Main contents of DVD not shown as available to rip
solidsnake1298
Post by solidsnake1298 » Mon Aug 22, 2022 1:09 am
I've got a DVD, Appleseed Limited Collector's Edition (Geneon 2004), where makeMKV only shows the (probably) main menu video loop as available to rip. There are no additional items to select from. I made sure to remove the minimum length requirement (set to 0). When I playback the DVD in MPC-BE I am able to play the movie.
makeMKV 1.17.1
Pioneer BDR-XD07B, firmware v1.04
Windows 10 21H2
I am in the process of ripping my collection to a Plex server. This is the first and, so far, only DVD that I've encountered this problem with.
wmcclain
Re: Main contents of DVD not shown as available to rip
Post by wmcclain » Mon Aug 22, 2022 1:30 pm
Does MPC show the title number being played? (VLC does). If so, you can try Manual Mode and specify that title.
You might also experiment with Preferences -> Protection -> DVD structure protection removal method. Some new options were added recently.
solidsnake1298
Post by solidsnake1298 » Mon Aug 22, 2022 6:12 pm
Interesting. Manually setting the protection removal to "CellFull" instead of auto fixed the problem. It is showing me the full contents now.
CGooden
Post by CGooden » Sat Nov 05, 2022 12:24 am
I am wondering if you are still having issues with the Pioneer BDR-XD07B drive when ripping UHD disks. I see the price on Amazon is less than $100 and I was thinking of getting one but would like to know if it will work with MakeMKV first.
Also can you tell me if this drive supports 4K Ultra HD Blu-Ray? Not really sure what this is, or possible it the 125 GB m-Disk format?
The other drive I am considering is the Pioneer BDR-XD07UHD for $225.00 on NewEgg.com.
Thanks for the info,
Post by dcoke22 » Mon Nov 07, 2022 11:13 pm
CGooden wrote: Sat Nov 05, 2022 12:24 am I am wondering if you are still having issues with the Pioneer BDR-XD07B drive when ripping UHD disks. I see the price on Amazon is less than $100 and I was thinking of getting one but would like to know if it will work with MakeMKV first.
I don't think the Pioneer BDR-XD07B supports UHDs. The OP was talking about a DVD anyway, hence the reason this post is in the DVD section of the forum.
The Ultimate UHD Drives Flashing Guide post is maintained and has a list of recommended drives to consider.
Ultra HD Blu-ray is the format for 4K movies that are sold on disc. It is not M-DISC, which is a write-once archival format for optical discs.
