Green Lantern Beware My Power - Volume Key Unknown
stricq
#1 Post by stricq » Thu Jul 28, 2022 10:36 pm
Trying to rip this movie but the volume key is unknown. I submitted the tgz file several days ago, but it still won't decrypt.
Do I need to do anything more?
Re: Green Lantern Beware My Power - Volume Key Unknown
#2 Post by Woodstock » Fri Jul 29, 2022 1:49 am
You do have to have reading from the web turned on, for when the key is generated. You did this, correct?
stricq
#3 Post by stricq » Fri Jul 29, 2022 4:16 am
Yes.
stricq
#4 Post by stricq » Sat Jul 30, 2022 4:56 am
Yay! It finally updated.
PrimalNaCl
#5 Post by PrimalNaCl » Sun Aug 14, 2022 8:12 pm
I got this disc, found the volume key unknown issue, sent the dump file, and heard nothing. Periodic checking never resolved it. So I find this posting.
What is the 'magic' for getting it to actually pull down the HK file? It keeps telling me that:
The only setting I can find that _might_ be relevant is View -> Preferences -> General -> Online updates -> Enable Internet access ... which I have always had checked .
So wtfo?!
#6 Post by Woodstock » Sun Aug 14, 2022 8:31 pm
That means something is interfering with your download. Since it has been "a while" since you started trying, it is likely a system setting that is preventing the host from being accessed. This is much more prevalent when you have 1.1.1.1 as one of your name resolution hosts, which is weird, considering this site uses their services...
Google name resolution seems to work better for a lot of things. They use 8.8.8.8 and 8.8.4.4 for name resolution, and do not seem to be likely to block as many names from being resolved.
PrimalNaCl
#7 Post by PrimalNaCl » Sun Aug 14, 2022 9:14 pm
Woodstock wrote: Sun Aug 14, 2022 8:31 pm
2 things:
0) I have only ever used google's dns servers since they have been around to be used.
1) I can get the sdf.bin or sdf.dat.gz files manually w/curl from the same box.
Further, there are no issues w/perms. The datadir for my user has FULL perms. I have even gone so far as to use a different datadir and bounce MakeMKV. The first thing it does is to download the _private_data.tar. So it's able to get data from the internet via some means. And even if I manually curl down the sdf.bin and sdf.data.gz, I still get:
MakeMKV v1.17.1 win(x64-release) started
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Downloading latest HK to C:/MKVDATADIR ...
Saved AACS dump file as C:/MKVDATADIR/MKB20_v76_DC_Universe_Movie_Green_Lantern-_Beware_My_Power_8DE6.tgz
Why is this process fragile af?
#8 Post by Billycar11 » Mon Aug 15, 2022 12:13 am
PrimalNaCl wrote: Sun Aug 14, 2022 9:14 pm
2 things:
well actually the servers seem to be down today as im getting the fail message too just started testing some drives
#9 Post by MartyMcNuts » Mon Aug 15, 2022 3:43 am
Billycar11 wrote: Mon Aug 15, 2022 12:13 am
2 things:
Yep, I'm getting the HK is disabled or failed message too.... Perhaps @mike admin can chime in??
planedrop
#10 Post by planedrop » Mon Aug 15, 2022 4:41 am
FYI also seeing this today with any discs that I have, so seems to still be down. Bad timing since I just started up my rip machine again lol (as in I thought something of mine was causing the issue but everything is whitelisted).
Hopefully things are back up soon though.
chuckthetekkie
#11 Post by chuckthetekkie » Mon Aug 15, 2022 5:55 am
I'm getting that error too. Is there a way to get the new HK file and install it manually?
#12 Post by Billycar11 » Mon Aug 15, 2022 12:41 pm
chuckthetekkie wrote: Mon Aug 15, 2022 5:55 am I'm getting that error too. Is there a way to get the new HK file and install it manually?
Yes but it's not official and I'm debating removing it. Until I know further info
gtrogue
#13 Post by gtrogue » Mon Aug 15, 2022 2:22 pm
It isn't a configuration setting. I have the same problem with all 4K discs. The server has to be down or have some configuration issue. I've tried in two different locations with different network configs and with my firewall completely disabled. Besides, everything was working fine and nothing on my network has changed.
or8ital
#14 Post by or8ital » Mon Aug 15, 2022 6:39 pm
Getting same error
planedrop
#15 Post by planedrop » Mon Aug 15, 2022 8:26 pm
gtrogue wrote: Mon Aug 15, 2022 2:22 pm
Just figured I would chime in here with some info as well.
I did some packet captures and was able to verify DNS is getting the response it should on the machine I have with MakeMKV installed. The server it is trying to contact also WILL reply to pings, so it's not entirely down but something is configured wrong, at least that would be my best guess.
