4BDB0BA75DF16C1C0F9D6EAFE5BCEB972E4009C8111B6172A424A7881517113F9E3BF340070DA4E88F3B00BDC
    1    768 002001     8259840000       34560000 F1184F2C 0B77E968144043FFF306F362DD07080703A0A080A13F55C47567C2BB958F9F574AF9F4354F6B3EAF4A13F4B7E9A674FD33DAD9DEC37E9595C369621D5BA826C0AE6ABFA47A7BB9534E942859D4544EED13860F63CCB14A6570DA58F6E95A09C9DF1B9FC4E9CBB492AAA55A1D0D6B95BE76A2CA17EDEE52B2DE804081201D9566
    1    768 002001     8294400000       34560000 FDAAC2A0 0B771CDD144043FFF306F362DD07080601A0A0A0C15F5610D774A9FA97EB9C5BAEF69577CF92C052AA1BF19AE756A6F9F4374A953E86959FBF67C2E5188E9CACA66AC5C6B5DF6B54A9D528882AC827469C25EA2DE688F667EFDA57F8E2E3D9B15EB3B1612678746BBE7EA36A47B1112B4B49FA5854ADBEB2DE844891201ABCF5
    1    768 002001     8328960000       34560000 D52E22BF 0B77B45B144043FFF306F362DD08090603A08060C13F5611424D5A9A986B9D3A535DED77D061AB1B0A1AA6B5E1A67D3CB29D55DFA6716D9F586FC6C3890ECFDDAC7F670734E1C186E9F5755575BE7EFA0257CA9F3DB74E67D61C5BF8DF8BD74B149CA771256E0E94EB750ABBA7AF9FBF54FD2437C9620DB2DE89428520089AA7
    1    768 002001     8363520000       34560000 8CCA9C84 0B77F520144043FFF306F362DD08080504A08080E11F5610759CF9F3EACED2BE7CFC98D4C8553DAEF9FA674F9FA9874DEBE7EE6B577D09A16C6FD643E55073AB861DFF1395AEA97CFA9BDB2460C376A61BA54F6BD35506685B1BF6ECF6BBA490291C7DC5066BAE5F3A7D479D3A35D5527E99CD2A706C25B2DE8C4891200761FA
    1    768 002001     8398080000       34560000 7E2C7635 0B777B64144043FFF306F362DD09080704A06080C11F5646BE7B4DD3E7CF9F2DB0E5ED754A6B5786994BF435B7C2CEF9F52AEAC8AA7CF9A1C367D6235B70AAC0AED1D707D36E525E9383E7EF5F437D0A1BE5E95FBF4AEA6870DA5CF6939D29B1531F7F61D20E0F9FA0D74ABBDAD4DD3F4B4A1BA4B5ABBDB2DE8A44892013895D
    1    768 002001     8432640000       34560000 7235ABC5 0B77E5CA144043FFF306F362DD08080703A0A080A13F5681BE7D495B584FD4D2550952DA796BAB4AFA9427D612C2AF0A13EA55DF4E86959FC369773537D5AD40A4A5CF172EAC3E4C96DC2AD0E0DC4E85F56803552EA6A667F0DA61F3076A66A4DF349D5EDA4E8F9F2A8885F3E7C9A9A57EF9CC3735DF3FB2DE8A4489201CD75E
    1    768 002001     8467200000       34560000 5EBCAF38 0B77126F144043FFF306F362DD09080702A06080A15F5645EC536AC395519F2E7C9953E74F6B5754F9FA673ADF4374FDCD8191DF3E8D49A1DB4B1F5D35D0DF2754950F54B4E22554A9FBE54E9F434CF9F3F4C9A1527D5F6875DCC3F50782A7AB1D9B75BDF53550A1269EEA6C3554DABF84A35D77CF953DF2DE8C4891200B48E7
    1    768 002001     8501760000       34560000 0C4A9263 0B777E34144043FFF306F362DD09090702A06060C13F5683BE4D0D2BE74960257D3953DA6F9CC37EE5FAA43B1F12836DF4752FF53E7D49A374735EDC28F4DCAAB0829C474D38AA534D5A9AB7339674FCABE5CFDF3E869B6876DCECE2F9FA98311F354F5E8CDE2D5F90D8992C354E9352A4F9AD94299CD3F2DE8A44892008B2C0
    1    768 002001     8536320000       34560000 682E2CB5 0B77EF8C144043FFF306F362DD0A0B0703A02000A13F5A442A7CE6BBF6AA9D56539E35354A92D77D4DF25754E1437B5ADE67D6130D7D4D6E44199F7D3534ABAA44E74F176E356F5E9AB2A574A13F250D0D3A4F61B02B0E6889BCEACE592D25EF9F2AAEC0657565BCB79F122448063D223747CE147AB0145EDE2C497059780F4F
    1    768 002001     8570880000       34560000 1B718962 0B77D992144043FFF306F362DD090A0704A06040A11F7E45C4735A1537B0A190855AC265506B437D0D2BF6B6E1A9A70A35B4C99D2A7CF99FF07F153277D68B4CFFD53805204E8256CB79E91224905CCFDF28210879205FF73F97C9EE3CF8AA3A60A89ADCC0C430C97F385616468BC5E6AF1939F5E35391A9ADF79B71E354D6DE
    1    768 002001     8605440000       34560000 46C5A6BD 0B77FD0E144043FFF306F362DD090A0702A06040A15F561592535A143A4A6A0D4CE61A5AD4DF2A7C9A1BA734DF527EFA13F54F6BBE54ED6E163B5ED4444D39C41B4E0C34D3ADAF4CE6FAA4EEA12A7DD1FA59EF6B577BC16865913FE8C0933DEC04C1DCC04D1BF0DD51B8A90D2B69DAD87E552D344A9B2B72DE7ECD9B20049A30
    1    768 002001     8640000000       34560000 00B8B40A 0B774191144043FFF306F362DD090A0603A06040E13F5645D77D0DF3E730ABBE554933E5499729B74B3A57D0DF574D09FA97EF9F3E7D499F2F44FB7AF4ED35C71CE9F6B4BAEAF04D9E13F430AB43556DF581ABC45B7EEA67CBD0D8F170B9CAD0C725A6AC9A08659352AB810D3535D36C430A8EF4B5DF40B2DE844891200EB77F
    1    768 002001     8674560000       34560000 EFBAA94A 0B770E16144043FFF306F362DD08090803A08040A13F5614C2B095D527EE9FA17CF9D3E750A0C3755D2C3436E13F4B5DF574CE9F3E7D0DA14724FF5481C835C74ED68D7588363E54EDF567D0B3BE56AD33CB8990C77CFE6837093FF1748B9DD70920AD0A22283BD608AD5A1BF2AF9FBEA5595424CFA7AAB2DE8040812015CDBE
    1    768 002001     8709120000       34560000 61D564AC 0B776D3A144043FFF306F362DD09080905A0608060FF56456C7B5D53F4B0D53F42F932A7B0E6DB84FA13F735DF527EF9D3F534AB5B7D499EF11CE77B01CE6AC544E355C4D061C7734B8267CBA9AA4F0D4C34B5A9BDD6FA67BD473DF55DDB8B6AC6CEA3106BDDF6D3B88EFDCD84ABC73F9CA5FD24AFD2D3B2DE80C1832016D357
    1    768 002001     8743680000       34560000 0616A0C5 0B7714E0144043FFF306F362DD08080705A0A080A0FF5612BEAD5A1BEAD0C8D6CD4DED77CA952E84FDDA16B6E1AA7E92BD286F61BA7D4DA12F44FB7494CD2DB0134774443478AA4D4A33EA56D52B4BC1FA95371339A5BE684BD152F4C1333E7106D683110BDC2A9B3CB839AC2AE9A76F85ADAD6855DD42B2DE8448912002CA05
    1    768 002001     8778240000       34560000 7E60F220 0B779D95144043FFF306F362DD07080704A0A080A11F56063F5D0DD224CAD2BEA549FBA7D46D43569933A735E942AEEA13EA4FAA257E85DF166D4AD48AD3A1403B363C3439ADBF7EF3022730CB167DC1FAD7B71329A5AE75459152F51EC1FE6BC6D1BF003D7B6ADD38B846755E73DD477D4D0AB72F9F68B2DE7ECD9B200FE60C
    1    768 002001     8812800000       34560000 99AE6538 0B779692144043FFF306F362DD07080602A0A080C15F6A0E3AA8461BE54F9D2A4CF6C3A7CF9EC3A4F9F3E7D11339855D54356888BAAE960E448709D3F83AEBBEDEFDD40A2FDF96A0EABF6A5F2A5EA69A68696B447CAA191B2DE7A44892015542DDBF1B600564D30F08802FCF6DC9E5BE1BBE10CA3EF0E1AC77898222E81FA2BC
s=2 n=0 o=36749312
mt=000001F63099CF20 n=3
s=0 n=1 o=237971456
    0  14920 000018     8072064000       36036000 16C46FD8 00000100005FFFFBB8000000000001B584443B1C0000000000000101125602028AC0000000000102125602028AC0000000000103125602028AC0000000000104125602028AC0000000000105125602028AC000000000010612560EE626387EF145A3FC003F54A9BDE5A251325A0E37790901E702DC0ECAF2731AE06AF1F9A898
s=1 n=1 o=4853760
    1    768 002001     8847360000       34560000 5D109D96 0B77746C144043FFF306F362DD07090702A0A060A13F6A0DD3B045ED7853A73F734D342B699ED85495F4369D54D77B49FBF5509F532B39D0A68AD5F3F7CB61EB7E99544D8861A65D0A6F885F2EA49953F5B0A9BFB8861AA72DE75CB97201AA6AA1E8034BF30AAF21ABF0D44F5E2E9B48F810EFAB467FB5E1343F4200B1059138
s=2 n=0 o=36749312
004007:0010 AV synchronization issues were found in file 'file://D:/plex/POIROT_SERIES6_DISC1/B1_t00.mkv' (title #1)
005003:0000 Failed to save title 0 to file D:/plex/POIROT_SERIES6_DISC1/B1_t00.mkv
Application exited at Sun Aug 21 18:43:56 2022
kyrra
Post by kyrra »
It looks like Series 11 disk 1 has a similar issue?
