Buying a drive that is already flashed?
anthonysneed
Post by anthonysneed »
I bought a UHD ultra slim drive that was pre-flashed but it's giving me power issues and I want to see what's out there in terms of drives pre-flashed, and ready to go.
Are there any resources or suggestions for buying a new external drive?
Re: Buying a drive that is already flashed?
Just buy a high powered USB hub if your computers USB ports are not able to supply enough.
https://smile.amazon.com/gp/product/B00 ... VXLJ&psc=1
I do have 1 special drive that will never have power issues but it's very expensive it's a BU40N in a 5.25 external enclosure with a wall plug.
anthonysneed
Billycar11 wrote: Fri Aug 12, 2022 10:48 pm Just buy a high powered USB hub if your computers USB ports are not able to supply enough.
I've got plenty of power, the drive is just not working properly. It doesn't get power unless I push really hard on the enclosure. I'm running a Mac Pro 2019
anthonysneed wrote: Fri Aug 12, 2022 11:36 pm
So the USB port is damaged just buy a new case the vanteck case is the same PCB as the archgon
