1.17.1 64bit linux
This will not rip. It stops and says 0 titles saved. What other info should I post?
This is playing fine with MPV and libdvdcss.
The Lost City w/Sandra Bullock does not rip but MPV with libdvdcss plays it.
Re: The Lost City w/Sandra Bullock does not rip but MPV with libdvdcss plays it.
What's in your MakeMKV log file? Or in the bottom of the window?
Desanitized log attached.
I found out I have to uncheck the CC boxes. I've not figured out which one causes this. I do not have ccextractor installed but that has not mattered in the past. The movie seems to play fine but I didn't watch all of it. For all of that work to get to watch it it might as well be a DeadBox original.
- MakeMKV_log.txt
- (66.87 KiB) Downloaded 305 times
005014:0000 Saving 1 titles into directory file:///home/blastocyst/Videos/THE_LOST_CITY
001003:0020 DEBUG: Code 0 at U-t>s&5ks03! B25%:213130237
CCX001: Launching /usr/bin/ccextractor
001003:0020 DEBUG: Code 2 at E}t,*AjiVg.}u\kX*geF:29394436
004041:0000 Failed to execute external program 'ccextractor' from location '/usr/bin/ccextractor'
001003:0020 DEBUG: Code 0 at oSZes9XjB}DA3}w&UAU'\:121261957
001003:0020 DEBUG: Code 0 at @FazU7:Afwilt'{|:121264533
001003:0020 DEBUG: Code 0 at a:)+=%,nM|N5QDa[{>py:121261773
001003:0020 DEBUG: Code 0 at c&c#(HhO<GzLb3LkDpLRg:213137068
---- Failed /home/blastocyst/Videos/THE_LOST_CITY/C1_t00.mkv