Debug log started at Tue Aug 23 19:39:54 2022 , written by MakeMKV v1.17.1 win(x64-release)
DEBUG: Code 0 at +5ZIKvxeTqz?.{MeG:121263199
DEBUG: Code 5 at +5ZIKvxeTqz?.{MeG:121263199
DEBUG: Code 6 at +5ZIKvxeTqz?.{MeG:121263199
003025:0000 Title #1 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2 has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4 has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #5 was added (11 cell(s), 1:37:22)
003028:0000 Title #6 was added (11 cell(s), 1:37:22)
003028:0000 Title #7 was added (11 cell(s), 1:37:22)
003028:0000 Title #8 was added (11 cell(s), 1:37:07)
003028:0000 Title #9 was added (11 cell(s), 1:37:07)
003028:0000 Title #10 was added (11 cell(s), 1:37:07)
003027:0000 Title #06 in VTS 5 is equal to title #05 and was skipped
003027:0000 Title #07 in VTS 5 is equal to title #05 and was skipped
003027:0000 Title #09 in VTS 6 is equal to title #08 and was skipped
003027:0000 Title #10 in VTS 6 is equal to title #08 and was skipped
001003:0020 DEBUG: Code 0 at Z0yWfr+sM4){1wKs$ln:121264119
vobs=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
vobs=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
005014:0000 Saving 2 titles into directory file://D:/plex/POIROT_SERIES_11_DISC1
005001:0308 File D:/plex/POIROT_SERIES_11_DISC1/B1_t00.mkv already exist. Do you want to overwrite it?
005001:0308 File D:/plex/POIROT_SERIES_11_DISC1/B1_t01.mkv already exist. Do you want to overwrite it?
001003:0020 DEBUG: Code 15616 at 8XRpIX1y7o2iOHx!,MUy:29393930
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 1747638272-1747646464, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 1747652608, attempting to work around
001003:0020 DEBUG: Code 12288 at 8XRpIX1y7o2iOHx!,MUy:29393930
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 1747658752, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 1747664896, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 1891719168-1891749888, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 1939527680-1939535872, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 1939542016-1939548160, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 1944410112-1944440832, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 1944492032, attempting to work around
004007:0010 AV synchronization issues were found in file 'file://D:/plex/POIROT_SERIES_11_DISC1/B1_t00.mkv' (title #1)
004008:0010 AV sync issue in stream 1 at 1:32:11.488 with duration of 192ms : audio gap - 6 missing frame(s)
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2004211712-2004219904, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2004224000, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2004228096-2004230144, attempting to work around
001003:0020 DEBUG: Code 207 at *j~unZzdc3nz;HmxMxLveu:213129915
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2004234240, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2004238336, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2004238336-2004240384, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2004240384, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2004240384-2004242432, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2004242432, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2004242432-2004244480, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2004244480, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2004244480-2004246528, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2004246528, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2014631936-2014642176, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2040911872-2040920064, attempting to work around
vobs=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
001003:0020 DEBUG: Code 0 at Z0yWfr+sM4){1wKs$ln:121263015
001003:0020 DEBUG: Code 0 at ^Qjq;+-!?d/:>aLz.mj):213131157
001003:0020 DEBUG: Code 0 at ^Qjq;+-!?d/:>aLz.mj):213131272
001003:0020 DEBUG: Code 996546 at ^Qjq;+-!?d/:>aLz.mj):121261773
001003:0020 DEBUG: Code 0 at %Fgk##=EujkCx,];LyE:121264234
---- Failed D:/plex/POIROT_SERIES_11_DISC1/B1_t00.mkv
ch_0        6244408170000 0
ch_1        6244948710000 0
ch_2        6245489250000 0
ch_3        6246029790000 0
ch_4        6246570330000 0
ch_5        6247110870000 0
ch_6        6247651410000 0
ch_7        6248191950000 0
mt=0000024424ED1550 n=3
s=0 n=1 o=2034794496
    0  42465 000013  6248191950000       54054000 3D39AE06 000001B32D01E034124FA380000001B5148200010000000001B8064A67C000000100008FFFF8000001B58FFFF71F80000001011B7E2AD0F6B1F1207800D18E87AB4D8406CE236E71ADABEF335AC12E76B4B84F31B6457AB541AD35B6717C07B5D733BC64B84066B84146981CC16DB724E5B67B75D57EDD331B9B5DE6CD8E4D0E
s=1 n=2 o=2034884608
    1    768 000001  6248171526000       34560000 5EB0431D 0B77D1881440437FB307F6F362DD0C0B0906A3A3E040DF564626A845F534ED48C34C99EC374A9DA574FA0EB7EE5F3E7CA9F3E86866F1EB099FBF7349FC385248E77D11CD5B15DCBAB0592D774E9D427B0EB6B74B5F53549A64EFB5A5B94DFA71911D4353B1F3DB2928D8735AC3E9B5DF47A4A9D3E4BADF3AB2FE99428520071D
    1    768 000003  6248206086000       34560000 C30A2E04 0B7764CB1440437FB307F6F362DD0C0B0A07A3C00040BF56463DAF5A1BF4AFA157730D525854DF3DAEFA1267539D3E7B5D53E74BA158EAAD9F5C6CF69AF86FD556AF1138C874A952AEF9F56D885CDB8371F267CF92E77C96626AE93DEAFA13E86ADDAA850B7A68559F4372FAC4342FA14354F9F3F1C9693AB2FE974E9D201437
s=2 n=0 o=2040926208
