quietvoid
#7021 Post by quietvoid » Fri Jul 22, 2022 11:35 pm
RESET_9999 wrote: Fri Jul 22, 2022 10:58 pm but the SM clip I did with madvr is 10 000nits and the L1 still doesnt work properly. Did you try it on your firestick?
and why the shield is not affected?
The "RPU.out.of.sync.p8 (madvr generated, no L2).ts" clip works fine on the stick, the changes are noticeable.
I just tested playing with MDL and it seems that tone mapping targets "source_max_pq" when there's no L1, but otherwise L6 makes no difference.
quietvoid
#7022 Post by quietvoid » Fri Jul 22, 2022 11:46 pm
PS: There's a bug with the latest 1000 nits trim metadata test file, where the CM v2.9 version has the first 3 seconds with CM v4.0 metadata instead.
This is a revision: https://0x0.st/ojmX.mkv, but it made no difference for me at least.
#7023 Post by RESET_9999 » Fri Jul 22, 2022 11:47 pm
quietvoid wrote: Fri Jul 22, 2022 11:35 pm The "RPU.out.of.sync.p8 (madvr generated, no L2).ts" clip works fine on the stick, the changes are noticeable.
Well I guess the firestick is not affected by this bug because it's night and day the difference on the x800 + C2 ( EG the horse scene) but yes, some luminance change looks similar.
quietvoid wrote: Fri Jul 22, 2022 11:46 pm PS: There's a bug with the latest 1000 nits trim metadata test file, where the CM v2.9 version has the first 3 seconds with CM v4.0 metadata instead.
thanks , will try
#7024 Post by RESET_9999 » Fri Jul 22, 2022 11:54 pm
yep as soon as L1 is alone, big difference.
https://slow.pics/c/uF3dr3YN
DSLR camera settings locked
quietvoid
#7025 Post by quietvoid » Fri Jul 22, 2022 11:59 pm
RESET_9999 wrote: Fri Jul 22, 2022 11:54 pm yep as soon as L1 is alone, big difference.
So it doesn't react when there's L2 present only?
The TV only looks dimmer in the photos, but the clipping is the same..
That's weird. The L2 is all set to 2048, though. I think usually real metadata has one of them at like 2049.
I doubt it would work, though.
Another thing might be that there's L2 up to 4000 nits, so maybe that does something too.
#7026 Post by RESET_9999 » Sat Jul 23, 2022 12:08 am
quietvoid wrote: Fri Jul 22, 2022 11:59 pm So it doesn't react when there's L2 present only?
There's a big different too when l2 is present but I think it's not as obvious as in the L1(no L2) scene. or maybe im dreaming
with the internal player, the L1 (no L2) scene is a lot brighter and more clipped than the x800m2. Roughly the same difference as in your first 1000nits pattern.
quietvoid
#7027 Post by quietvoid » Sat Jul 23, 2022 12:27 am
RESET_9999 wrote: Sat Jul 23, 2022 12:08 am There's a big different too when l2 is present but I think it's not as obvious as in the L1(no L2) scene. or maybe im dreaming
Okay, I don't really understand what the issue is anymore.
I thought there was little visible change on the Blu-ray player. Now it sounds more like the TV is just brighter.
I can't easily judge the brightness by eye, but the C2 does clip more than the FireTV Stick 4K Max for me.
The stick shows more blue at the edges of the water splash, while the TV internal player is almost just white.
So the TV is probably brighter too.
To me this isn't a significant issue, as I've always assumed the internal player to be brighter and "more accurate".
#7028 Post by RESET_9999 » Sat Jul 23, 2022 12:33 am
could you re-do the first 1000nits pattern with only one 600nits trim set to 2048 for the L1 scenes?
maybe it just doesnt work properly when L1 is alone (which is very rare in UHD-BD)
edit: scratch that, i just checked your file and it has l2
#7029 Post by RESET_9999 » Sat Jul 23, 2022 12:42 am
quietvoid wrote: Sat Jul 23, 2022 12:27 am
I dont think we can say that one is better than the other with your patterns because you're just sending extreme value to some random 10 000 or 1000 image.
to me, this just shows that there's a difference and that one is incorrect. The real test is with real content, or madvr pixel measurements.
1- the shield behave exactly the same as the internal tv
2- same player same file behave the same on the C8
3-The CX is not affected.
it just doesnt add up
chros
#7030 Post by chros » Sat Jul 23, 2022 11:58 am
Poker354 wrote: Fri Jul 22, 2022 11:27 pm
RESET_9999 wrote: Fri Jul 22, 2022 10:43 am
Poker354 wrote: Fri Jul 22, 2022 3:52 am I’m not sure I’m experiencing this bug. LG CX with Sony X700 and Shield Pro 2019. Testing the videos back and forth (ts on Sony and mp4 on Shield) I could easily see the changes on both. The shield might look slightly better but I easily see them as well on the x700.
yep, CX looks ok. lucky you
please try the cmv4.0 version on your Shield(or TV internal player) and tell us if you get L8 reaction.
https://drive.google.com/file/d/1tU3VLC ... sp=sharing
Both the Shield and TV show strong reaction in the L8 in the trims, chroma weight, saturation, clip trim, I don’t really notice anything happening in the vector fields.
Thanks for checking, so the CX is not affected that also has cmv4.0!
RESET_9999 wrote: Fri Jul 22, 2022 10:50 pm interestingly and kind of a good news, @manix said he got an L8 response on his CX and no L1 bug on the x700... mmm
so there's something going on with the C1/C2
That's a good news indeed! Meaning they (probably Dolby) screwed up something in the DoVi engine on C1/C2!
