No Disc Inserted BU40N
Edcasti
Post by Edcasti »
Hi, just bought this this morning, it came with 1.01 out of the box so I flashed it to 1.03nk HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin then over to DE_LG BU40N_1.00.bin using command prompt and making sure enc was included. I have the drive connected directly to my PC (processor an AMD Ryzen 7 3700X 8-Core, GPU RTX 3070) and so far at no point has the disc drive been able to read an UHD, blu-ray or DVD through MakeMKV ver 1.16.5. The disc will spin, MakeMKV will react to the disc drive ejecting or the disc spinning (by saying the disc is being loaded under Disc Information) but will inevitably lead to No Disc Inserted
The drive info is as follows
OS device name: E:
Product: BD-RE BU40N
Revision: 1.00
Serial number: MO2M2QE0517
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
I've tested
The Godfather UHD
Logan Noir UHD
(500) Days of Summer Blu-Ray
Midsommar DVD
Is there anything I might be missing or was I sent a messed up drive out of the box?
