Edge of Tomorrow UHD
The_FireBird
Post by The_FireBird » Sun Jul 24, 2022 6:48 pm
Hi, as I try this disc, I get hundreds of these errors (DEBUG: Code 3221225664 at U5PW&tql`c>RT]\::121267362) after 31GB with:
Fehler 'Betriebssystemfehler - STATUS_DEVICE_NOT_CONNECTED' trat auf während des Auslesens von '/BDMV/STREAM/00018.m2ts' bei Offset '37072269312'
Fehler 'Betriebssystemfehler - Ein nicht vorhandenes Gerät wurde angegeben' trat auf während des Auslesens von '\Device\CdRom1' bei Offset '37072269312'
DEBUG: Code 3221225486 at qfmN#a{sFwgf"zj2mo:213131502
DEBUG: Code 3221225629 at qfmN#a{sFwgf"zj2mo:213131502
DEBUG: Code 0 at ^Qjq;+-!?d/:>aLz.mj):29395471
DEBUG: Code 0 at @6''E8Sm7NY#fCx<#H`$:29394068
DEBUG: Code 0 at ^Qjq;+-!?d/:>aLz.mj):213131157
DEBUG: Code 0 at ^Qjq;+-!?d/:>aLz.mj):121262647
DEBUG: Code 18101694 at ^Qjq;+-!?d/:>aLz.mj):121261773
DEBUG: Code 0 at fRe7Tf.X>q:*CJ*_~hmr?:213137068
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Titel 0 in Datei C:/Users/..../SEG FPL_MainFeature_t00.mkv zu speichern schlug fehl
0 Titel wurden gesichert, 1 schlugen fehl
Thank you for help. I have version 1.17.1
Re: Edge of Tomorrow UHD
Post by Woodstock » Mon Jul 25, 2022 12:31 am
Most likely your drive is trying to go faster than the power you have it connected to will allow it. As it speeds up, it requires more power, and your drive gives up when it reaches the limits of available power.
You either have to slow down the transfer by writing to a device slower than you can rip the disk at, or provide enough power for the drive to run full-speed.
midnighwatcher
Post by midnighwatcher » Thu Jul 28, 2022 5:54 pm
If an external USB drive, connect both USB connections.
The_FireBird
Post by The_FireBird » Sun Jul 31, 2022 6:56 am
Mhh, this is the first UHD since 2 years I had problems with.
It is a external drive with one USB 3.1 and I put, as always, to my USB 3.1 at the computer. I try also differnt ports - the result remains the same (unfortunately).
Any other ideas?
midnighwatcher
Post by midnighwatcher » Tue Aug 02, 2022 3:46 am
Can you do a full disc backup? If yes, try ripping the backup.
The_FireBird
Post by The_FireBird » Tue Aug 02, 2022 8:23 pm
Can you discribe how this work in detail please?
Post by dcoke22 » Thu Aug 04, 2022 3:34 pm
Making a backup of a disc with MakeMKV is as simple as clicking the 'backup' button instead of opening a disc in the usual way.
viewtopic.php?f=1&t=16405
That link has a picture with the backup button labeled.
Is your external drive powered by USB? Or does it have its own power supply?
The_FireBird
Post by The_FireBird » Sat Aug 06, 2022 8:48 pm
No, is not working (both options)
Yes, with USB 3.1. I do only have one USB-Port and no power supply.
As I say, this is the first disk of around 100 I have problems with.
The_FireBird
Post by The_FireBird » Sat Aug 20, 2022 9:05 pm
I send disc back, get a new one - now it works like ever ;)
lfoust
Post by lfoust » Thu Aug 25, 2022 3:42 pm
I was able to successfully rip my copy and here is how the contents laid out: https://thediscdb.com/movie/edge-of-tom ... es/2022-4k