mt=0000024424ED11F0 n=3
    0  10843 004018  6248101860000       54054000 0FDF0864 00000100001FFFFBB8000001B58112379F800000010142E710EA1F5C44105C01C568641D38D5AA33631EE06AFFFADFA70FAE25BBFF6B9CEAD19164131708A1353708EA3A8493B3F323232E8494A1B2803EAA124BEDE32328494FF37E2042A14408550A26C8F67D0929468671B67350921F05074001803C803882AB6F4655CA0B
s=1 n=38 o=2034884608
    1    768 006001  6248240646000       34560000 FA04F4C2 0B77BB651440437FB307F6F362DD0D0B0808A2E00080BF5646A57D5D3567D49F3EA4FA142A50DF3A54F9ED37D469A67CF953E74FD4D8BAFD9F5D4159FB1244A153A6AA13F8549F3EAEA9FBAACE7756E0A9F3D86F5FBA7CAA5814E939EAFA13A7D7512A7EF756BAE99CBF749623E73AEBBE56A695254A9FA5B2FE9840812006F7
    1    768 006001  6248275206000       34560000 33ED1E06 0B7728B51440437FB307F6F362DD0D0B0707A34020A0BF56463E86A9F2AA54B33E86F69A9AD4DF3E54F9D39855A1BE7CF9F4E53612BFF3719F5C6B49FAF870E23586FA14386A9ED2B281EDB87396D6D8A973E7CA93A5530264F0E925F4A5ED786FDF577D0B5CDD8E5D52D4FD559110DEC37CFA9427CF9F3BB2FE994285200A18
    1    768 006001  6248309766000       34560000 D46CFE74 0B77DF2F1440437FB307F6F362DD0C0B0907A3602060BF56463E7D5DED7755D2C34C994C27CFD53E5CE69C1AEB9F2A4B0ABA5A7061C5C0AD9F591959FC454AD84E4B0ABDAAF4A1B9B095F544AF6B5B7D0AC2174A932A7B5E676FDF29ECA5F52870073E54FABB9E1361437CA95C3495EA257D49F427BC1D25B2FE974E9D201881
    1    768 006001  6248344326000       34560000 300A8E21 0B77702F1440437FB307F6F362DD0C0C0906A383A060DF56463E7EA9D527B5DF3EA55A13F7AFD4D34CF954DB221DA4AEE9F3E4CF75D9E0AD9F587CA5FC37D623BE8501752CD0DCD37E99B25B095F3E7D0DF2A9C993524C9A64EBDFB8EB0973EA6ADDAA850A3BDC29492654A9FD349AEDBB7AFD32574F9F4EB2FE9A4489200570
    1    768 006001  6248378886000       34560000 3AE565F3 0B779CD11440437FB307F7F362DD0A070805A020A060FF56503EA696BBF496D5527E9613EAE95FB9AE96BAA7B5EABF4CE94EB7CF9F5CECF99F587349FC3889A1BA7D1132F24EC8BAA4F9FAA7E8673E7D0D53A72AD2D68EA671D5E94DE160925B6FDD437D510BDAF9D2D27E95FD34BBA3DC2349EAF54F6C3AB2FE8E4C99200B15
    1    768 006001  6248413446000       34560000 93334EC4 0B7713481440437FB307F7F362DD04080708A10060A0BF56133ECEA616C72F9F428699CC2854ABBE7CF9DA156429BE7CF9F4F4B06161EB0D9FBEAD59FBF885A1BEA6A9FB988E9ED3A4F952B4D377D27D0DED3744933D56F664D75ED1D95DF52AEADD42870DF3E86E5F477AFA1C2ADAE156CDAE9167CF75C2B2DE8CC993201BDC
    1    768 006001  6248448006000       34560000 6513110B 0B77E8731440437FB307F7F362DD0C0C0907A383C040BF56463EA6A92D77CF9F3E7CFA156AEF9D3E74F9F2A7CE9F3D86FA93DB6FD2C4E96197C374F5FC05696C3AA50E9468F5A9577E95D537E969528521325A4961AA7CEB67761D34E2BA13ECEFDDAA7EF9F3DB0F95297E99DBDCF497BE7CFA129AEE6BABB2DE904081201FAB
    1    768 006001  6248482566000       34560000 1FC01DE0 0B775AF91440437FB307F7F362DD0C0A0A08A3A020409F56503E7EF9D3EA55AB3EA4FD4D286E5FBA7B5A942D6AA13E4CF9ED3730ABC4EC999FBEAD695C056978527D0D742BF0DF26A4F9D3F56A694352AE13A54F69C254A772371F3CE50D2BED71E9BA7EFA151B291F52AEF935AA6F6FDB83B14C27CF9F3EB2DE8DCB97200BD2
    1    768 006001  6248517126000       34560000 E48AA11D 0B775D021440437FC307F7F362DD0C0A0A07A3602040DF56463E7EF94D84C99D264AF763D850DCC354F9F2A4CEDCD27D09F3E7E95DC3E30D9FBECEE5FC0550B7D77D0DF5754FDAD2AEAD0C34BADF3EAD5D7A5AB4AA2554FA656FDD4DD910AD2A6FDDBF4B4DF427D49F4286E61D774FA025A54D2C34CD553FB2DE8D4A95200016
    1    768 006001  6248551686000       34560000 1AC3513D 0B7756491440437FC307F7F362DD0D0B0907A3400060BF56463F534AB577CED38CAD5A13F730DF267CE9D3E730ABB97EF755686A9FC0915D95A79CA934056AA95385208C474F953AA4FD2C37CFAAD7AEA76257AFD3427C9A656FE951E9812C2AF0D5AE56FD339A559FA586A69D79D0AB437CF9F3A7CFDEBFB2DE904081201AAE
    1    768 006001  6248586246000       34560000 12B50307 0B7738AA1440437FC307F7F362DD0D0B0A06A3400040DF56463E7EFC6BE5CFDCC34AFD33DB03903F7E42B3F7D09F267CAC8BB4AFA15DB0FD93BEAD59FC07EEA9BA7D0DFA9AF5A9C27D59542AF49ED6B6FAC117C9933F4C867255EB3DE309F3ED562024AF0E151E281FCE7CF9FBE850ABC27CFD2BE4D4D2BEB2DE9040812009CA
    1    768 006001  6248620806000       34560000 E3E0796A 0B7719011440437FC307F7F362DD0D0C0906A303C060FF56463EA56D4D7ACFA1A5A69933DACFA9A673AA1BA54E9ED77CFA739AD5ABC4C2FD9D589E91FD453B1F42AF5E210E0AD0BA550DCD6B8A5F3E855DF276C81FD2549E656FDF8CE171ED27F1073A86BAD3DD8F5FA654FA1D76B578434AED2BE7549FA5B2DE904081200486
    1    768 006001  6248655366000       34560000 E44D0EDA 0B7723A41440437FC307F7F362DD0C0C0907A3838060BF56463EA6AC6BEA6E92BAA4ADD29855A1437C96157754DD257CEC8B9B709F48EB09D13EADAD35386FDFBE4F4D73E7CFDD27530D2DAB6FA9B986A9D3AAC9933E7CFA655754BDE2B9FA64D0DFD34BBEB3DAF49FAA7CFA1C50F4ABBDB0E5FA54CFA12AB2DE9040812010ED
    1    768 006001  6248689926000       34560000 7D22FA50 0B779EED1440437FC307F8F362DD0D0B0A06A3200040DF56503DDF0DCD84AFA95284FDCD74AFD2D34C9953A7B5DD2A7E85F3E74B9F48EB099D444B59F54870DF56CEFE1AA854B5537E95FD27CA9F3E869A1A24AA69BE7B0E65D61F39E16DF5754FD3444BAE951D9461537D0D342A50A1BF52A9F3E76E5ED8B2DE90408120073E
    1    768 006001  6248724486000       34560000 EEAF44DB 0B77CF061440437FC307F8F362DD0D0B0A07A3000040BF56463E86A92D8430A13E7EA6B52A55D32654AAAD354E9ED84AF9F427CA9EDEC0FDD0C473B9FA2910DF5852FE1487AFB367850D351AEF9F5354AD4BF4AF6BCDAEFA7231EBBDBAAD4BF4CFD3BA7D616BDD895F577E955C36B5A1E67CF9F2A7CFDCBEB2DE904081200CBD
    1    768 006001  6248759046000       34560000 1B83C4CF 0B775F051440437FC307F8F362DD0C0A0907A3602060BF56463EAEA94D7A4BAB3F7B09FB9AEF615374994D77509CD77539F2A54FA8CAB8FD9D57D5B9FAAABC75D77D1DFAB435A9A6550D0D2870A13EAD0D7A59C9933E7B1265562951D95DF40230D3BB4975339AEF9F3E7EE894374A9FA58696957444613FB2DE904081201838
