#6991 Post by RESET_9999 » Fri Jul 22, 2022 2:51 am
sw5163 wrote: Fri Jul 22, 2022 2:31 am So if L1 is not used, it will be HDR10 without tone mapping(clipped).
Please correct me if I'm wrong.
pretty much but the L2 still has an effect when present.
But the thing is that a lot of movies only have a 600nits trim( no effect on bright TV) and some others don't have any (rare).
In that case that's basically static DV. Not to mention all the HDR10plus conversions to DV.
sofakng
#6992 Post by sofakng » Fri Jul 22, 2022 2:51 am
Ahhh! Now I understand ... The problem is between the older players and the newer TVs. Sorry for all the questions!
Poker354
#6993 Post by Poker354 » Fri Jul 22, 2022 3:52 am
I’m not sure I’m experiencing this bug. LG CX with Sony X700 and Shield Pro 2019. Testing the videos back and forth (ts on Sony and mp4 on Shield) I could easily see the changes on both. The shield might look slightly better but I easily see them as well on the x700.
X700
https://imgur.com/a/0kYGI5Z/all
Shield
https://imgur.com/a/CIEGd5f/all
djanvi2020
#6994 Post by djanvi2020 » Fri Jul 22, 2022 8:40 am
Interesting thought,
A majority of my Dolby Atmos DV discs have 7.1 and DD+ can do 7.1 Unless i missed the memo that DV MP4 or TS files doesnt like 7.1, why aernt we using it if Dolby Atmos or Dolby True HD tracks are in 7.1 and the Dolby Scripts downgrades it to 5.1?
why are we losing those two channels cause i do have a system that can do 7.1 and DD+ can have 7.1?
#6995 Post by RESET_9999 » Fri Jul 22, 2022 10:43 am
Poker354 wrote: Fri Jul 22, 2022 3:52 am I’m not sure I’m experiencing this bug. LG CX with Sony X700 and Shield Pro 2019. Testing the videos back and forth (ts on Sony and mp4 on Shield) I could easily see the changes on both. The shield might look slightly better but I easily see them as well on the x700.
X700
Shield
yep, CX looks ok. lucky you
please try the cmv4.0 version on your Shield(or TV internal player) and tell us if you get L8 reaction.
https://drive.google.com/file/d/1tU3VLC ... sp=sharing
#6996 Post by RESET_9999 » Fri Jul 22, 2022 10:56 am
djanvi2020 wrote: Fri Jul 22, 2022 8:40 am Interesting thought,
ffmpeg doesnt support 7.1 audio.
DEE does but I'm not able to get 7.1 audio from my C2 internal player to my AVR (might be because my avr is ARC)
Also, the 7.1 EC3 from bluray disc doesnt work, it plays the 5.1 core on my C8/C2.
sw5163
#6997 Post by sw5163 » Fri Jul 22, 2022 11:19 am
RESET_9999 wrote: Fri Jul 22, 2022 10:56 am ffmpeg doesnt support 7.1 audio.
That is not true. ffmpeg supports:
7.1 trueHD/atmos copy
7.1 trueHD, flac, PCM copy and encoding
6.1 alac encoding
7.1 eac3/atmos copy
5.1 eac3 encoding
5.1 ac3 encoding
I’m not familiar with all the DTX sound.
RESET_9999 wrote: Fri Jul 22, 2022 10:56 am DEE does but I'm not able to get 7.1 audio from my C2 internal player to my AVR (might be because my avr is ARC)
ARC should be able to do 7.1 eac3/atmos at best, through HDMI 2.0
7.1 eac3 without atmos through HDMI 1.3
eARC is only needed for TrueHD and PCM
In case anyone want this, it's from https://zhuanlan.zhihu.com/p/106809463. I don't own it.
mehgh750
#6998 Post by mehgh750 » Fri Jul 22, 2022 11:44 am
RESET_9999 wrote: Fri Jul 22, 2022 1:31 am
deadchip12 wrote: Fri Jul 22, 2022 12:59 am I'm using the recently purchased x700 with the lg c9 oled and it sucks if it turns out the x700 is unusable again.
C9 has the old DV engine so you don't have this problem.
How old are we talking about? I got LG Electronics OLED55B7A in 2018, do I need to worry about this issue?
#6999 Post by RESET_9999 » Fri Jul 22, 2022 11:54 am
sw5163 wrote: Fri Jul 22, 2022 11:19 am
6.1 alac encoding
7.1 eac3/atmos copy
5.1 eac3 encoding
5.1 ac3 encoding
lol we are talking about my script and EC3 encoding.. I know ffmpeg can copy 7.1 audio
sw5163
#7000 Post by sw5163 » Fri Jul 22, 2022 11:57 am
RESET_9999 wrote: Fri Jul 22, 2022 11:54 am lol we are talking about my script and EC3 encoding.. I know ffmpeg can copy 7.1 audio
Sorry, my bad.
#7001 Post by RESET_9999 » Fri Jul 22, 2022 11:58 am
sw5163 wrote: Fri Jul 22, 2022 11:19 am ARC should be able to do 7.1 eac3/atmos at best, through HDMI 2.0
well 7.1 EC3 without a core doesn't work on my C8/C2 + ARC AVR , so I don't know
7.1 EC3 with a core plays fine but only the 5.1 core.
btw , the answer to your hybrid rpu question is also in my script :P. there's tutorial video. they were made with an older version of the script though.
#7002 Post by RESET_9999 » Fri Jul 22, 2022 12:22 pm
mehgh750 wrote: Fri Jul 22, 2022 11:44 am How old are we talking about? I got LG Electronics OLED55B7A in 2018, do I need to worry about this issue?
looks like the CX or older are fine
#7003 Post by RESET_9999 » Fri Jul 22, 2022 12:24 pm
looks like the Sony X900H also have the bug:
https://www.avsforum.com/threads/offici ... t-61832553
mehgh750
#7004 Post by mehgh750 » Fri Jul 22, 2022 12:25 pm
RESET_9999 wrote: Fri Jul 22, 2022 12:22 pm
Thanks for letting us know.
sw5163
#7005 Post by sw5163 » Fri Jul 22, 2022 12:48 pm
RESET_9999 wrote: Fri Jul 22, 2022 11:58 am btw , the answer to your hybrid rpu question is also in my script :P. there's tutorial video. they were made with an older version of the script though.
Wow, thanks that really helps a lot!
RESET_9999 wrote: Fri Jul 22, 2022 11:58 am well 7.1 EC3 without a core doesn't work on my C8/C2 + ARC AVR , so I don't know
eac3 can have a core? I don't know that, I thought only TrueHD should have a core.
