Thanks! I tried to mux the 3 files afterwards (BL, EL and audio), but txmuxer failed to complete the job. Multiple hours lost unfortunately.RESET_9999 wrote: Fri Jul 29, 2022 11:05 amthats just "the script has completed" popup msg that didnt work. you can ignore that.Amused wrote: Fri Jul 29, 2022 7:52 am Thanks! I went through the lengthy process but got an error at the end. Any suggestions?
I have one more question, when I try to watch a DV FEL movie through a full BD structure - BDMV folder - Stream folder (ripped through MakeMKV, placed in the root folder of an external HDD, played on the Sony X700), the video and audio play fine, I can use FF-RW etc. However, when I hit the “display” button on the X700 remote, it reports only HDR, whereas the tv reports it’s getting Dolby Vision. Looks to me as if the X700 player is only getting HDR10 and then injecting DV metadata and sending it like that to the tv.
Is there something I’m doing wrong here?
Many thanks!
