Recovering from read errors in Linux
MrVanx
Re: Recovering from read errors in Linux
#16 Post by MrVanx » Mon Jun 29, 2020 8:18 pm
Rojma wrote: Mon Jun 29, 2020 3:28 pm I strongly recommend you only use isoprophl alcohol to clean the disc. For me using alcohol has resolved almost all read issues I have had with disc read issues. Using other methods suggested around the interwebs, such as liquid hand soap, has actually led to more problems for me.
Yes ive got some 99% isopropyl on its way and some microfibre cloths, I wont let this disc beat me :D
Any tips on how to apply it or just dab onto a cloth?
#17 Post by Woodstock » Mon Jun 29, 2020 10:16 pm
From the "if you are experiencing errors" topic in the BD section:
Proper disc cleaning:
Center to edge, never circular.
How to clean CD/DVD/Blu-ray disks
MrVanx
#18 Post by MrVanx » Tue Jun 30, 2020 4:42 pm
Just a quick update (in case it is helpful for others), Ive been re-running step 2 but I increased the number of retries to 2 or more (i'm working on 4 at the moment) and the bad-sector size is reducing slowly every time which is great.
This is the line I use (for reference):
ddrescue -d -r4 -b2048 /dev/sr0 brimage mapfile
The initial run of step 2 gave me a bad-sector size of 1507KB, I'm now down to 1089KB (the number of bad-areas goes up as explained in the ddrescue manual) I don't think this is important but I eject the disc, close the terminal, put the disc back in and restart a new terminal session each time.
I had another go copying over the files and using the .dat file generated by a non-decrypted backup attempt but the hash check shows up corrupted files again and the title I want to get is still missing from the makemkv screen. I will persist onwards a while longer with ddrescue (It sounds like several days is totally normal for a dodgy disc).
MrVanx
#19 Post by MrVanx » Fri Jul 03, 2020 5:54 pm
OK TLDR: I succeeded in rescuing the disc!
Long version:
ddrescue zoomed through the remaining 1100 or so Kb on the last attempt a couple of days ago so I thought "Wow!". I ran through the remaining steps and unfortunately makemkv was still unable to rip the titles I needed from this one so I gave up temporarily.
The isopropyl didnt seem to make any difference but I will still use it to clean any discs that I have trouble with later.
My suspicion is that the drive didn't kick up a read error but instead gave garbage data (hence the ton of hash check errors in makemkv?), I kicked myself for not making a backup of the mapfile before I ran that last rescue.
For my linux machine I had actually installed ddrescue-gui so I ran that up with the intention of doing another rescue attempt (from the start), I noticed several presets in the settings..one of which reduced the block read size and was labelled "best recovery" so I ran the disc up with that setting and the whole disc was rescued in just under 40m!?!?! (the previous rescue would take ~16hr).
The next step I took was out of necessity rather than anything else, I am running out of HDD space so instead of copying over the BDMV folder to the location of the .dat file I placed soft links to the three top level folders in the mounted disc image (the image just freshly rescued) so I didnt take up the space.
I ran up makemkv via the dat file and VOILA!!! :D Needless to say im a happy chappy, apologies for the thread hijack but I assume this info will be useful for someone down the line, I will be backing the rescue image, dat file and everything else somewhere safe should I need it again!
I have another disc I haven't been able to rip for ages so I will attempt the same process with that one.
Cheers all!
xr200
#20 Post by xr200 » Sun Jul 26, 2020 2:09 pm
lepathi wrote: Fri Jun 19, 2020 12:30 pm Doing this I was able to create an Image of Alita: Battle Angel with "only" 70MB corrupt sectors.
Yet, I am unable to rip the movie with makeMKV due to 342 'HashCheck Errors". Did anybody experience similar and/or has a workaround for me to get that movie ripped?
I'm experiencing the same problem with a different BD. I followed the instructions to the letter, but when I ran makemkv, I got a "hashcheck error".
