I submitted a dump for Heat_3EB6 a couple of days ago. I understand it may take a while.
How can I know that MakeMKV is using the latest sqv file? It used to tell me when it updated the sqv file but I don't see that any more. Using latest version.
Heat 4k; MakeMKV not updating sqv for me?
Re: Heat 4k; MakeMKV not updating sqv for me?
I too have the latest 4k release of "Heat" (1995) from August 9th 2022, and I confirm MakeMKV can't open the disc ...
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: A204
Serial number: KLZL4TA3340
Firmware date: 2119-01-04 10:44
Bus encryption flags: 1F
Highest AACS version: 76
Firmware version: 0.A204W
Disc Information
Label: HEAT
Timestamp: 2021-05-03 16:09:04
Protection: AACS2.0/C v76
Data capacity: 61.65 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Downloading latest HK to C:\Users\****/.MakeMKV ...
Saved AACS dump file as C:\Users\****/.MakeMKV/MKB20_v76_Heat_3EB6.tgz
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: A204
Disc Information
Label: HEAT
Number of layers: 2
Well in your case MakeMKV couldn't update the database.
My problem is that MakeMKV is not downloading the current HK.
Note the missing "Downloading latest HK..."
I checked in Preferences under General and "Enable Internet access" is checked.
MakeMKV v1.17.1 win(x64-release) started
Using LibreDrive mode (v06.3 id=4083C4CCDB14)
Saved AACS dump file as C:/Users/****/.MakeMKV/MKB20_v76_Heat_3EB6.tgz
Failed to open discI checked in Preferences under General and "Enable Internet access" is checked.
Uk version worked from day 1 ?
Same here in US, Amazon preorder if that matters,
Same error, no internet issue. did check both GEOip and my DNS wasn't blocking either. Tried on a separate VPN and same issue, so whoever is getting this ripped, I'd love to know how. I sent in the tgz also.
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Saved AACS dump file as C:\Users\xxxxx/.MakeMKV/MKB20_v76_Heat_3EB6.tgz
I fixed my issue... apparently I had "single drive mode" on. Turned that off and now it's working. oops.
nah that wont cause that the key just updated thats allspaced wrote: Mon Aug 29, 2022 5:24 am I fixed my issue... apparently I had "single drive mode" on. Turned that off and now it's working. oops.
UPDATE : I did retry and it is now working fine for me ! MakeMKV went through Heat's 4K / UHD disc flawlessly.
Thanks !
Thanks !
