Post by RESET_9999 » Wed Jul 20, 2022 4:33 pm
yep same bug.. Confirmed on C1 and probably CX too :(
viewtopic.php?p=124746#p124746
sofakng
Post by sofakng » Wed Jul 20, 2022 4:36 pm
Darn! I've just ordered an oppo-clone but now I guess I should cancel it before it ships? :(
Post by RESET_9999 » Wed Jul 20, 2022 4:37 pm
if you have a CX or newer, yes i would try to cancel.
sofakng
Post by sofakng » Wed Jul 20, 2022 4:42 pm
Thanks ... hopefully it hasn't shipped yet.
I purchased both an x800m2 (received from Amazon) and oppo-clone (m9201, not yet shipped).
I have an LG CX and LG C1 but they don't support DTS or any lossless, right?
I've been trying to understand everything to get a "complete" UHD playback setup but it now seems impossible?
Post by RESET_9999 » Wed Jul 20, 2022 5:01 pm
correct, no dts support nor truehd via internal player. I convert to EAC3 5.1 1536kbps and get good quality (ARC).
EAC3 7.1 doesnt work on my end via ARC.
I wonder if this would allow me to play DV TS + LPCM 7.1 via EARC to my ARC AVR.
https://www.thenaudio.com/product/zone- ... processor/
magnetoeric
Post by magnetoeric » Wed Jul 20, 2022 5:15 pm
Thank you so much Reset for these findings. I was so close to purchasing x800m2 after going through your excel file sheet about all the players and its capabilities. I even had it in my cart :lol: But I guess I should be satisified with my shield pro and lg cx.
sofakng
Post by sofakng » Wed Jul 20, 2022 5:20 pm
I have almost the same exact product (SHARC v1) but I haven't used it yet. I ordered it a while ago but never used it on my LG CX but I'm going to try on my new LG C1. I'll let you know how it works.
Now that the x800m2/700/Oppo have a known bug, what is the next best method for playing FEL movies?
Post by RESET_9999 » Wed Jul 20, 2022 5:25 pm
I don't think there are any FEL devices that support cmv4.x unfortunately...
maybe the expensive Panasonic?
chros
Post by chros » Wed Jul 20, 2022 6:56 pm
RESET_9999 wrote:
Wed Jul 20, 2022 2:38 pm
Baer2021 wrote:
Wed Jul 20, 2022 2:30 pm
Is this only an issue with player-led Dolby Vision? Can the C2 perform TV-led Dolby Vision while still using the x700 to avoid the issues with L1?
those video are TV-led
it's also an issue with LLDV and it's actually a lot worse because not even L2 works with player-led TV.
see: https://www.avsforum.com/threads/offici ... t-61830407
Your Mutli_pattern_dv_p8 sample looks weird on Plex, but OK on Oppo :) (take a look at the bottom, clipping, conversion)
Post by RESET_9999 » Wed Jul 20, 2022 7:02 pm
yep, I noticed that too. It behaves a bit like the Shield but not as bad.
But Quietvoid found out that the BL luma is messed up in the original spears pattern. It's also encoded with incorrect static metadata.
If we fix the BL luma, no more clipping/conversion error at the bottom on the shield and C2, so I'm not sure this pattern is actually helpful
chros
Post by chros » Wed Jul 20, 2022 8:14 pm
Thanks, good to know, didn't know it had issues (Spears messed up so many things with that disc, and it's used for benchmarking :)).
Then let's try out this one, Seq Dovi 16mps (profile 5), form le labo dejay, it has similar pattern in the beginning:
https://lelabodejay.com/category/sequences-4kuhd-hdr
Off: good thing is that 2022 models has pretty good Hdr10, even in PC mode! What a turnaround... :)
Post by RESET_9999 » Wed Jul 20, 2022 9:32 pm
I tried that pattern the first week I got my Tv and didn't see anything wrong with it.
Regardless of the issue with cmv2.9 hdmi device, I think the 2022 LG oled are amazing TV at least for HDR. I don't watch SDR stuff on it.
Baer2021
Post by Baer2021 » Thu Jul 21, 2022 12:53 am
This new DV incompatibility with newer TVs might be the final straw for me with Dolby Vision haha. Seems just far too easy for me to just convert all my BDMV folder rip of DV films to HDR10 and call it a day.
Donpoku
Post by Donpoku » Thu Jul 21, 2022 4:36 am
Thank you @RESET_999 This is a huge revelation. Anyone know how to contact Dolby lab about this issue, maybe they can update old players to cm4.0?
Post by RESET_9999 » Thu Jul 21, 2022 1:52 pm
I don't think they can do that but I'm sure they can fix the issue via a firmware update on the newer TVs.
