Multi-drive USB enclosures?
samoht
Post by samoht »
Sorry if this is the wrong board to post this question on.
I have a blu-ray drive and 2x dvd drives (5.25") that I use for MakeMKV (will hopefully get a UHD soon too).
They are currently connected via sata.
Are there any multi-drive USB enclosures available 2/3/4 drives? I'm hoping to build my next PC in a smaller case and would like the drives to be in a USB enclosure so that I can connect them only when required.
Re: Multi-drive USB enclosures?
Never seen one that is USB they are usually standalone cloners that type of thing
And it's becoming less and less popular
samoht
Post by samoht »
I've seen that you sell slimline UHD drives (I think you only sell to US though - I am in the UK) and one of those plus some DVD only drives (a lot of my media is older TV shows that are DVD only) would probably be suitable alternatives with a USB hub.
Is there a list of good quality slimline USB DVD only drives that are compatible with LibreDrive?
samoht wrote:
Tue Jul 26, 2022 11:13 am
Don't know of a DVD one I can recommend I don't test them like the bluray drives.
But libre drive does nothing for DVD so that should not even be a factor.
Asmcom is in the UK and can help you out if you want preflashed and tested drives viewtopic.php?f=20&t=19387
Also be careful with USB hubs optical drive take a lot of power even the best 60watt hubs can only do 6 drives reliably because of spikes it should be a lot more but everything is junk. you can get drop outs and then they all disconnect and your progress is ruined
