The reason Im asking Is because I heard In a video that manufacturers or
the people who make the optical drives are trying to make it so you cant
change the firmware or something like that. Im thinking of buying the ASUS
BW-16D1HT from amazon will I be able to flash it still?
Can you still flash new drives like ASUS BW-16D1HT
Re: Can you still flash new drives like ASUS BW-16D1HT
yes
whoever made that video is lying we can still flash them
kubuntufan01
Yes you can still flash them.
I flashed the drive successfully but am I missing something? Did me flashing it using the 'enc' just make the drive where it's unlocked and
capable of being flashed with different firmware? I did read the thread on libredrives...what they are etc. Where do I find the 'DE' firmware for my drive?
I also read the thread about windows gui for flashing. I only use Kubuntu which is a fork off Ubuntu distro.
you didnt flash it successfully as you used enc when you should not have do it again without that and it should work.kubuntufan01 wrote: ↑Thu Jan 12, 2023 12:52 am
Yes you can still flash them.I do have a few questions though and I think the thread topic this should be under is locked.
kubuntufan01
user@Node-11:~$ sudo -i
[sudo] password for user:
root@Node-11:~# cd /home/user/
root@Node-11:/home/user# makemkvcon f -v -f sdf_00000096.bin -d /dev/sr0 rawflash -i ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Loaded SDF.bin version 0x96
Reading input file ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Current Drive ID: ASUS_BW-16D1HT_3.10_211901041014_KLZL9PA3508
yes
100% Operation finished
Done successfully
Command produced 0 file(s)
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLZL9PA3508
Bus encryption flags: 1F
Highest AACS version: 18
Firmware version: 3.10
No disc insertedCode: Select all
root@Node-11:/home/user# makemkvcon f -v -f sdf_00000096.bin -d /dev/sr0 rawflash -i DE_ASUS_BW-16D1HT_3.02.bin-
yes now you are good as it says reenabled.kubuntufan01 wrote: ↑Thu Jan 12, 2023 2:17 amThanks!!Code: Select all
user@Node-11:~$ sudo -i [sudo] password for user: root@Node-11:~# cd /home/user/ root@Node-11:/home/user# makemkvcon f -v -f sdf_00000096.bin -d /dev/sr0 rawflash -i ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin Loaded SDF.bin version 0x96 Reading input file ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin Flashing flags = 0x0 : 0 0 0 0 : ---- ---- ---- ---- Current Drive ID: ASUS_BW-16D1HT_3.10_211901041014_KLZL9PA3508 Ready to write drive flash memory. Type "yes" to continue, "no" to abort yes Operation started: Sending flash image to drive 100% Operation finished Operation started: Programming flash 100% Operation finished Done successfully Command produced 0 file(s) root@Node-11:/home/user# Drive Information OS device name: /dev/sr0 Manufacturer: ASUS Product: BW-16D1HT Revision: 3.10 Serial number: KLZL9PA3508 Firmware date: 2119-01-04 10:14 Bus encryption flags: 1F Highest AACS version: 18 LibreDrive Information Status: Enabled Drive platform: MT1959 Firmware type: Patched (microcode access re-enabled) Firmware version: 3.10 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc insertedSo the process would be the same to use the 'DE' firmware?
user@Node-11:~$ sudo -i [sudo] password for user: root@Node-11:~# cd /home/user/ root@Node-11:/home/user# makemkvcon f -v -f sdf_00000096.bin -d /dev/sr0 rawflash -i DE_ASUS_BW-16D1HT_3.02.bin
yes same thing now to go to DE if you wanted but you did have to go to mk first.