Just reporting that it's not just you, no suggestions on what to do about it.
hutchinsonhatch
#21 Post by hutchinsonhatch » Sat Aug 07, 2021 7:55 pm
ddrescue -n -b2048  /dev/sr0 brimage mapfile
and in a second (and more) steps
ddrescue -d -r1 -b2048 /dev/sr0 brimage mapfile
is the right way, have patience it needs time...
After the step about mounting the brimage file
 sudo mount -o loop brimage /mnt
and removing the BDMV folder of the backup e.g.
rm  -rvf ~/backup/THE_MATRIX/BDMV
I suggest instead of a
cp -rv /mnt/BDMV ~/backup/THE_MATRIX/
a simple ln -s
ln -s /mnt/BDMV ~/backup/THE_MATRIX/BDMV
because it is all read-only anyway. And it saves time and space (up to 50GB).
Then of course open the *.dat file and proceed with makemkv.
MovieLuver
#22 Post by MovieLuver » Mon Dec 20, 2021 10:39 pm
Start a backup, uncheck the decrypt option. Let it run until it gets to the first m2ts file. At that point, it has saved the disc code, which is a file called "discatt.dat". Stop the backup, quit MakeMKV, [...]
Is there a way to do this from the command line, automatically ? Like not having to manually stop the process ?
babypuncher
#23 Post by babypuncher » Mon Aug 15, 2022 9:07 pm
I've tried this with a 4K disc (Onward) and MakeMKV cannot find the volume key, even though it has no trouble decrypting the actual disc.
Does this just not work with 4K discs?
bamfsf
#24 Post by bamfsf » Wed Nov 23, 2022 2:32 pm
I also had this issue with some 4K discs, but there are a few tweaks I made to my process that helps things work:
  • Don't use an LG drive because their "Jamless Play" feature will often return garbage data instead of indicating that a read failed. I use my ASUS drives for this, though they can behave similar to LG with some firmwares. I think mine have the MK firmware.
  • Always "bless" the disc/drive before running ddrescue using something like
    makemkvcon info disc:0
  • Only use the "discatt.dat" file from the backup.
    Mount the completed ddrescue image:
    sudo mount -o loop disc.img /mnt/bluray
    In the backup directory:
    rm -r AACS BDMV CERTIFICATE
    ln -s /mnt/bluray/AACS "$(pwd)/AACS"
    ln -s /mnt/bluray/BDMV "$(pwd)/BDMV"
    ln -s /mnt/bluray/CERTIFICATE "$(pwd)/CERTIFICATE"
With those changes, I've had success recovering multiple 4K discs with read errors.
nethammer
#25 Post by nethammer » Sat Jun 03, 2023 12:03 pm
Hi Everyone,
I found this thread, trying to recover some Blu-Ray discs I've got which persistently report bad blocks when trying to play or back them up---For example, MakeMKV 1.17.3 fails with bad block errors.
I retrieved the latest version of ddrescue (1.27) and compiled (under Ubuntu Linux). To my amazement, after struggling a while, ddrescue was able to recover the entire Blu-Ray contents, no remaining bad blocks! Fantastic! However, following the procedures found earlier in this thread, MakeMKV doesn't work. It skips all the titles, finally ending with a "Failed to open disc" error.
To diagnose further, I backed up a known-good Blu-Ray (MakeMKV backup, with decrypt video box unchecked) and could read that data using MakeMKV. I also read the raw disc contents with ddrescue. After ddrescue completed, I mounted the resulting ISO file via the loop device and then compared the contents with the files in the MakeMKV backup folder. All files were identical, except for most (but not all) of the .m2ts files in the /BDMV/STREAM folders. Most .m2ts files differ starting at byte 17. What step did I miss? Is this somehow encryption related?
I'm using an LG WH16NS40 drive, flashed with this firmware: HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Powerkey
#26 Post by Powerkey » Fri Mar 22, 2024 6:03 pm
If I have 2 identical discs that both have errors on them (presumably not the same errors) can I do step 2 with the second disc?