    1    768 006001  6248793606000       34560000 377B8288 0B770F201440437FC307F8F362DD0A080907A0408060DF564642A50A9AA7D09F4286993258CF9F56AEF9F29AEA9F4D8845529AEE69B0EB5D9F537EF9D537989F5790461BCC2A9F29B095FBD86EA142A55DEAEB559F53735E656AF3B8BAFD2C422FD3A65501D25A6E6BD27EF9DA9A4FABC27AFDF2DB5ADF3EB2DE9040812005BF
    1    768 006001  6248828166000       34560000 B2612F49 0B7797131440437FC307F8F362DD0C0B0907A3A00060BF56153E850D4D77D09F3E8696B574E95F25B54DF274AF9F3E7CF9ED28EFD2D8EAFDC6D87D46A27478D4D6876DF4288F63BA84FA1A5B0969401A99F8D74F92DC72FA72D0F5B8D9AE1577CFD3577D1ADBE86969577CFD33EAB5EBBA7CA9EDB4E992BEF2DE8D4A95200EDF
    1    768 006001  6248862726000       34560000 39E7C8F4 0B7734421440437FC307F8F362DD0C0A0807A3C02080BF5650A9A6A9EEC4AFA13E7CFAB4354E9D527B4DED37B5DED754F6BBDAEFA1C4B90D9FBF75469BB7B86C21AEA9343553A75324BA952AF19F3EA55DDA4B092C255B0A67F01D3CD95E15853027427CFDF3E86F61A74B4ABD34B4ABBE80321434B4DF2AB2DE9040812017C1
    1    768 006001  6248897286000       34560000 6703E836 0B77E55A1440437FC307F8F362DD0C080806A3C08080DD5646A9AEF9D3F7C969B9A6A934F495E129ACFD5297DBDF5274AA929DEA6A40B94D9F5943595407189FA57EAC8C34B4D73E7D5E9C1B6FABA9855E1534C455B97CAB656FB638D9614D454A9F47250A025AD4D3267CFA02A4B0B5AF72F9D527DA9FA6B2DE91428520025A
    1    768 006001  6248931846000       34560000 22C3C7F2 0B77B3201440437FC307F8F362DD0B0A0806A0204080DD5646A674FD2D74B5ABA5A54A956AEA9ED77B5A1AE7CE952E4CF9F3E7D49D5D8F5DD2C47BAA9C47D114D37CFD5BA55075D34B1E952AF09FA5AD108BE74F953F4AA77250E1A57F6AFC37D64654530ABBB730D2C2B709FC27D4AC2584A9CDB7D5A13EB2DE904081200FFA
    1    768 006001  6248966406000       34560000 2B2A618E 0B7784B81440437FC307F9F362DD0C090806A3A04080DD5650A9D6ADCD77CE9EC28CFDCC2A835D3E7CED256A55E93E7D09D29AEF9F5CF495A16075493447D11ED7883552E86FAB56A561CDB7CFD33A4CA9F667E990C34AFB67F61F8C8159FBA85613434B0D53F7B49F3EAEF9FD36B5ABAAA6969427CFD527B2DE904081201910
    1    768 006001  6249000966000       34560000 9E2D1084 0B7740D21440437FC307F9F362DD0D090807A3406080DD564856DEFD2BE854AB3F734D4D6AEF9FA17B5DF29AEF5FC1AEFD0BE7CF9548EABD9FABA4F69D87B72E267D0A1AA54FE8BE855E02554F9F2EAEF9D42869913A4AEB67771F39A751CD37EA9FBE7D5D53E7D4AB438041FD7434D5A97CFA93F4CE9327F2DE904081201C33
    1    768 006001  6249035526000       34560000 A6E12B22 0B771A3E1440437FC307F9F362DD0C080706A3A080A0DD5646A9AD6132A52FDD3A5349F577C961AA7B4DD3E7CF6B5822F9FA97CB6BD9B90D9F5C7EE55BF79D9F3F730D5577699CD27D11D2A8510653750C8BEA4F9F52ACEA74D6136580F9EDC7EAD32E7D0B5BEA6F5F477E95FBE7EE61578881CDC730AB3FF2DE904081200A35
    1    768 006001  6249070086000       34560000 2D2DD1CA 0B77422F1440437FD307F9F362DD0B090607A00060C0DD564842AD5DF3EA6F5FA5AD4D3265685EBF4CA9F3A530DCC34B5DF3E54EA744C2FD95D37D49FAF7186DBE86F95BD8706C257EAA9BE7E9D056869A1527CF9DB97CAB6575DFB9A8FA13F7D5DF5B56F9FA4D75D2BFA4FD342A55A3BF22FB3574B5DEBFF2DE914285201680
    1    768 006001  6249104646000       34560000 5E2567C7 0B774EF61440437FD307F9F362DD0C090607A3C060C0BD56530CAF09F537B4ABAA730DF3E7C9A13DAEA9F51A6AA13A7CE9F2A7CFA1ABEABD9771739A0267186BD34CF6BC77CBA14F7CBD33E9EE35BF54BD4BE74E9D52869B67EFE1BDAF0E15386FD35676F61D3735D32686A695BA56ADBF5161EBF4B5DF2AB2DE904081201ABE
    1    768 006001  6249139206000       34560000 4D87944C 0B7724EF1440437FD307F9F362DD0B0A0706A3E020A0DD5683BDAEF9F3F534A1BAA685FA17CF94D6A6AD056AEF6D6B7CE9ED6BEED4ECC30995C46B49FE77989DBA7E986D2AD5DF437CFA9447AFA956A55DF52A4AD0D25E4A67F5ACA0B0FA942DF11D3A54FA15B7F494D3A4F9FD779BEBBF4CF92C34C99527B2DE904081200AF4
    1    768 006001  6249173766000       34560000 EE734DF8 0B77BEB61440437FD307FAF362DD0B080606A00080C0D55648444AF9F3EA4FD3424CA9CBF530A1BDA56DF3DB54DF3E7CF6DD2A4E94DEB711A02B536AE1654FB85354F63C286FA9A254FD4DBA695342AD0E9A642F9F567E8B68A59338A90D475AEADF2F22FABD34CF932AA549FC2A55E1427EA9CD67EEA73AF2DE904081201811
    1    768 006001  6249208326000       34560000 E25F0F3B 0B778B801440437FD307FAF362DD0C080806A3C08080D55651248895EEBA695FB9803553B4A975D274A94D67EA9FA57EA693E4B5AB75E2AD97C3A6F6C2A7B0F83AA895542A8E5F3E85626D7A6E5F3F54FA13F734933F52FE65F0EBB94F0DF43D6ADD3DAF0E13E5CFAA0DA4FA9C3434ABBF4B610A9A55DD2AF2DE9040812018FB
    1    768 006001  6249242886000       34560000 A96A131A 0B7771581440437FD307FAF362DD0C090707A3C040A0B55650BEA4FD2C34C99CD74CA9CD67D4A9BE5546B437E992BDD55DCC774FD4D9B8FD97DBA54ABAE84FF8534CE9F66AF4A13E7D5EB57AD6AAEF86FD2C28695FBD7CFA6870EBB94D1525CB039FB97EAA73EAD9E739DF59F6F9D0E1A674F9F39ACFD4C0B2DE944891200CD8
    1    768 006001  6249277446000       34560000 520B8BAC 0B77D5D91440437FD307FAF362DD0C090706A3A040A0D5565056AEFD2C3530D2BE855D53E52FDF3E7CF9F264CF6B537CA9EC37CE9EDDE2FD63DD6B5ADBE850F7EC73608D353ADFBA735E1C27CFA95B7D09F3F4C95D567D4B65EFF686B0FDF477D6152F26A2BBB7B0D33EAD09FC2A55E9A9B085D3D869A0E7B2DE904081201C52
    1    768 006001  6249312006000       34560000 116A2EEE 0B777D811440437FD307FAF362DD0C0A0907A3A02060B55650AB52AC8D27CFD2BF530D2C28695FB9AEE9ED77D9A0D384F973E734DFABEAFD61D9430ABBF7CBB852A55D742B8A5F3E7D4E1BED4FDEC2AEF9F527D49DA57E9665F01FA077112D85645FBF2D06BBE86A5FAAA699DA67AFE02174E95257EF6953B2DE924489201A76
    1    768 006001  6249346566000       34560000 1CEF30D6 0B77EF351440437FD307FBF362DD0C090808A38040A0955650BE7D0D2C34B0A1D1A6B953AA35B542AEF9D2A554953E602DFAB196ABDCF1716043A55B0265D0B842CEAA9AA5D4A13E86F9FD28699F41AEBDEB9D749FAA7AFE67EBEBBD7F0DED8856EA257D4DF3EA699F3AAEA5FC2AD4DEEB86F61A9AEFCB11B2DE92448920061C
