I bought a UHD ultra slim drive that was pre-flashed but it's giving me power issues and I want to see what's out there in terms of drives pre-flashed, and ready to go.
Are there any resources or suggestions for buying a new external drive?
Buying a drive that is already flashed?
Re: Buying a drive that is already flashed?
Just buy a high powered USB hub if your computers USB ports are not able to supply enough.
https://smile.amazon.com/gp/product/B00 ... VXLJ&psc=1
I do have 1 special drive that will never have power issues but it's very expensive it's a BU40N in a 5.25 external enclosure with a wall plug.
anthonysneed
I've got plenty of power, the drive is just not working properly. It doesn't get power unless I push really hard on the enclosure. I'm running a Mac Pro 2019Billycar11 wrote: Fri Aug 12, 2022 10:48 pm Just buy a high powered USB hub if your computers USB ports are not able to supply enough.
So the USB port is damaged just buy a new case the vanteck case is the same PCB as the archgonanthonysneed wrote: Fri Aug 12, 2022 11:36 pmI've got plenty of power, the drive is just not working properly. It doesn't get power unless I push really hard on the enclosure. I'm running a Mac Pro 2019Billycar11 wrote: Fri Aug 12, 2022 10:48 pm Just buy a high powered USB hub if your computers USB ports are not able to supply enough.
