Vertigo 4k UHD Only Ripping With Commentary
ETR34
Post by ETR34 » Tue Aug 09, 2022 11:02 pm
Hi, sorry if this is a noob question or not how this works, but I didn't see this covered elsewhere. I have the steelbook Vertigo 4K UHD (I purchased it standalone but it could be the same disc that's in the Alfred Hitchcock Collection) and am ripping with a BU40N, but every time I rip the disc, I only get the main film video file with commentary. I have tried ripping the entire disc, but it only appears to make videos with the commentary. Any help or advice would be appreciated.
AngryVirginian
Re: Vertigo 4k UHD Only Ripping With Commentary
Post by AngryVirginian » Wed Aug 10, 2022 3:01 pm
Media info of the MKV file would help. My guess is that your player cannot play DTS:HD or Dolby TrueHD track and defaulted to the DD stereo commentary track.
Sent from my Pixel 6 Pro using Tapatalk
Post by Woodstock » Wed Aug 10, 2022 6:07 pm
Or the commentary track is the first track in the file. MakeMKV does not NORMALLY flag tracks as "default", but it can... but only the first track found. It depends heavily on how the disk is mastered.
sephirothkefka
Post by sephirothkefka » Thu Aug 11, 2022 1:34 am
I just ripped this disc yesterday and it definitely an issue with OP's player. I recommend the K-lite codec pack myself and MadVR.
ETR34
Post by ETR34 » Fri Aug 12, 2022 9:21 pm
Thank you everyone for the info. Going to try the rip on another player to confirm for myself.
I am sorry for my incredibly dumb question, but where would I find this info so I could share it? Windows 10 operating system if that's info you'd need.
ETR34
Post by ETR34 » Fri Aug 12, 2022 10:26 pm
Thank you everyone for your patience and pointing me in the right directions. Here's the media info it gave me, in case it gives anyone more insight:
General
Format : Matroska
Format version : Version 2
File size : 77.3 GiB
Duration : 2 h 8 min
Overall bit rate mode : Variable
Overall bit rate : 86.1 Mb/s
Movie name : Vertigo
Encoded date : UTC 2022-08-06 17:45:50
Writing application : MakeMKV v1.17.1 win(x64-release)
Writing library : libmakemkv v1.17.1 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 79.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.401
Stream size : 71.6 GiB (93%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 63 cd/m2
Original source medium : Blu-ray
Audio #1
ID in the original source medium : 4352 (0x1100)
Format : DTS XLL X
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 3 188 kb/s
Channel(s) : 8 channels
Channel(s)_Original : Object Based
ChannelLayout_Original : Object Based
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Stream size : 2.86 GiB (4%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
ETR34
Post by ETR34 » Sat Aug 13, 2022 1:46 pm
It was indeed an issue with my player, tried this file and two others I had similar issues with in another player and they all played perfectly. Thank you everyone for helping a newbie figure this out, was starting to think I was crazy.