    1    768 006001  6249381126000       34560000 2BBF84BF 0B7731BE1440437FD307FBF362DD0B090706A00060A0D55652BE8695556A6961534CF6B577EE553F2AF9CD37CF6BB654F9CEB7CF9EDEE10D602FA54ABBF7CFB8539CF93A984FB621856292684FD38E4960B3D8509F3F4C96588FEC2476FA1C386AB4264CA9F3B735D52A7D4A23E735AC264C9933A74F6153B2DE93468D201E69
    1    768 006001  6249415686000       34560000 63591E33 0B77D7291440437FD307FBF362DD0B070806A000A080D55652A67CF9FA6535D53E5B5D7434A9A73DAEFA925AEF952A74EA9A576E29EDE8BD95AFA55DF3F7CFB84E884553EAEF9F527F0DF3E8509FE67CFA1A67AF9FAA4B4A656FE1D17D5EE427EFA9BE555DF3EA4FA211A695FC7735DF42AE99D29A6F61ABF2DE944891201196
    1    768 006001  6249450246000       34560000 DD44B941 0B773A4F1440437FD307FBF362DD0A090806A0206080D55655257CFD52A4CF94DAA6AD0BA7CF6BBEA34A9BDDF09F527CEA93E73614D9B90D603F7D5E1A67D0B852B099ED6AF1B35656FDCD6AEFD33E7EF69B9AD4AB3E7E9E581013414F008C074FDD53730AC3DA5AA9BDB8EC6C29D5DF5774A75437CAA93AB2DE92C58B20087F
    1    768 006001  6249484806000       34560000 6402A76A 0B77A1251440437FE307FBF362DD0B090606A00060C0D55683BE7D5D2C67D5AB5375063B9A75D2BE5546BBA74F6BBE7CFAA0C85A9F45B8FD602BA74A1A6A54EBD356A933E7D0DF3B1AFAC2654969BF4B09FAA7CE5FBA54EE580BEC2475C52D788993434E492BAA6A6B57B6F952B74F6E2B295A9BE7CAC8BBB2DE944891200027
    1    768 006001  6249519366000       34560000 595A39BD 0B77574C1440437FE307FBF362DD0C090706A3A060C0D55652BEA55D2C374F93267B4DF3DAEF9F3E74A9F3E7CFA8D77CA9F3DDEB9F44C30D603F7DBAE3F7CEABEB86E6B56E09755354FDFA586E695754FDFA174E5FB97EAA58911FB87F0DEDC7EFE13E7D6B9BE7EF6BAAAEFC93A4CF9FAAA506BB9AF4A9B9B2DE9448912014B5
mt=0000024424ED2870 n=3
    0   8557 004018  6248155914000       36036000 5E9AADCF 00000100005FFFFBB8000001B58112171D800000010142D11287B9709AE3B68347FFC042001C5689A2385401E57191FC0D1FFF368AB4C001CC3A6AE3B8D5424A248A1DD72A401F426B4A53BB8454FCADB4E8CA144DE752A4A1243DD75C67A3AB4454547D689B76AD1BD3D092B645C18800627422AB94FA7BA124AB59509A2DB6
s=1 n=1 o=2034884608
    1    768 006001  6249553926000       34560000 3AB960B4 0B772E4D1440437FE307FBF362DD0B080707A000A0A0B55652AA7EE5FBA534E33E7CA6BB9AEF9F424B5DED37CEA0D77D49F267CF9F45E8FD562AB2F2C26A551FC34B0D2C37D5ABD274FDF3E7EE9FB4D70D326535762986AA558FEBBE4D4DF5786FDFBD7F075D2A5AD73DB0F9542854DF52AEE61BE74F9F3FB2DE944891200982
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 2040924160, attempting to work around
005003:0000 Failed to save title 0 to file D:/plex/POIROT_SERIES_11_DISC1/B1_t00.mkv
004004:0000 The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 3229696-3260416, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 7882752-7913472, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 7983104-7997440, attempting to work around
001003:0020 DEBUG: Code 3911 at ^Qjq;+-!?d/:>aLz.mj):121261773
---- Failed D:/plex/POIROT_SERIES_11_DISC1/B1_t01.mkv
ch_0           4954950000 0
ch_1           5495490000 0
ch_2           6036030000 0
ch_3           6576570000 0
ch_4           7117110000 0
ch_5           7657650000 0
ch_6           8198190000 0
ch_7           8738730000 0
mt=000002443645A9A0 n=3
s=0 n=1 o=1148928
    0   7517 000013     8738730000       54054000 D0F5E473 000001B32D01E034124FA380000001B5148200010000000001B80009004000000100008FFFF8000001B58FFFF71F80000001012B7E2168D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A34618
s=1 n=1 o=1234944
    1    768 000003     8743686000       34560000 2E662063 0B773F4214404370F3071CF362DD06060507A0E0C0E0B756903E86A613F4AFDD297E99D3DA54D2C018F9541B8961BD7D5D6BEA4FAB61E2A9EC429D52AE1A4B14D84CADF3F749D1C3B896BC684FA14254E9F2EAE993257CFB7B12200C7D250DC6135DAA8EFB33E7B614D6D749FBA54A6D437D39739A6E933EF2DEAAC58B200A1C
s=2 n=0 o=8009728
mt=0000024424ED08F0 n=3
s=0 n=1 o=1148928
    0   4908 000018     8648640000       54054000 FA320F3F 00000100001FFFFBB8000001B58111179F80000001012AE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBAE7FBBBA
s=1 n=49 o=1234944
    1    768 002001     8778246000       34560000 B44F0EFD 0B77BC0414404370C3071CF362DD09080709A06080C0755683D77CFA0DBA4FDEC2A4F9F56B4FA0BF7CF9F3B49608BF2B0D0C27E95FC8C10DAEC36B52AE1A64ABD27EADF427EA9EABB55A2257CAA92A7CF63BA7CF9ED6B74B6B9C5FA653250D9579C442E14D2BF530DED77CFDCBEAD4D2D2CE992C28549F3EF2DEAB468D200552
    1    768 002001     8812806000       34560000 38439BCF 0B77762714404370A30718F362DD08070607A080A0E0B576526C7D09ED6A54A954434D2BE7CF9F267B5DD2AA695F4E55069537CAA159B95E537AEB5EBD6B0429EEAE3BF7EFA4268923388870E95686E6025A4F954F74A939084FDD297D49ED851E5BD489122402FD1F83589C3C781952C3B8B820502EED09989237AE32DE5E2E
    1    768 002001     8847366000       34560000 4D01F3F4 0B77EE5D14404370A30714F362DD08070707A080A0C0D756844369A126B4B4DCD374F9F2A4CF9F267E42BA5CEF9F2E54F9D2674A9F5990F9DFC86B62AE2729EBD37CFDFBE7E52DBE7E969BE54A61577AFD5264B4ABBD7EE777F0E25285884595EF939285608A98D5DF3DB55DED7A4FD2A6850A929AEF9F3AF2DEA84081201D08
    1    768 002001     8881926000       34560000 24BE2758 0B7791B014404370930713F362DD09070606A060A0C0D55652BF7AFABA654A94D6AD4A956A6F951274E93A174F9F2E7CF613F54E955CEAFDA05C6B66860AE9F5D77EAC92586F615422F9FB9A832B527D4D5297CF6224D75B6810E2575321DC454FD32FACFA9BA4B0973F52FA9BB72F9F4254AD2BE74E9CEAF2DEA44891200351
