Greetings,
I recently flashed a LG BP60NB10 with the LibreDrive firmware list below and MakeMKV still doesn't recognize it as having the correct firmware. I used Terminal in MacOS to do the flash (a lot of trial and error to get it to work but it did show as flashed and have done it multiple times with the same result.) Should I use an older version of the firmware or attempt to flash it from a different computer (older MacOS or PC)?
Firmware:
HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
MakeMKV Notes After Firmware Flash:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03L56G4935
Firmware date: 2120-05-07 09:35
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Thanks for the help!
LG BP60NB10 Flashed with LibreDrive Firmware Still Not Recognized
Captain_Cowtown
Re: LG BP60NB10 Flashed with LibreDrive Firmware Still Not Recognized
You didn't flash it follow the guide.
Or get an automated flasher from me or Marty that will do all the right steps for you.
make sure you use enc in your command as your drive comes with encrypted firmware.Captain_Cowtown wrote: ↑Wed Aug 03, 2022 9:33 pmGreetings,
Firmware:
Revision: 1.02
Captain_Cowtown
Hi, this did the trick!make sure you use enc in your command as your drive comes with encrypted firmware.
Thank you so much!
I have the same drive and I have tried every possible combination but still it doesnt flash it to MK firmware.
would you mind sharing your command line ? or setup ?
I'm on macos, I did it through the terminal, used enc in the commandline, the command reports success, but when recheck the firmware, it is does not change.
I used the firmware:
I thought of trying HL-DT-ST-BD-RE_BP60NB10-NB12-1.02-N000300-212107081556.bin
but I couldnt find it.
any help is appreciated
