Is there a way to open a directory w/ GUI?
beandog
#1 Post by beandog » Sat Jul 30, 2022 6:09 am
If there is, I'm not seeing it.
Context, I did a backup of a 4K to a directory, would like to just extract some of the titles from that.
Re: Is there a way to open a directory w/ GUI?
#2 Post by Billycar11 » Sat Jul 30, 2022 6:49 am
file> open files > movie name > BDMV> open index
beandog
#3 Post by beandog » Sun Jul 31, 2022 1:45 am
Oh wow, that worked, I never would have thought to try that! Thanks!!
SmartOne_2000
#4 Post by SmartOne_2000 » Tue Aug 02, 2022 7:58 pm
Hey Billy ... first of all, thank you for the UHD friendly player I recieved this past saturday from you. Seems to work fine as far as I can tell. Its just that my VLC skills are somewhat limited for now.
I posted earlier from "How to play 4K UHD ripped movies using VLC". I followed the advice above, opened the index.bdmv file and nothing happens. VLC just sits there as though nothing has happened. What am I doing wrong? Thanks!
#5 Post by Billycar11 » Tue Aug 02, 2022 11:48 pm
SmartOne_2000 wrote: Tue Aug 02, 2022 7:58 pm Hey Billy ... first of all, thank you for the UHD friendly player I recieved this past saturday from you. Seems to work fine as far as I can tell. Its just that my VLC skills are somewhat limited for now.
Already answered in email but for public use
To open it in VLC do open disc and select bluray then find the folder and open it.
and also make sure you have checked the decrypt box in the folder backup
