purchased Itunes movies and make mkv
pasjk
#1 Post by pasjk » Tue Mar 29, 2011 12:27 pm
Will make MakemKv work on ITunes purchased movies so they can be converted to a burnable format?
Thanks.
skittle
Re: purchased Itunes movies and make mkv
#2 Post by skittle » Tue Mar 29, 2011 1:52 pm
Not out of the box, but install something like xbmc on your appletv2 to enable mkv playback.
Romansh
#3 Post by Romansh » Wed Mar 30, 2011 8:46 pm
skittle wrote:Not out of the box, but install something like xbmc on your appletv2 to enable mkv playback.
That's not the question.
pasjk:
1) MakeMKV only supports DVD, HD-DVD and Blu-Ray sources, not movie files, whether they are sourced from iTunes or elsewhere.
2) iTunes Store movies are not burnable because they're encrypted.
pasjk
#4 Post by pasjk » Wed Mar 30, 2011 10:46 pm
Thank you.
Although the previous answer did help to discover what I was inadvertently looking for concerning ATV2.
