DVD Ejects
NineInchNails
DVD Ejects
Post by NineInchNails »
I've been able to do DVDs before on a Mac, but now it just spins, doesn't recognize the disc, then ejects. I've done DVDs in the past. This has happened just recently. I did a few DVDs a few days ago. Then the issue started. May have started after the new MakeMKV 1.17.1 for Mac OS X was installed. I have two computers. Neither can do a DVD.
Re: DVD Ejects
Is your problem with all DVD discs? Or have you just tried with only one or two discs?
NineInchNails
Re: DVD Ejects
Yes. And it started recently when I added the newest Makemkv update.
NineInchNails
Re: DVD Ejects
And on some Blu Rays all the files are saved except the main file. I had an occasional issue with a Blu Ray. Everything worked better before I updated to the newest version of MakeMKV.
