ragico
Post by ragico » Sun Jul 24, 2022 5:19 pm
Tested cmv29 and cmv40 compatible with Apple TV 4k:
Tested on Lg CX 48" and on Panasonic JZ1000 55".
CMV29
CX internal player and Apple TV connected to CX (same results)
L1 ok
L2 ok (L2 saturation gain and ms weight better on Apple TV)
Panasonic internal player and Atv connected to it, same results as CX
CMV40
CX internal player and Apple Tv connected to CX (same results)
L1 ok
L2 no
L3 min pq offset=no
L3 max pq offset=ok
L8 Ok with exceptions:
ms weight, saturation vector trim 0/1/2/3/4/5 and hue vector field 0/1/2/3/4/5 NO
Post by RESET_9999 » Sun Jul 24, 2022 5:41 pm
I had a closer look at my C8 now that it's back in the pitch black room and there's also an L1 difference between the x700 and C8 internal player. It's just less obvious and not a night and day difference like on the C2 + x700.
I also tried the Shield + C8 and there's no L1 difference with the TV internal player.
So maybe that bug was always there and because the C2 is much brighter than the C8 now it's just more obvious???
DiscoD
Post by DiscoD » Sun Jul 24, 2022 10:46 pm
Just so we have more data on all playback devices tried the cmv40 File on my Chromecast with Google TV (TV is Vizio m65-F0)
L1 - Good
L2 - Good
L3 - No Reaction at all
L8 - No Reaction at all
might as well get as much data as possible.
sw5163
Post by sw5163 » Sun Jul 24, 2022 11:18 pm
RESET_9999 wrote: Sun Jul 24, 2022 5:41 pm
Have you guys ever tested convert those p8 to p7 MEL?
It seems only FEL compatible disc players are affected.
Would it be possible these deivices never expect P8 DV and their DV engine always assume there is an EL and treat them like P7?
ragico wrote: Sun Jul 24, 2022 5:19 pm L2 ok (L2 saturation gain and ms weight better on Apple TV)
That is strange, proper developed internal player should always have more accurate image than external.
Those engineers who built the TV have a much better grasp of the TV specs, therefore should be able to fine tune it.
deadchip12
Post by deadchip12 » Sun Jul 24, 2022 11:59 pm
RESET_9999 wrote: Sun Jul 24, 2022 5:41 pm I had a closer look at my C8 now that it's back in the pitch black room and there's also an L1 difference between the x700 and C8 internal player.
What is the difference you saw?
Post by RESET_9999 » Mon Jul 25, 2022 1:24 am
deadchip12 wrote: Sun Jul 24, 2022 11:59 pm What is the difference you saw?
the light changes are slightly brighter on the internal C8 compared to the x700/x800m2.
Not as drastic as on the x700/x800m2 + C2 combo and that's why I didn't really spot it when the C8 was in a brighter room but now in a pitch-black room, I can definitely see a difference.
deadchip12
Post by deadchip12 » Mon Jul 25, 2022 2:11 am
RESET_9999 wrote: Mon Jul 25, 2022 1:24 am
If I go to the General>About This TV>TV Information and scroll down to Dolby Vision, it says 21.26 there. What does it say on your C2 and C8?
Are there any more tests that I can do? In the last few pages, it seems there are several test videos, quite confusing. Which one should I use?
chros
Post by chros » Mon Jul 25, 2022 10:17 am
deadchip12 wrote: Mon Jul 25, 2022 2:11 am If I go to the General>About This TV>TV Information and scroll down to Dolby Vision, it says 21.26 there. What does it say on your C2 and C8?
DoVi version on the G2 is (fw 3.11.35): 31.18
I uploaded the DoVi trim test files (mkv/mp4/ts) into one place (including the latest correct cmv2.9 ones):
https://mega.nz/folder/ehUWVChK#KmxRwARyFogmMWz4nkU6Kg
Yesterday I checked couple of DoVi things:
- internal player (Plex/Jellifyn) is definitely brighter than HDMI devices (Oppo and Shield as well!) with the same files: not just the mid part but also shadow details as well, not sure why
I thought maybe the 1dlut is different, but I used the same settings and the same preset, so the 1dlut should be the same.
I thought maybe Limited/Full (Black level) was the reason, but setting internal players to Full (with bscpylgtv, obviously) we get washed out colors, so that's not that; interestingly this setting didn't have any effect with HDMI devices using DoVi content.
