Disc access speed in 1.6.6
Post by mike admin »
This is continuation of http://www.makemkv.com/forum2/viewtopic.php?f=1&t=2600
The disc IO engine is updated once again in MakeMKV 1.6.6 . If you experienced disc speed problems in 1.6.4-1.6.5 and still have them in 1.6.6, please post here. If your problems are gone with 1.6.6 then post a note too.
RickH
Re: Disc access speed in 1.6.6
Post by RickH »
Fixed the DVD access speed for me. Thanks.
With 32 bit Windows XP Pro SP3 using external USB HP DVD1040 with DVDs only
philnort
Post by philnort »
Good results here, also (although in all honesty I never had a speed issue with the previous versions either). I'm using a firmware- modified Liteon IHES-208.
Another "good" result for me (maybe to do with continued mod of the I/ O process)...in version 1.65 my BD RIPS would start to fail at the 60-70% process claiming a fault with the BD STRUCTURE. However, in 1.66 the BD RIP IS FAST AND FLAWLESS. (I tested with 4 of the same BDs.)
Thank you....
broconne
Post by broconne »
With 1.6.6 I am unable to open the only BluRay I have tried. I turned on debugging and the last entry in the log is "Using Direct Access Disk Mode". I get a program error, exiting when I try and open the bluray.
1.6.3 is able to open the BluRay and is presently backing it up to an MKV.
I am running Windows XP as a guest within VMWare ESXi 4.1 with the drive in passthrough mode.
leylandleopard
Post by leylandleopard »
1.6.6 has fixed my speed issue, I'm now back to the speed of 1.6.3. :D
Many Thanks
Windows Home Server V1 Service Pack 3 (Win Server 2003 based)
HP Proliant ML310 G5 Xeon Quad core
8GB RAM
crowfax
Post by crowfax »
Everything is fine here, getting between 2x and 5x ripping on blu-rays.
Ubuntu 10.10 x86_64
Plextor PX-B310U External USB
PeacePipe
Post by PeacePipe »
Disk access in 1.6.6 was fixed working now once again 3-6 times faster than in the previous two updates. Returned to 3.5X -7X speed, taking only 12 minutes vs. 75 minutes for a 5GB DVD. Thanks!
Windows XP, Athlon 2.6GHz CPU, 4GB RAM, eSATA external WD10EACS drive.
Navvie
Post by Navvie »
I'm currently ripping 24 Season 8 on blu-ray... disc 3 would not get any faster than 3MB/s until the last ten minutes or so of the rip when I got to 10MB/s. Except for the initial slow copy of small files, disc 4 has so far been at 23-26MB/s.
Both discs are new, having been watched once on my Sony S760. No scratches or finger prints or anything.
Ripping on a Pioneer BDR-205.
Registered user
Linux / Windows 10
Asus BW-16D1HT 3.10MK x2
Asus BC-12D2HT 3.11MK
LG BH16NS40 flashed to WH16NS60 1.03
LG GGC-H20L 1.03
Pioneer BDR-205 GENE
Vidmo
Post by Vidmo »
1.6.6 fixed the speed (and other issues) I was seeing as well.
LG UH10LS20
Samsung SH-B123L
nicolo69
Post by nicolo69 »
DVD access speed is now better for me. Many thanks.
XP SP3 32bits TDK1616N
