LibreDrive for Pioneer drives
ElOsoTito
#286 Post by ElOsoTito » Sun Jul 31, 2022 5:42 am
Hi fellow movie nerds. Sorry in advance as I am learning a lot of this as I go. I recently got a pioneer BDR- XD07UHD disc drive and was wondering if someone could help me out with what I need to flash the proper firmware? I saw a list of firmwares below but was unsure how to download or flash.
Thankyou all in advance so much! I think this is the final step I need to take to get this server up and running.
Thanks again :D
#287 Post by Billycar11 » Sun Jul 31, 2022 5:54 am
ElOsoTito wrote: Sun Jul 31, 2022 5:42 am Hi fellow movie nerds. Sorry in advance as I am learning a lot of this as I go. I recently got a pioneer BDR- XD07UHD disc drive and was wondering if someone could help me out with what I need to flash the proper firmware? I saw a list of firmwares below but was unsure how to download or flash.
Thanks again :D
you dont flash it
ElOsoTito
#288 Post by ElOsoTito » Sun Jul 31, 2022 5:01 pm
I’m almost wondering if it was just the disc I tried the first time. I’ve been able to decrypt and decode a couple other 4K UHD discs with no issue. I just picked up the new remaster of Species and it just WILL NOT decrypt it. Anybody else run into this?
Thanks,
#289 Post by d00zah » Sun Jul 31, 2022 7:34 pm
ElOsoTito wrote: Sun Jul 31, 2022 5:01 pm I’m almost wondering if it was just the disc I tried the first time. I’ve been able to decrypt and decode a couple other 4K UHD discs with no issue. I just picked up the new remaster of Species and it just WILL NOT decrypt it. Anybody else run into this?
Thanks,
UHD FAQ (linked below)
ElOsoTito
#290 Post by ElOsoTito » Sun Jul 31, 2022 7:40 pm
You guys are awesome! Thank you so much!
DarknessUK
#291 Post by DarknessUK » Mon Aug 01, 2022 11:28 am
Just wanted to call out Asmcom who I bought this drive off via Ebay and his store there.
Am v new to the MakeMKV world and he has helped me (am a Mac user) when I had issues / questions about burning speeds - went well above and beyond what I might think is the normal support, as the drive was basically working. You may save a quid or two getting it from other places, but you do not get the stunning level of support he gives!!!
Enjoying the drive as it burns discs much quicker than my old drive, now to read up on MakeMKV and the joys there 8)
SirReallySam
#292 Post by SirReallySam » Tue Aug 02, 2022 9:16 am
Anyone got any ideas why no UHD discs are working?
SirReallySam wrote: Fri Jul 29, 2022 1:18 pm Hi there, I've recently got a new UHD Pioneer drive that I'm trying to rip UHD discs with.
It's the following:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.03
Serial number: TJDL000950WL
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 61
Drive platform: RS8D31
Firmware version: 1.03/ID05
In theory should this work I think? I'm on the most updated MakeMKV, have enabled internet access in the preferences and have sent of the .tgz files off to svq@makemkv.com a couple of weeks ago. I'm still getting 'the volume key is unknown for this disc' only for UHD discs, standard blu-ray and dvds are working fine however.
Any help would be appreciated.
Thanks,
Sam
#293 Post by Billycar11 » Tue Aug 02, 2022 9:21 am
SirReallySam wrote: Tue Aug 02, 2022 9:16 am Anyone got any ideas why no UHD discs are working?
It's the following:
OS device name: E:
Revision: 1.03
Thanks,
Sam
try a diffent dns
try my privatedata.tar keys in the guide
the issue is on your end if no UHD discs work its internet related disable your geo filers and other junk like that
SirReallySam
#294 Post by SirReallySam » Tue Aug 02, 2022 1:29 pm
Hey Billy,
Thanks very much for this! Think it was indeed the internet blocking this.
Cheers,
Sam
Billycar11 wrote: Tue Aug 02, 2022 9:21 am
It's the following:
OS device name: E:
Revision: 1.03
Thanks,
Sam
try a diffent dns
#295 Post by Billycar11 » Tue Aug 02, 2022 8:55 pm
SirReallySam wrote: Tue Aug 02, 2022 1:29 pm Hey Billy,
Cheers,
Sam
try a diffent dns
What fixed it for you
bimbi
#296 Post by bimbi » Wed Aug 03, 2022 7:45 pm
Now got me a Pioneer BDR-S12UHT, works perfectly with 4K.
AintNoSin
#297 Post by AintNoSin » Wed Aug 17, 2022 10:15 pm
Just checking in. I have a Pioneer BD-X05 that seems to be on its last legs. It takes a long time to open and rip disks, at least compared to before, and makes a lot more noise than before as well, even when the disk is just in the drive even before I do anything. Also, I seem to get more frequent media errors. The drive is several years old and most of the 600+ films in my Plex library were ripped using this drive, some more than once.
I'm looking at the BD-X07UHD as a replacement, but I wanted to know. Are those external slim drives just naturally more fragile than internals. Would I be better off with the BD212U?
torkya_titzoff
#298 Post by torkya_titzoff » Thu Aug 18, 2022 2:55 am
Hi guys, looking for a little clarity if possible.
I have a Pioneer BDR-S12U (Drive Platrorm RS8F01) but Im having issues ripping any 4k disc.
With only 3 in my collection to test I get the error message "The volume key is unknown for this disc" on all of them.
The 3 discs tried are
Ghostbusters - Afterlife
Tomb Raider
Spiderman Far From Home
MKB20_v76_Ghostbusters-_Afterlife_CF57.tgz
(175.98 KiB) Downloaded 541 times
MKB20_v68_Spider-Man-_Far_From_Home_D19D.tgz
(198.66 KiB) Downloaded 479 times
MKB20_v61_Tomb_Raider_4447.tgz
(144.78 KiB) Downloaded 469 times
#299 Post by MartyMcNuts » Thu Aug 18, 2022 7:42 am
torkya_titzoff wrote: Thu Aug 18, 2022 2:55 am Hi guys, looking for a little clarity if possible.
Tomb Raider
Have you allowed internet access in Preferences? This is needed so MakeMKV can access/download the UHD Volume Key database.
torkya_titzoff
#300 Post by torkya_titzoff » Thu Aug 18, 2022 8:31 am
Ta muchly ... Here I was thinking I had down everything lol. Didn't think to look for setting in preferences to allow internet access.
Thanks again
