Blu-ray won't rip.
Joshthedemongod
Blu-ray won't rip.
Post by Joshthedemongod » Thu Jul 28, 2022 9:10 pm
Halloween Kills bluray wont rip.
Re: Blu-ray won't rip.
Post by Woodstock » Fri Jul 29, 2022 1:47 am
And you sent the TGZ generated?
Joshthedemongod
Post by Joshthedemongod » Fri Aug 05, 2022 11:56 pm
Exactly what is a TGZ.
Post by Woodstock » Sat Aug 06, 2022 1:06 am
The type file created when MakeMKV can't figure out what to do with your disk. It will have the name of the disk and some characters at the end, and it gets forwarded to svq@makemkv.com so that it can be processed into what is needed to decode the disk contents.
Your rip attempt should have given you the path to it, so that you could forward it to the author.
Post by dcoke22 » Tue Aug 16, 2022 12:53 pm
There usually aren't .tgz files with regular blu-rays, only with UHDs. Presumably the OP had some other issue trying to rip the disc.
