sw5163
Post by sw5163 »
RESET_9999 wrote:
Fri Jul 22, 2022 10:56 am
ffmpeg doesnt support 7.1 audio.
That is not true. ffmpeg supports:
7.1 trueHD/atmos copy
7.1 trueHD, flac, PCM copy and encoding
6.1 alac encoding
7.1 eac3/atmos copy
5.1 eac3 encoding
5.1 ac3 encoding
I’m not familiar with all the DTX sound.
DEE does but I'm not able to get 7.1 audio from my C2 internal player to my AVR (might be because my avr is ARC)
ARC should be able to do 7.1 eac3/atmos at best, through HDMI 2.0
7.1 eac3 without atmos through HDMI 1.3
eARC is only needed for TrueHD and PCM
In case anyone want this, it's from https://zhuanlan.zhihu.com/p/106809463. I don't own it.
mehgh750
Post by mehgh750 »
RESET_9999 wrote:
Fri Jul 22, 2022 1:31 am
deadchip12 wrote:
Fri Jul 22, 2022 12:59 am
I'm using the recently purchased x700 with the lg c9 oled and it sucks if it turns out the x700 is unusable again.
C9 has the old DV engine so you don't have this problem.
How old are we talking about? I got LG Electronics OLED55B7A in 2018, do I need to worry about this issue?
sw5163 wrote:
Fri Jul 22, 2022 11:19 am
6.1 alac encoding
7.1 eac3/atmos copy
5.1 eac3 encoding
5.1 ac3 encoding
lol we are talking about my script and EC3 encoding.. I know ffmpeg can copy 7.1 audio
sw5163
Post by sw5163 »
RESET_9999 wrote:
Fri Jul 22, 2022 11:54 am
Sorry, my bad.
well 7.1 EC3 without a core doesn't work on my C8/C2 + ARC AVR , so I don't know
7.1 EC3 with a core plays fine but only the 5.1 core.
btw , the answer to your hybrid rpu question is also in my script :P. there's tutorial video. they were made with an older version of the script though.
mehgh750 wrote:
Fri Jul 22, 2022 11:44 am
looks like the CX or older are fine
looks like the Sony X900H also have the bug:
https://www.avsforum.com/threads/offici ... t-61832553
mehgh750
Post by mehgh750 »
RESET_9999 wrote:
Fri Jul 22, 2022 12:22 pm
Thanks for letting us know.
sw5163
Post by sw5163 »
RESET_9999 wrote:
Fri Jul 22, 2022 11:58 am
Wow, thanks that really helps a lot!
eac3 can have a core? I don't know that, I thought only TrueHD should have a core.
sw5163 wrote:
Fri Jul 22, 2022 12:48 pm
yes, a core is mandatory on bluray disc for EAC3.
i made a demo with a couple different audio you can test (i messed up the last part of the demo though):
https://drive.google.com/file/d/1D0qlUm ... sp=sharing
Audio #1
Format                                   : MLP FBA AC-3 16-ch
Muxing mode                              : Stream extension
Codec ID                                 : 131
Duration                                 : 6 min 28 s
Maximum bit rate                         : 5 064 kb/s
Stream size                              : 29.6 MiB (2%)
Number of dynamic objects                : 15
Audio #2
Format                                   : MLP FBA
Format/Info                              : Meridian Lossless Packing FBA
Commercial name                          : Dolby TrueHD
Codec ID                                 : 131
Maximum bit rate                         : 5 340 kb/s
Audio #3
Format                                   : E-AC-3
Format/Info                              : Enhanced AC-3
Commercial name                          : Dolby Digital Plus
Format profile                           : Blu-ray Disc
Format settings                          : Dolby Surround EX
Codec ID                                 : 132
Bit rate                                 : 1 536 kb/s
Stream size                              : 71.0 MiB (5%)
Audio #4
Format                                   : E-AC-3
Codec ID                                 : 132
Bit rate                                 : 768 kb/s
Stream size                              : 35.5 MiB (2%)
Audio #5
Format                                   : E-AC-3
Codec ID                                 : 132
Frame rate                               : 62.500 FPS (768 SPF)
sofakng
Post by sofakng »
Ugh ... I've just unboxed my x800m2 and I can confirm the bug on the LG C1. The LG C1 internal player looks fine.
sergonnn111
Post by sergonnn111 »
Hi please give source where i can get makemkv nightly
chros
Post by chros »
deadchip12 wrote:
Fri Jul 22, 2022 2:06 am
RESET_9999 wrote:
Fri Jul 22, 2022 1:58 am
it's not a player bug.
It's Dolby's faulty implementation in newer TV.
Oh so the new engine is faulty? Then I guess Dolby and LG have to work together to release an update on the newer TVs. I will try tagging Vincent from HDTV Test on twitter so he can be aware of this. He has good contacts at LG.
Thanks! Then just link this post, it has all the bugs we know so far about 2022 LG models.
https://www.avsforum.com/threads/2022-l ... t-61675612
And let's wait for a miracle! :D
chros
Post by chros »
RESET_9999 wrote:
Fri Jul 22, 2022 10:43 am
Poker354 wrote:
Fri Jul 22, 2022 3:52 am
I’m not sure I’m experiencing this bug. LG CX with Sony X700 and Shield Pro 2019. Testing the videos back and forth (ts on Sony and mp4 on Shield) I could easily see the changes on both. The shield might look slightly better but I easily see them as well on the x700.
X700
https://imgur.com/a/0kYGI5Z/all
Shield
https://imgur.com/a/CIEGd5f/all
yep, CX looks ok. lucky you
please try the cmv4.0 version on your Shield(or TV internal player) and tell us if you get L8 reaction.
https://drive.google.com/file/d/1tU3VLC ... sp=sharing
What does this do on our TV and UHD BD players? Thanks
sofakng
Post by sofakng »
I've tried this on my LG C1 (latest version) using x800m2 (latest firmware) and no visible changes for L3 or L8.