RESET_9999 wrote: Fri Jul 22, 2022 10:58 pmI'll do some tests with real movies.
That would be really useful, if you can provide a sample of the real bdmv (we can cut streams with CloneBD).
Checking other files (haven't checked the new test files yet), it seemed to me that the image is duller (less vibrant) via Oppo, compared to internal Plex client.
RESET_9999 wrote: Sat Jul 23, 2022 12:42 am 1- the shield behave exactly the same as the internal tv
Yes, I think it's a DoVi engine bug only on C1/C2 (not CX) with cmv2.9 devices, simple as that :)
Btw, is profile 5 content is also affected? (not that I want to use them on the Oppo, just curious) I'll check again the lelabodejay samples...
quietvoid
#7031 Post by quietvoid » Sat Jul 23, 2022 1:54 pm
chros wrote: Sat Jul 23, 2022 11:58 amYes, I think it's a DoVi engine bug only on C1/C2 (not CX) with cmv2.9 devices, simple as that :)
Makes sense, I guess the firesticks are affected too. I just don't have another device to compare against to know for sure.
#7032 Post by RESET_9999 » Sat Jul 23, 2022 2:19 pm
I checked real content(3 movies) and I couldn't really spot a difference in the brightness changes. (i wonder if the difference could be L4 ?)
There's only a big difference when I generate DV from HDR10 or HDR10plus and with quietvoid's pattern so I don't know what's going on but i still think there's something wrong (real content or not).
I also noticed that the cmv2.9 and cmv4.0 have different L1 metadata. cmv4.0 clip a lot more in the "high contrast" scene on both the C2/C8 but on the x800m2 there's no difference.
Today I'll put back side by side my C8/C2 and make a more direct comparison.
the 3 movies test I did were profile 8 and one of them didn't have any L2 (ocean's eight). I did the test without splitting the file because I wanted to make sure that nothing was broken so I can't share samples.
Anyone can do the same test, just extract the RPU and delay it by 30 frames. It can be done in P8 or P7.
extract and convert to P8:
dovi_tool.exe  -m 2 extract-rpu input.hevc
or
extract untouched P7:
dovi_tool.exe  -m 0 extract-rpu input.hevc
edit rpu:
dovi_tool.exe editor -i rpu.input.bin -j duplicate.json --rpu-out rpu_delayed.bin
duplicate json:
	"duplicate": [
			"source": 1,
			"offset": 1,
			"length": 30
inject:
dovi_tool.exe  inject-rpu -i video_input.hevc --rpu-in rpu_delayed.bin
#7033 Post by RESET_9999 » Sat Jul 23, 2022 2:28 pm
chros wrote: Sat Jul 23, 2022 11:58 am Btw, is profile 5 content is also affected? (not that I want to use them on the Oppo, just curious) I'll check again the lelabodejay samples...
because of the dynamic color reshaping in P5, it can be hard to delay the rpu but I compared lelabodejay pattern again last night and didn't really see any difference.
same with the fixed luma version P5 of the "mutli_pattern" from original spears and munsil
https://drive.google.com/file/d/1GRWWow ... sp=sharing
I checked HDR10 too and it clips a lot more than DV and maybe there's something going on with the ST2084 tracking in HDR10?
chros
#7034 Post by chros » Sat Jul 23, 2022 5:55 pm
quietvoid wrote: Sat Jul 23, 2022 1:54 pm
You remember when I had the B8 and Firestick 4k (old one) and I told you guys that the resulting image was different compared to the Oppo/Plex, it was darker on the Firestick somehow.
Is the Max version cmv4.0? In other words is your cmv4.0 sample has any effect on it?
So, I've been thinking about this more, what we know is:
- L1 data is arrived to the TV: there's a slight change in the image
- this can mean what I thought is: DoVi engine deals with the old devices differently
- or: L1 data gets truncated somehow: but this scenario is very unlikely, since L2 is not? :)
RESET_9999 wrote: Sat Jul 23, 2022 2:19 pm I checked real content(3 movies) and I couldn't really spot a difference in the brightness changes. (i wonder if the difference could be L4 ?)
That's not a good news :) What do you mean about L4?
RESET_9999 wrote: Sat Jul 23, 2022 2:19 pm Today I'll put back side by side my C8/C2 and make a more direct comparison.
Cheers, that would be really helpful! We only have to find 1 example with true content where the issue is clearly present, after we can think it over by examining the RPU itslef.
RESET_9999 wrote: Sat Jul 23, 2022 2:28 pm
Yes, I don't recall much difference with lelabodejay pattern either, that's why I asked about it. I'll try to recheck it soon. I'll also check that pattern.
Not sure about the HDR10 version (I don't have it), what is the metadata for it? (mdl, maxcll, etc)
RESET_9999 wrote: Sat Jul 23, 2022 2:19 pm There's only a big difference when I generate DV from HDR10 or HDR10plus and with quietvoid's pattern so I don't know what's going on
There's a only one more possibility in my book: that "only" profile 8.1 content is affected somehow :)
We will know this for sure when/if we find a true example.
The hunt is on! :)
quietvoid
#7035 Post by quietvoid » Sat Jul 23, 2022 5:57 pm
chros wrote: Sat Jul 23, 2022 5:55 pm Is the Max version cmv4.0? In other words is your cmv4.0 sample has any effect on it?
No, it only reacts to L2.
