yes you can take the largest m2ts or the mpls file corresponding the to the main movie. You can find the right playlist with the script (MODE.M ===> MODE.4).Amused wrote: Fri Jul 29, 2022 11:39 am As for BDMV, do you mean to import the main m2ts file from the BDMV/Stream folder and then remux it in tsmuxer back to BDMV? If yes, which output should I select in tsmuxer: Bue Ray folder or AVCHD folder?
select "bluray folder" as output.
