"Failed to install CdRom Device Arbiter service"
bentobox34
#1 Post by bentobox34 » Fri Dec 13, 2019 6:06 pm
When installing, at the end of the process I get the error message above. After, MakeMKV does not run.
This is probably the 6th or 7th device I've installed MakeMKV on and I've never seen this error before. I didn't see this directly addressed in the forums or on google. Help?
TrevorK
Re: "Failed to install CdRom Device Arbiter service"
#2 Post by TrevorK » Fri Jul 01, 2022 4:55 am
I installed MakeMKV for the very first time yesterday and received "Failed to install CdRom Device Arbiter Service".
I note I have a fast and powerful recently built Windows 11 desktop pc so hardware is good.
MakeMKV runs ok and I made several attempts to copy Blu-ray movies. One I produced with menus using Pinnacle Studio, others were commercial movies.
All appears to work however menus got stripped out, and the movies stops after just after a minutes and the quality of the video played stutters in places,
I commercial movie produced 12 titles - not a good result.
So I joined this forum hoping to find answers, but not so far. Will keep looking.
koitsu
#3 Post by koitsu » Mon Jul 04, 2022 12:39 am
For what it's worth: same here.
I suspect version 1.17.0's installer contains a bug, where some part of the installation process *assumes* you have enabled/checked (during installation) the "CdRom Device Arbiter service".
I explicitly *uncheck* this option during installation (and always have; I've never found a need for it (program functions fine on Windows 7 SP1 64-bit without it), and I was unable to find clear documentation on what it does anyway. I just know I do not need another service running somewhere that is enumerating devices or fooling around with stuff behind the scenes.)
I've never seen this error dialog up until now.
redwine
#4 Post by redwine » Tue Jul 05, 2022 12:10 pm
Encounter the same "Failed to install CdRom Device Arbiter Service" twice when i try to install v1.17.
On my 3rd attempts , no error occur during installation.
But when i start the application, encounter makemkvcon64.exe crashed.
Using Win7 SP1 x64.
Rgds
koitsu
#5 Post by koitsu » Thu Jul 21, 2022 8:00 pm
Problem still exists as of 1.17.1.
#6 Post by mike admin » Sat Jul 23, 2022 7:36 am
This is a harmless bug in 1.17.0 and 1.17.1 . Program outputs this message when one chooses NOT to install WinCdArb service. The installer runs a certain script that fails and gives this error message. In this case the script does effectively nothing.
Here is what it does - https://www.makemkv.com/wincdarb/
leosantare
#7 Post by leosantare » Sun Jul 24, 2022 1:59 am
I just went to install the current makemkv version today with the the cdrom device arbiter checked, and it failed to install the cdrom device arbiter?
leosantare
#8 Post by leosantare » Sun Jul 24, 2022 10:34 pm
Is there a way in install a previous version of makeMKV without this issue, or do I have to wait until a new version is released?
#9 Post by mike admin » Tue Jul 26, 2022 10:09 am
This is a wrong installer message. Message only. The action (to install or not to install) is always performed correctly, only a wrong error message pops up. Just click OK and forget about it.
