TV-led on both devices.ArArdin wrote: ↑Thu Aug 04, 2022 8:32 pmPlease correct me if I'm wrong, but this sounds like you're comparing "player-led" modes. Which on itself is fine of course. I've always experienced a nicer image when tonemapping is done by (my) tv. Therefore, I always have "tv-led" mode set.Amused wrote: ↑Thu Aug 04, 2022 6:29 pmCompared to the Sony, the Zidoo appeared to produce a somewhat softer image with less depth and at times too “digital”. The colors were not as vibrant (for example the grass around the hobbits’ houses, as well as fire scenes). The Sony also gives a brighter DoVi image for some reason.
UHD players: Sony X700, Zidoo Z1000 Pro
Audio system: Sony HT-A9
TV: Sony 77A80J
TV: Sony 77A80J
deadchip12
Is there a way to check if the x700 is playing tv led dolby vision instead of play led?Amused wrote: ↑Thu Aug 04, 2022 9:16 pmTV-led on both devices.ArArdin wrote: ↑Thu Aug 04, 2022 8:32 pmPlease correct me if I'm wrong, but this sounds like you're comparing "player-led" modes. Which on itself is fine of course. I've always experienced a nicer image when tonemapping is done by (my) tv. Therefore, I always have "tv-led" mode set.Amused wrote: ↑Thu Aug 04, 2022 6:29 pmCompared to the Sony, the Zidoo appeared to produce a somewhat softer image with less depth and at times too “digital”. The colors were not as vibrant (for example the grass around the hobbits’ houses, as well as fire scenes). The Sony also gives a brighter DoVi image for some reason.
So how big the issue is with the L1 bug on C1+x700 in real content (BD movies)? Is it night and day difference like in the pattern videos? Is the DV on BD still better than HDR10?
I have the Philips HDMI Sync Box between the tv and both players (Sony and Zidoo). The Sync Box synchronizes the lights of different Philips hue products to the image on the screen.deadchip12 wrote: ↑Thu Aug 04, 2022 11:04 pmIs there a way to check if the x700 is playing tv led dolby vision instead of play led?
The Sync Box works with Dolby Vision only if it’s player-led (LLDV). It doesn’t work with TV-led Dolby Vision, unless I switch on the “Dolby Vision Enhanced compatibility” option inside the Sync Box settings. This option basically forces the player to switch to LLDV and then the lights work. So if the Hue lights sync without the DV enhanced compatibility option checked - it’s player-led DV. If they don’t work - it’s TV-led DV.
TV: Sony 77A80J
TV: Sony 77A80J
deadchip12
Does the x700 switch to tv led dolby vision automatically when the tv supports tv led dolby vision? There's no option to switch between tv led and player led on the x700.Amused wrote: ↑Fri Aug 05, 2022 7:02 amI have the Philips HDMI Sync Box between the tv and both players (Sony and Zidoo). The Sync Box synchronizes the lights of different Philips hue products to the image on the screen.deadchip12 wrote: ↑Thu Aug 04, 2022 11:04 pmIs there a way to check if the x700 is playing tv led dolby vision instead of play led?
I think this is precisely the way it works. I believe it will always send TV-led DV (8 bit) if the TV supports it, otherwise it will send LLDV (12 bit). There is no option to switch between player-led and TV-led on the Sony, I think Oppo 203 has this option (as well as the Zidoo players).deadchip12 wrote: ↑Fri Aug 05, 2022 8:46 amDoes the x700 switch to tv led dolby vision automatically when the tv supports tv led dolby vision? There's no option to switch between tv led and player led on the x700.Amused wrote: ↑Fri Aug 05, 2022 7:02 amI have the Philips HDMI Sync Box between the tv and both players (Sony and Zidoo). The Sync Box synchronizes the lights of different Philips hue products to the image on the screen.deadchip12 wrote: ↑Thu Aug 04, 2022 11:04 pm
TV: Sony 77A80J
TV: Sony 77A80J
Do you guys see any difference perceptually with TV led? Or just want it cause it's technically better? I know even if you see something it could be subjective in perception, etc - just curious really. I feel like when I watch a FEL for example the image has more depth to it it seems.
it depends on which player you use. On the x700/x800m2/Shield the L1 and L2 trims are not working at all in LLDV.
ah, so there's obvious stuff missingRESET_9999 wrote: ↑Sat Aug 06, 2022 4:40 pmit depends on which player you use. On the x700/x800m2/Shield the L1 and L2 trims are not working at all in LLDV.
sergonnn111
HI i don t understand how i can drag and drop mkv file doly vision into reset999 scripts i want to do ts file dolby vision i just dont understand sorry for my english
if you want profile 8 DV for TV playback(or any other non-fel device) and your MKV input is profile 7, select: 4-2-1 if you have to convert lossless audio or if not: 4-2-3sergonnn111 wrote: ↑Sat Aug 06, 2022 7:50 pmHI i don t understand how i can drag and drop mkv file doly vision into reset999 scripts i want to do ts file dolby vision i just dont understand sorry for my english
if you want DV playback on x700/x800m2/oppo and your MKV input is profile 7, select: 4-3-2 if you want to convert THD or if not: 4-3-4
There are workflows for when your input is bluray disc as well.
if your MKV input is profile 8 or 5, just remux in tsmuxer.
sergonnn111
yes, my mkv file in 8 profile dolby vision and i did it in last versions of ts muxer and this don t work, i don t know why but Hybrid mkv 8 profile is working in ts muxer and native lg oled player is dolby vision
sergonnn111
my tv is lg oled e8 2018
with tsmuxer file + plex on 2018 LG tv:
1- Audio must be AC3 / EAC3 or DTS,DTSHD. DV won't work if the audio is TrueHD.
2- pgs subtitles must not be selected: only external srt works with DV TS
@RESET_9999 how do I rip a Profile 7 FEL Dolby Vision UHD disc that contains 3 or 4 different videos in it (tv series)? I wish to make separate BluRay folders for each episode in tsmuxer. Thanks
TV: Sony 77A80J
TV: Sony 77A80J
