Any help or troubleshooting steps would be appreciated.Debug log started at Mon Aug 08 01:21:55 2022 , written by MakeMKV v1.17.1 win(x64-release)
001005:0000 MakeMKV v1.17.1 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Brian/MakeMKV_log.txt
DEBUG: Code 3 at W3_5mn~z2cnbOYW#o~Zq,@E{:29395310
SDF v08d: HL-DT-ST_BD-RE_BU40N_1.00_211612201528_MOBL4T90449
001011:0000 Using LibreDrive mode (v06.3 id=64754CF46FCA)
005055:0000 Evaluation period has expired, shareware functionality unavailable.
005052:0204 Evaluation period has expired. Please purchase an activation key if you've found this application useful. You may still use all free functionality without any restrictions.
001003:0020 DEBUG: Code 0 at y)Ry^8yAV]1;).Da:121263958
001003:0020 DEBUG: Code 0 at y)Ry^8yAV]1;).Da:29395172
001003:0020 DEBUG: Code 233 at GFSlZDT0kBkQhE2GsufNVyyg:0
001003:0020 DEBUG: Code 233 at E5gNk47Stqy1B+vGjWaeX51K:0
BU40N Failed to open disc
I have a BU40N (v1.00, from a known supplier on the forums) that has worked perfectly in the past but now says failed to open disc for all of the various discs that I have tried (a couple different regular Blu-ray and UHD disc). The drive recognizes the discs, it shows the title and the protection type but when I try to access the disc I get the following:
Re: BU40N Failed to open disc
time to buy makekmkv your trial is over
