Does anyone have a link for this firmware update? I have the same drive (purchased 2018), and it doesn't read any recent blu-ray discs.corruption wrote: Wed Sep 01, 2021 5:38 pmJust looked up what I used sucessfully:deerewright wrote: Wed Sep 01, 2021 5:05 pmI have the same question. I have tried to flash my ASUS BW-12B1ST with both the ASUS flasher and the SDTool. Neither one seems to work. They both just hang and/or do nothing. What am I missing?Wolfnut88 wrote: Sun Mar 15, 2020 10:27 pm
So i'm looking into updating pic related, i've found firmware 3.11 for it but i'm curious about what you posted. Do i just use the ASUS ODD FW Changer to flash DE-ASUS BW-16D1HT or will i need the official FW? Do i lose any functionalities like disc writing? Thanks.
(Modified) ASUS ODD FW Changer (24.08.2019) + UHD Friendly Firmwares + Latest MK Pack (14.02.2020).zip
ASUS BW-12B1ST
Chews Wisely
Re: ASUS BC-12B1ST
Re: ASUS BW-12B1ST
1st post of the guide has links, etc..
Chews Wisely
Re: ASUS BW-12B1ST
Except for LibreDrive functionality (link below), no particular FW is required for BD. That said, 'the guide' contains links to all available tools/recommended FW/videos, etc for drives, in general.Chews Wisely wrote: Sun Jul 31, 2022 9:35 pmI could use some clarification here, UHD is for 4k discs right?
I only need my Asus BW-12B1ST to read 1080p blu-ray discs.
& you threw me, this being the UHD drive section of the forum. D'oh!
Chews Wisely
Re: ASUS BW-12B1ST
sorry about that, I was just responding to the thread because it deals with the same drive I have, and it doesn't read the latest blu-rays anymore. I can still burn dvd's and cd's though.d00zah wrote: Sun Jul 31, 2022 9:57 pmExcept for LibreDrive functionality (link below), no particular FW is required for BD. That said, 'the guide' contains links to all available tools/recommended FW/videos, etc for drives, in general.Chews Wisely wrote: Sun Jul 31, 2022 9:35 pmI could use some clarification here, UHD is for 4k discs right?
Re: ASUS BW-12B1ST
Based on that description, 2 possibilities come to mind...Chews Wisely wrote: Mon Aug 01, 2022 1:05 am
- BD/UHD uses blue laser. CD/DVD uses red laser. It's conceivable blue died. Has this drive been power cycled (not just a reboot) since this started?
- Host revocation... LibreDrive and AACS
Can you please copy/paste MakeMKV Drive/LibreDrive Info (text can be selected/copied) section here?
Chews Wisely
Re: ASUS BW-12B1ST
Well I didn't realize it was a different laser for dvd/cd. So before I get more involved with this, could you tell me if this newer drive is able to read UHD discs? If so, then i'll just order one right now and be done with it. It costs less than I paid for my Asus drive.d00zah wrote: Mon Aug 01, 2022 1:31 amBased on that description, 2 possibilities come to mind...Chews Wisely wrote: Mon Aug 01, 2022 1:05 am
https://www.amazon.com/WH16NS58DUP-Blu- ... B09GLM1L9C
Re: ASUS BW-12B1ST
Dunno. I would refer to the guide for recommended drives, as things change & Billy tends to keep that 1st post current.
Chews Wisely
Re: ASUS BW-12B1ST
donmentionit
Re: ASUS BW-12B1ST Supported "Yes / No"
Hello and sorry if this is annoying.
I have been looking through the form for quite awhile now and I am finding confusing binary "Yes/No" on wither or not this drive is supported for UHD.
OS device name: E:
Manufacturer: ASUS
Product: BW-12B1ST
Revision: 1.03
Serial number: CBD0CL008579
Bus encryption flags: 1E
Highest AACS version: 66
Disc Information
Label: RESIDENT_EVIL
Timestamp: 2007-11-13 19:52:59
Protection: AACS v4
Data capacity: 44.17 Gb
Disc type: BD-ROM
Number of layers: 2
Can some one help me through the weeds on this one? If it is supported, Where is the BIN file?
OS device name: E:
Manufacturer: ASUS
Product: BW-12B1ST
Revision: 1.03
Disc Information
Protection: AACS v4
Disc type: BD-ROM
Number of layers: 2
Can't tell from that info it likely can do UHD but I can't guarantee it or tell you what to flash you your drive platform is not listed needs to be mt1959Jman9980 wrote: Sat Apr 29, 2023 7:57 pm Hello and sorry if this is annoying.
OS device name: E:
Manufacturer: ASUS
Product: BW-12B1ST
Revision: 1.03
Disc Information
Protection: AACS v4
Disc type: BD-ROM
Number of layers: 2
If it is that follow the Asus fw process to 3.10 mk
Re: ASUS BW-12B1ST
Thank you for the fast reply. How do I find mt1959? Is it on the drive label?
jhunter844
Re: ASUS BW-12B1ST
I had two of the BW-12B1ST
One that was much older and the other one I purchased maybe 4 or 5 years ago. Anyway I was able to have that crossflash and now it works fine for UHDs or appears too...don't have an abundance of media to try yet. Tested with one uhd thus far and worked fine.
The other one wouldn't even try too as the software said it did not have mt1959 that it was looking for.