    1    768 002001     8916486000       34560000 A85E106F 0B775CC414404370830712F362DD06070607A0C0C0C0B5A6929174A9CD754F8ED6A5AE73A535AC7A8303B466ED4E32BA34E16B5319F427D1B74F1ACA754ADFA78F5D2D952F6C1D84ADF3E7CE9EC37B0A152A6E9CD67EAA98DF2DE93C78F20086EE7EEBFBF8FF870C158BDBFDB8F0A04DCBFA80A49847D788A31EDC62055E2C61
    1    768 002001     8951046000       34560000 713E68F4 0B772F8E14404370830710F362DD07080706A0A060A0DF56472556E613E7CF9F425371EBEB4F6BBB54A23D2A4FA9AD7D0A13F4B5AB5DE9219FF569C9EE1749E1577E9A92AA54DD8C7CAA94E534ABBEA6921537D0D390A69B67F6EC407B629A7B74D33EAD61328B70D2C353108534B5D32674A9D298D4A9A5F2DEA0408120193C
    1    768 002001     8985606000       34560000 79DE74E6 0B770CD51440437073070FF362DD07070809A0A0A0807F5652428749ED7A4F9FA649AE1527CF9F22A549F3F4AFA93F4AF77D284EAB5DE961D3C773CA0DD74AEB56AEFDED37CFAB66A4B9FA47AFEA097CF61A5AEFA1474B5374F0E1BF86FEBA7B0F93277CF953E7CFD2C2A69693B7B59F3E9D0D3271AE5F46F2DE9E4C992003CB
    1    768 002001     9020166000       34560000 29AFF81B 0B779AEF1440437073070EF362DD07070706A0A0A0A0FF56462B52FD2D844E2A2584FD25B7B5DF1352F61BE7509F8E734A93F730D344EAADD3DB73C77617B154D76B61EC1B7112C2730ABBA4AFDEBF4B706574CB95B97C9B74F0E158870F5A7879D342AEF9D3EA4F9F3F74F9CAA7D0DD264B09F3E8692BC2F2DE9C48912005A5
    1    768 002001     9054726000       34560000 141CDAB1 0B7739B31440437073070EF362DD08090708A08060A09F565056AEAA8D74CA9F464B5DF2A7D0A7267CF9F3F4AB9F3F2339F3EA361349B299A0479BC77497CAE3BA7361D264CF9EEB5499F424AFE8BE8699F3E7CFDCD67EA76810E170890ABAC4D49FAAB0923BDAEAA1BA4AFA94EACBA12A54F9F3E7CF9F3FF2DE9C4891201993
    1    768 002001     9089286000       34560000 2650FF9D 0B772E2A1440437073070EF362DD09090808A06060809F5650B9AD5DF4274E9F427CE953E7B5B5A67CF6BBD86A953B4AF9F3E8695F5DBC99D3DB9BC7749A49EB58190EB2A7EF9ED7730AC9041ADEDC7E354D7A509FBE734B74D7237622FEBAC5EE9F3E855DD3A7CEB33E7CF96D77CF9F567CFD2BF4A9973EF2DE9B468D20061C
    1    768 002001     9123846000       34560000 E4904ABF 0B771A971440437073070EF362DD080A0708A0A020A09F5648BE5695F29B8588BF52E95A57CF69927CA933A7CF6B56A895F3E7695F5CF4ADDDC3A562D5CD6B1F3A74FDED27EF95B97CF77C251726BFA34E93F4AFD5297EEB74D223F0550B892AF9E92AA50D5267B6D5B97D4A8DAA6A95427CA9F3DAD0ADBFF2DE9C4891200405
    1    768 002001     9158406000       34560000 F33C03E6 0B77C8E11440437073070EF362DD08080708A080A0C09F5654BA7BBDF2E7696125D55D59174B931284F696B7B0ABBE7CA6B43834ABF2B8FDA2446BB6AC9864D739855F33E857D33F72F9FA97AFEAD2AD712D842E9339D55374D6EE6C531F640854ABA685A9FAA54B6BC27E929BE7CF69C17EF9EBE7EF6B3FF2DE9C4891201C7C
    1    768 002001     9192966000       34560000 BFFBFFB1 0B7734F31440437063070DF362DD09080706A06080A0FF56483F7E3693EA35D4D686E9F25AEA9F0D86F5FB9AEA7556B50D52A7CF95C5B8FDA2446B668E18501CD34E95FAA2B0A1AAA35DF524C99EC04AE952B4AFD33D7D0B74D222577B6F6407E96BA674F6BBE84FABBA435AC25830ABBDA8D5DB486E6BCEF2DE9A4489200180
    1    768 002001     9227526000       34560000 2287F0F3 0B775D4B1440437063070DF362DD08090607A08060C0BF5650AE73610B97D09FBD86E953A7B09F26855A2114C99D29A6E94D4495D549E90DD5C46B62DC974ADD39AD4E13E804926F8546DBDCD0E8BF568673F4B0D325AD0B74D72C584972C2B7D4A9BE850CAC2A845EC34B0DF3E72FE6BDBA954D74B0AB52F2DE9A44892001FB
    1    768 002001     9262086000       34560000 65DE7A61 0B7722891440437063070CF362DD09090808A06060809F5650CDA54A192530DFA54B5AB5372FDD11855AB577545F3EAD0A142AD0A1C4EB4DD3C469C6DDBD7021397EFA9BD86E69A67D0A13E74E693F7CF6BC286E5FBA515F745121EC555B6AB535DFA9AF09FBA54E6BB9AEE94D35B0A1AA9CF3824B74D34DF2DE9A44892018DE
    1    768 002001     9296646000       34560000 F90B7964 0B775FB41440437063070CF362DD08080608A08080C0BF56483EA6992BE7D5DD3D84FD525CE95F228696B528519FA5A4FD4BE7EA5FC5C101DD5CA3C9F48A69AB52A6FAC0CADBDED77D075BE72ADD39AEF9D2A7CF9F5684FF74D121D7AD1F8447CFD3267CFA1537499529A4FA1AA4AFD4D372FA9B9A4FD529F2DE9A44892006CF
    1    768 002001     9331206000       34560000 80C5D046 0B777A641440437063070CF362DD0A080707A04080A0DF56463E7EA613EAD59F3B7B4A13EA6F92BB4AFDF257E95FA652FD4BE7CB0670ED1A074471DD542E0AA9574B6EBA180421C27B0DF3E4B0DCD77CAA152A4FD2EA7B5F81B1216D7B1F8AF7B5E1A58EBA1A48F1A1576AF9F427CF9F3EAD0D33DA556BD2F2DE96CD9B20196D
    1    768 002001     9365766000       34560000 87E4F7F4 0B7745521440437063070BF362DD08090805A08060A0FF56503E74F9F56A696BA556E5FA8AF0D4A67E961A25495FAD7D09F427D4A04588AE06DD71CAAD8B239CE74B5E9A67CB62297CFD0BA83145C35CE9F52AEE5ED7A53B81B0EBEC8376227A4F9552B6A6B5B84F9FBA52A9F3EA4FD2C27CFDCD34E3F839F2DE944891201D5D
    1    768 002001     9400326000       34560000 4E3DD6A9 0B77226B1440437053070BF362DD08080708A060A0C0BF5644527EE5F527D4DED2A4F95B97EA5F2AA69A6BA7D0D2BF4AE9CDB8699CE2B76206DE3FC2DC57EADCE6859B824BF5D33DAD5DF3A54E9FA154E6A2573608BF2C9381B0EC3F5326C27534D3A1AEF953F4B1C92584FA952850A1437C9553F4B0DED3F2DE964C99200744
    1    768 002001     9434886000       34560000 8AF421B6 0B77CD361440437053070BF362DD08080807A0808080BF56463EAD4A93EA4F9F3A7CE9D2A7CFD2A684FC8BF72F9F3E7B612BE7D4D393E91E06CA3FC21C8B09A9B9870B4EBA50DD3DAEF9F3E7499EC422F9D9272FA13E7E9781B0ECA6251EE5B8748B3DDEAD53E5695F51D749F3E7D4A9427D0D2BE7EE9D11F2DE944891201C51
    1    768 002001     9469446000       34560000 16B529AB 0B7766621440437053070BF362DD08090706A08040A0DF5650A57EA9CBE7CF9DB8AEF9F3E7CFD2B67D49D567CFA8D77E96966802EDF6AF5E10C971C2BC7E29A9B97EFA191A4FDD567B5DF51A69A13A54F5F42AEFD2BF4C978430EEBB217363F7EF69D74AFA13F74FA13F4AF9F3ED559F3E54F9FA97CF6DC2F2DE95CB97200AF0