Also, I am doing this on macOS and the -d option in step 2 is saying "Direct disc access not available." even though I blessed it with makemkvcon first. If I drop the -d option, does that cause the data to be incorrect?
Rojma
#27 Post by Rojma » Fri Mar 22, 2024 9:44 pm
Powerkey wrote: Fri Mar 22, 2024 6:03 pm If I have 2 identical discs that both have errors on them (presumably not the same errors) can I do step 2 with the second disc?
Yes on the first question. I've done exactly that to get one good whole disc. Can't comment on the second since I don't have a Mac or tried it on a Mac.
Syer10
#28 Post by Syer10 » Tue Oct 29, 2024 1:23 am
This thread saved me, and I was able to recover the disk without any loss to the content.
My disk didn't have any visible scratches to me, but it would always have errors around the 47% mark. During ddrescue the same issues happened, 9 sectors and 400kb of data, and it was able to read the rest of the disk. Then it did a reverse pass(reading the disk backwards) and it was able to get all the missing data without even doing the second step of the guide. I copied it to my main windows machine as brimage.img, mounted it, copied the BDMV folder to the extracted MakeMKV backup and it was fully able to run in MakeMKV.
Thanks for the great guide.
kaysee
#29 Post by kaysee » Fri Dec 20, 2024 2:21 am
MrVanx wrote: Fri Jul 03, 2020 5:54 pm For my linux machine I had actually installed ddrescue-gui so I ran that up with the intention of doing another rescue attempt (from the start), I noticed several presets in the settings..one of which reduced the block read size and was labelled "best recovery" so I ran the disc up with that setting and the whole disc was rescued in just under 40m!?!?! (the previous rescue would take ~16hr).
It is not clear what "reduced the block read size" would mean with ddrescue. Did it use a setting for sector size smaller than the usual 2048 bytes for optical disks? (The commandline flag when working with optical discs is: -b2048.)
The ddrescue manual does not indicate a way to specify block read sizes (how many sectors to read in a chunk), only the software's algorithm that either reads in large blocks or sector-by-sector:
"Only non-tried areas are read in large blocks. Trimming, scraping, and retrying are done sector by sector."
kaysee
#30 Post by kaysee » Fri Dec 20, 2024 6:07 pm
I may have figured out the settings that the user "MrVanx" was using to recover the difficult blu-ray with DDRescue-GUI. And I still do not understand why that worked, since I would expect no difference from using ddrescue via commandline.
DDRescue-GUI manual:
https://www.hamishmb.com/files/support/ ... overy.html
Figure 3.12. DDRescue-GUI's Settings Pre-sets
If you're in a hurry to get started, just click one of these and then save the settings, and it should be fine. If you think your disk is mostly readable, go with "Fastest". If you aren't sure, "Balanced" is a good all-around choice. If you know that your disk is heavily damaged, pick "Best".
https://www.hamishmb.com/files/support/ ... tml#idm417
Number of clusters to copy at a time
On the first pass, you can set how many clusters you want ddrescue to copy at a time. It's ignored on later passes, but it can make the recovery a lot faster or slower, depending on how you set it, and what kind of disk you're recovering from.
Values range from 32 - 256. Mostly, the default of 128 is fine, but if you find it to be slow, you can adjust it. Bigger values are often faster.
DDRescue manual:
https://www.gnu.org/software/ddrescue/m ... anual.html
-c sectors
--cluster-size=sectors
Number of sectors to copy at a time. Defaults to 64 KiB / sector_size. Try smaller values for slow drives. The number of sectors per track (18 or 9) is a good value for floppies.
Note that for optical drives with sector size 2048 B (= 2 kiB), the above-described default cluster size is 32 sectors. So the "Best" recovery that "MrVanx" used in DDRescue-GUI presumably meant a cluster size of 32, which is simply the default that they had already been using with ddrescue all along.
