Hi
Been trying to get this UHD disc to load properly for a couple of days now and even tried requesting new disc from Amazon in case the original was faulty but, there are problems with both.
The furthest I can get is that the disc eventually is recognised (e.g. disc title/ vol info, layers, ACS etc.) but when I then try to do the usual extract, it fails to fully read the disc structure/content tables and eventually fails with multiple READ FAILURE errors.
I know that this problem was previously on this board but just wondering if any other variation of this UHD (e.g. steelbook etc.) gives better results? I am trying to use the 'standard 4k UHD' as sold by Amazon here https://www.amazon.co.uk/gp/product/B01 ... UTF8&psc=1
I am using MakeMKV 1.17.1 with Asus BW-16D1HT drive with 3.10 patched firmware.........................which works brilliantly with almost everything else (except for Close Encounters of the Third Kind UHD.......which I have given up with now).
Thx
Goodfellas UHD HDR failing to load fully
Re: Goodfellas UHD HDR failing to load fully
It's the disc or the drive no magic is going to happen sadly
These type of read errors on bluray are almost never a bug it's a hardware problem
The usual steps are
Clean disc
Replace disc
Clean drive not with cleaning disc open it and use alcohol.
Replace drive with BU40N or UHD pioneer
The usual steps are
Clean disc
Replace disc
Thanks Billycar11................................dammit..............but at least I won't waste any more time on this now.Billycar11 wrote: ↑Thu Jul 21, 2022 1:35 pmIt's the disc or the drive no magic is going to happen sadly
The usual steps are
Clean disc
Replace disc
I successfully managed (well, MakeMKV has...) to rip Goodfellas UHD (ASIN B01MCUR3Q7) some months ago with LG BU40N.