So, not sure what's going on or how this can happen.
Setting AI Picture Pro for Internal players helps a bit to make them similar.
I also checked couple of shows:
Stranger Things s3e2 Plex vs Netflix (both internal): looked the same
Dickinson s3s4 Plex vs Atv (both internal): Atv was darker (this can be because of the metadata in the mp4 file)
So, who knows which are the correct ones :)
deadchip12
Post by deadchip12 » Mon Jul 25, 2022 1:31 pm
chros wrote: Mon Jul 25, 2022 10:17 am DoVi version on the G2 is (fw 3.11.35): 31.18
Just quickly tested all 3 files on my C9:
1) DoVi_L1_test_high_brightness_ojA5.ts
Internal player & X700 seem to behave the same
2) RPU p8.1 L1.L2_cmv29-ojmX.ts
Internal player: Noticeable changes with L1 & L2, especially big change with L2 trim_offset 0.75 where the picture looks very wrong - overly bright and oversaturated
X700: Small changes with L1, noticeable changes with L2, except no change with L2 trim_offset 0.75
3) RPU p8.1 L1.L2.L3.L8_cmv40_test.ts
Internal player: Noticeable changes with L1, L3 & L8, no changes with L2
X700: Small changes with L1, noticeable changes with L2, no changes with L3 & L8
So what do I make of this :shock:
sofakng
Post by sofakng » Mon Jul 25, 2022 5:51 pm
I don't want to change the subject, but can I ask a quick question?
Is it possible to convert a DV MEL UHD (dvhe.07.06) to DV 8.0 (or is it 8.1) without any loss of quality?
I'm trying to convert my rip of The Matrix (1999) which MediaInfo reports the following:
Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
dwalme
Post by dwalme » Mon Jul 25, 2022 6:58 pm
sofakng wrote: Mon Jul 25, 2022 5:51 pm I don't want to change the subject, but can I ask a quick question?
Yes. Start with options 1 => 7 => 2 and then select the option that matches the type of audio processing you need.
Post by RESET_9999 » Wed Jul 27, 2022 3:45 am
not sure if it's related but it seems the C2 internal player and Shield clip more with 1000nits DV content than the C8 internal player and x800m2. But with the 4000nits pattern and 1000nits HDR10, The C2 internal seems fine .
1000nits C2 DV vs HDR10 vs DV x800m2:
https://slow.pics/c/NUzspwhM
4000nits C2 DV vs C2 HDR10:
https://slow.pics/c/RG9UMJET
*don't judge the colors, I took those pictures with my phone. I didn't check the 4000nits pattern on my x800m2. I will tomorrow.
1000nits pattern:https://drive.google.com/file/d/1wYbmD8 ... sp=sharing
4000nits pattern:https://drive.google.com/file/d/1foRyXE ... sp=sharing
1000nits DV C8 (left) and C2(right) side by side:
off topic...
did a couple of C8 vs C2 DV comparisons:
Spears and Munsil (10 000nits):https://drive.google.com/file/d/1JWtiLc ... sp=sharing
21 jump street (scene =500nits):https://drive.google.com/file/d/11QAedS ... sp=sharing
Doctor Strange (scene=1200nits):https://drive.google.com/file/d/1kWkKpM ... sp=sharing
Power rangers(scene =600nits):https://drive.google.com/file/d/1pM7rT5 ... sp=sharing
L1-L2 test:https://drive.google.com/file/d/1tSSr2W ... sp=sharing
deadchip12
Post by deadchip12 » Wed Jul 27, 2022 4:10 am
RESET_9999 wrote: Wed Jul 27, 2022 3:45 am not sure if it's related but it seems the C2 internal player and Shield clip more with 1000nits DV content than the C8 internal player and x800m2. But with the 4000nits pattern and 1000nits HDR10, The C2 internal seems fine .
off topic...
So after all these testings is there a consensus on which player is the most accurate?
Post by RESET_9999 » Wed Jul 27, 2022 4:14 am
deadchip12 wrote: Wed Jul 27, 2022 4:10 am So after all these testings is there a consensus on which player is the most accurate?
oh boy I don't know and with those comparisons, I'm now more uncertain than ever lol
sw5163
Post by sw5163 » Wed Jul 27, 2022 11:00 am
sw5163 wrote: Sun Jul 24, 2022 11:18 pm
Although it’s highly unlikely, but please give p7 MEL a test to rule out some possibility.