    1    768 002001     9504006000       34560000 950C93B3 0B7780241440437053070AF362DD09090708A06040A09F56483E54F9F3E7B5DF41AF49F3E7549F12A4F952A9D0953A7D4A93E7D0D2DDEAAE06DD51C21DBE09DD5A7EA6BBE7D4A9BA74F9F3A74A9F2A7CE9D3E4E95526569774CBAFF5250F8277D5D341B099CC37B6DF3E836E13B52F933EA4F6B577CA69BDF2DE9244892001DE
    1    768 002001     9538566000       34560000 C713289D 0B77D3471440437053070AF362DD07090609A0C060C07F56464EA4FDCBE7E92DAA7B5ABD684F6D927CFC857A4F9F25AF49F3E7D49DB190FDD35FB5C245AE04DFBE4AFB9C2755A9AA7505FBD86A9F39AEF9DA17B1085754FB8430AFF126F7AA7ADAD3A5850D6C2A892BBE84F9F3E864693E7CF934343061BEF2DE944891201A8B
    1    768 002001     9573126000       34560000 24F85BFD 0B77399E1440437053070AF362DD08090807A0806080B756463E7E85F3F4AFAB3E7536BBE7EE883F7D49CD774E953DA6F6BD27E95559C4E9D373B5C163AA84D5564D4ABAA7EF6DBA54F9F3F42F9D3E74AA1274AE9F3E54FB81CA6FF6530EC137D4C951DF008BA7CFA1434CA92BEA645D2E53AA9AB4485F3AF2DE9448912005C8
    1    768 002001     9607686000       34560000 0A40E46D 0B779F9F1440437053070AF362DD090A0609A06040C07756443A7CFA13A74F9FA57B5E72E7CFD23B74F9F3D889553A53612D27B5D7DDB8B1D3DA85C15C3AEB1D42554E12A7EE69BE535DF429B61454534615374E9F2A7C8B81AFADF17B1F830AD0D34DB099D25B098924AEF6BAA84FA741AEF934254F9D3EF2DE9142852001B6
    1    768 002001     9642246000       34560000 7737D7AA 0B778B331440437053070AF362DD09080708A04080A097565039B092A24D501EAE7E453A57CF9D127B6A1574D094BF7CE9F3E7CEA159C161D3DA85C1558B84DCDC4CEA9917BAA43988821C1755D4E81A96BA9AF39F3E74EB81B0AE597922C137D4D33AA54C66FA54D53E5549F3E4CFD242AF0954E74A5FBEF2DE8FCF9F2017B9
    1    768 002001     9676806000       34560000 D66EB084 0B778A1A14404370430709F362DD0A080606A02080C0F756504274F60115509F297EA933F6AF9F11D835D4DADADD3D83C14C38CFA1DDE29E0746ADC15448F0E0F456E9F427CF9F42A5612C17D0D4BF4D49D5244E6BAA7CF781AAA459791EEA77D5D3B8B04613F53ADD3A7CA9D3DAEAD243554953E749953AF2DE8E4C99200982
    1    768 002001     9711366000       34560000 1D1035B9 0B77D9F114404370430709F362DD09080805A0608080F75645D37B5EB3A54F6BA64B5E0BF54F94BED6B96C2AE99EE6D6F6A26410DF75EB21D3C37DAD543DA4B5D744F9F267B2153E535A9D2A49620DA35AD537C99ED374A781AAAEC05182E2B9D5D33E7CFD2C2AD106677645D29AEA9F2A54F9F3A9B4A9A9F2DE90C1832005C8
    1    768 002001     9745926000       34560000 A0A52892 0B7780D814404370430709F362DD08080905A0808060F7564EA4A6E6B6F5CE9CD774F6BCE749A7267D4C8BA74E9D2B495DF3E7D06BD9E10DDDC7A6F955BDA4AD6B5746DBE5D39FA5A6A9D29A50A9A9AEE9D297D0DEDB84A781AFAED8498362AD8F93A5A695F6687473BEA4A9D90D6A9ED6AEF92D7A4F932AF2DE914285201AA7
    1    768 002001     9780486000       34560000 3968EAC3 0B77DF7514404370430709F362DD08080808A0808080B756462B4AE69BA74E6BBE7CE9D2A54A6B2C42A953E54E694354EA0D3735DFC3E54E07447569557E2A9F4384FB543ACEA9BA7B0B566A3AE3BA569215818FA9A5AD4B81B0AE7551769AF76E5FE5D6B9F527EF9ED77C9933A7AFA1584AA9ED286A9CD7F2DE8C489120054D
    1    768 002001     9815046000       34560000 00C1C4FB 0B771CC814404370430709F362DD070A0807A0A04080B556463EACF9D3E7CA952AA2F9FAA4CA69A5A881FBDA6F9ED27EA6DBA74F61C4E4FDDD5CA759639E101EEB7D0D2BF7CE69BEA4EA9B9A699F2A74992C354F69BEA2FB8430E3ED5325D2757069B9D6FABA5AD5D4D754A9F3E7E95D42A3ADF25AD4DEC3F2DE91C3872003DE
    1    768 002001     9849606000       34560000 039E020E 0B772BD914404370430709F362DD08090707A0A060A0B5AA443E7E894BDAF36B43554A0C071AE1FC82F0D870B8F69BE5CAA15374A6B3EA55E825673ECD859FA15EE6156DF09ED7CCFACB7A312244806008A4C74CB4DBF138C0BA0E0A12CBF99DDFA1185B84917407B3C92949DC647198566161BD2F486D89175722A0D72DA460
    1    768 002001     9884166000       34560000 4436B10C 0B77913C14404370430708F362DD09070808A040A0809756153E54F9ED7835DF39AEE9ED6AEB5F96734D32A4CA9552A35DF3DA6F9F5DE2FDD3C6B1495C7E84E6EC234A12B4CE61BF233A9A67B0A96B734DF29BEE9D3E7C9B81AFDFDD54FEBAC4B59FCEA509D3F4CE953DD6FD2C27CA6BC27BAE93E7CA9529F2DE8F4E9D201D2F
    1    768 002001     9918726000       34560000 F8194D40 0B77E66F14404370430708F362DD0C090707A3C060A0B55614D44AFA93E7E95F3E54F75537CF61A67B5A93F7B0ABBE7CE61B9A6FA0F5F3620747A5BD5D3AF11D5684FD2BDB0A6157CAFAC424AFD7A152F9FBE530A9434B5B81B0EA438515D92859DFA0AD0DF529E96955B70DD29AD9A1BD84FDCD77B0AB56F2DE8C489120001F
    1    768 002001     9953286000       34560000 8152BB97 0B77FE6214404370430708F362DD0A0A0807A0204080B56645D354A953AA4A6B3E86A9F3E4AFDF3A7B5DCC27EE94BE86F6BBE7CE6DDEC0AE0BC35FC9B43749A0C3854B5924CF92C3E06C3815DF487D112F04CF6DA9B28216AA4FAB539CF75AA54E6BBE53AD529AD5BCB7A31224480648DCDDAA3CEE9C8FCAAB25FB5B14020348
    1    768 002001     9987846000       34560000 EACE9D22 0B770B2814404370430708F362DD08080808A0A08080955A153B214ABBDA749F3E7CE9D3A7B5D2AF54F932A75075C1B6F9D51AD0DEE390AA11444D595BFD6AEBBF1CF61427E869AA7B5E13F4B5A9A980848D77C99325A54B8238AA53B0BA98D84FA9C27CF9F2A7CFBCB7A312244800508AB88EE5356ED52884D74CB928B2D706
    1    768 002001    10022406000       34560000 22A0A115 0B77FE4E14404370430708F362DD07060705A0A0C0A117B5D4F04C86B58CB0DCC3ACA6BBE7B6A2FB92D229437CEE73EADC0D88ED5AA85BB6D7D5512C6853DF3A56A61267D49D41ADBDDB9835AB679E868F96F4264C9900114D3ECB92379EC141069913F1FDDD7F9CBF1F308A276ADB8A1CA87E98AFB97513CE1CB31D7D82B1E1
    1    768 002001    10056966000       34560000 D9DED72A 0B7718C314404370430708F362DD08080707A0A080A0B7B6043EA4FABC34B0DE5BADADF527CA6E7C82F2B866A6E933DB7C21870F8A97F653A28371CBE7CFA1AA4CFD0BDAEF933E7C9953A9CFA93E7BAE1796F442040900BDEB2A908FEDFA6DFDC04614EF045CF20F17383FE05CAF458D16E6EEE125FB2527271A1BA9C8D25316
    1    768 002001    10091526000       34560000 AAA13422 0B778F7414404370430708F362DD080A0907A0A02060B75643D34C96B527EAC8C2734D4C1E0A69A186E6153730DD3E7CF9F3A5D073D9C10E465B7F6D5D94C5A33F4B5ABBF296E15374E5FB97CFD4BF4C997265B5E7A57CFB84B0EC577D6EDAFB8F93B97CA9F534B5DF3E52FD52A53110AAA4E6BBA4CF6154F2DE8C48912003CD
    1    768 002001    10126086000       34560000 B8949137 0B777C8A14404370430708F362DD07070908A0A0A0609766064284FD552769753E850AB427D0D4BF7CA9CC27EE953F4C95F527CA69E2B77648DC615F6298831ED34C557A57CFDF53E50BF857533F7CB21428736BC27D00647AE95ED686F9F29A74D2C274E954E7E97CB7A291224800704317BEAFF9FFC5B85808EA7FA67A3CCD
    1    768 002001    10160646000       34560000 8C630396 0B7700F114404370430708F362DD0A080906A0408060D7561339B55DED77B0E6D3ACF9D3A7D09D167CA6B56A55DF3E7BAAB539B0DF44EB4E52C6895983B7D0E96B4B510AF4AF9F534C95FBE4B5DFA572FDF3F715EBBDA55F972FDF70890A9BEA75D5A584F9D3E7EA9D3DAEAD2BDAEF9551AEF932A7B612B9F2DE8CC9932013F4
    1    768 002001    10195206000       34560000 E9A3CEC1 0B77BF4214404370430708F362DD07090707A0C060A0B756462B4AE6DA586F6DBE7B5D4C37E9552752F953A56A21BDA74A92B5309F45B91252D689A9856AEBED527D4ABC34C992C27E9933E4CF6C217BADED784AABA58E9B972FA1F57B621589BBE9CDBEAD32A4C9933E7CEC8AA7CE69537EA5F3E536A9BAF2DE9040812006D2
    1    768 002001    10229766000       34560000 A1B1D15D 0B77068514404370430709F362DD09080807A0408080B756463F4A96E364B46BBA5549529AEA9D1342E92D2A50E139AEF9D2A54A955EB75E5A6FAF6D5C4A6AA9BD7D0DCD7D6E5FA5AEE94D34CA6BBF22FDED5AF4A9A64CAB9715E9F4870E9BEADBD5A9AEF9F4354A6BAA7B9E9A0B706B584AE6C2A4AF9F3EF2DE8FCF9F200B19
    1    768 002001    10264326000       34560000 30A78E93 0B7739DC14404370430709F362DD09090807A0606080B75645BEAEF9ED77CF9ED374F69BF490DF2654F6DD27C99D397EFC6D2A4F9FD8C1669044750A03F7D0ED51DEFA1AF4B4A93EA55D53A530DD5274F6A259EEC642855FA20FDF5D55012AC7D6D33A7B5EB535642DBF54490537D09F2A80915524C99D3DF2DE8E4C9920110F
    1    768 002001    10298886000       34560000 99AEBFEA 0B7787A514404370430709F362DD0A080809A02080A07756153A7D4932E735ABD254F9F3E4B0DF2274E62257D596D2AEA953A753A9B0E14E905B556D63B7E5DEEB54D69477D475D3536D2D67F4953E7CF9ED77BC1CC37CFB969C13C3B0EDD2BA55CB4E835E9527E99F3E74EC8B9A899C3F735DE5C7B5ABBAF2DE8ECD9B201F6C
    1    768 002001    10333446000       34560000 DC0EE04C 0B771F5E14404370530709F362DD09090808A04040809756442B215DF3D8E96D6B7CB9D3E5841EBB7695D3E74F9D3A7D09F2A7B0DDC3EAFE9051DAE963AB6AB5D686E75BE8549DA17EE6BBDA5610BF4C92BC27EE5FA57D4FA3F4ABDC88FD73ED9969BE86A9F3F2499F3E7CF9F3E74F93527B0DF8CB88533EF2DE904081201E14
    1    768 002001    10368006000       34560000 57427FC6 0B77CDC314404370530709F362DD09080706A040A0A0D7564639B0957434AF9F3DAEF9F3E4CEA716A4F9EDB84F9F3DAF075CF4AF9348ECEA52AEB2922B9E0FB5D1B74ABBE7EA60215506DBDAEFA13E7CFD2D188F94C28A1F970FB658554F5A6D7C093CC295F5280A885B730D2DACF075AA835D2EB7CF933EF2DE904081200301
    1    768 002001    10402566000       34560000 CC7A3DC6 0B775DCF14404370530709F362DD0A0A0908A0204060975650527CFD26B7CFC6534C99F3A4E8929322A953E7C973AA530E8D77CF9EF6E95E862DE3095BBB0975D27E973BEA69613F74F61AA7D09F2AA6922258699F2674FBA3F5B65B80EAD40AD9DFCCB849F4256A6B44510DF2A534EC0854A75BA7CF953AF2DE8ECD9B201FB1
    1    768 002001    10437126000       34560000 4DDEAC20 0B77558F14404370530709F362DD0A090806A0204080DF56462A5CF6BAA4E9553E74F9539A6F9D367CF6BA5A54A9437E82BAA7B5E15DF1B2526EE4A22BEDF020C256F9F4441512AA7E56BA17B5E9527D4AC2584E9EBF74EB9715AE5AECE75BFCF59FCD8696BD27EF9CD784A9F3DDEF9F3A4B4E13E74F94D8F2DE8D4A9520182E
s=2 n=0 o=8009728
s=0 n=1 o=1148928
    0    288 000018     8702694000       36036000 FD081E72 00000100005FFFFBB8000001B58111171D800000010152AC04052B0000010252AC04052B0000010352AC04052B0000010452AC04052B0000010552AC04052B0000010652AC04052B0000010752AC04052B0000010852AC04052B0000010952AC04052B0000010A52AC04052B0000010B52AC04052B0000010C52AC04052B0000
s=1 n=1 o=1234944
    1    768 002001    10471686000       34560000 66C8CAB6 0B77DBF91440437053070AF362DD09070807A040A080BF5645D37E35F3E7CEA93E54B9F3DA6F9F25AEF5F581B0D056AEAA13B4B9A1C3EB128FD6E3095BFB6B133E74A9ED7AEFD2D27E99D397D3DCC286E75AA54F9529D6AB9710AC5BBAFABA6B7462A086A6C395D4A1D59EF952A4CF9F3E7EE293ED56EB3AF2DE92C58B20163A
s=2 n=0 o=8009728
004004:0000 The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 8003584-8007680, attempting to work around
005003:0000 Failed to save title 1 to file D:/plex/POIROT_SERIES_11_DISC1/B1_t01.mkv
005004:0080 0 titles saved, 2 failed
005037:0204 Copy complete. 0 titles saved, 2 failed.
Application exited at Tue Aug 23 19:40:50 2022
I was going to suggest trying version 1.16.7 of MakeMKV, but then I realized the OP was using version 1.14.7. The next poster was likely using something newer than 1.14.7 but older than the current 1.17.x versions. It seems like there's something weird about that disc that surfaces a bug in MakeMKV.
^ that message seems bad
kyrra wrote: Tue Aug 23, 2022 7:42 pm It looks like Series 11 disk 1 has a similar issue?
Those errors look different. If you were reading from the disc, I'd suggest the disc is dirty and to try gently cleaning.
kyrra
Post by kyrra »
dcoke22 wrote: Tue Aug 23, 2022 8:51 pm Those errors look different. If you were reading from the disc, I'd suggest the disc is dirty and to try gently cleaning.
Ahh, thanks! I'm guessing my disc 11 may just be damaged then. I don't see anything obvious on it (and I did try cleaning it already).
