Game of Thrones 4K UHD Retail.
MediaLibrary
Post by MediaLibrary » Wed Jul 20, 2022 2:31 pm
I'm getting fails on Disc 3 of the seasons below. I have the ASUS & LG drives and both are failing at the same time. These are virgin discs that have went from the retail wrapper to the drives. I want to post my dumps to see what is going on but wondering if anybody else has had these problems.
Season 1
  • Disc 3
Season 3
  • Disc 3
Season 4
  • Disc 3
Season 5
  • Disc 3
Season 8
  • Disc 3
MediaLibrary
Re: Game of Thrones 4K UHD Retail.
Post by MediaLibrary » Wed Jul 20, 2022 3:22 pm
OS device name: /dev/rdisk4
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: XXXXXXXXXXX
Highest AACS version: 76
Firmware version: 1.02
MakeMKV v1.17.1 darwin(arm64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLBKAMN5727d" opened in OS access mode.
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Downloading latest HK to /Users/mediaserver/Library/MakeMKV ...
Title #00020.mpls has length of 158 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00056.mpls has length of 21 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00802.mpls was added as title #0
File 00801.mpls was added as title #1
Title #00053.mpls has length of 259 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00800.mpls was added as title #2
Title #00058.mpls has length of 21 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00057.mpls has length of 21 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00015.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00014.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00011.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00010.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00009.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00045.m2ts was added as title #3
Title #00054.m2ts has length of 5 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00044.m2ts was added as title #4
Title #00005.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00003.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00002.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00046.m2ts was added as title #5
Title #00048.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00000.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00023.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00053.m2ts has length of 5 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00006.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00043.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00042.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00040.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00050.m2ts has length of 79 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00039.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00049.m2ts has length of 79 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00037.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00036.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00052.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00051.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00024.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00019.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00041.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00038.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00035.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00034.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00033.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00032.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00031.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00030.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00029.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00028.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00026.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00025.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00022.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00021.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00020.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00018.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00017.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Saving 3 titles into directory /Users/mediaserver/To Be Encoded
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00046.m2ts' at offset '5662310400'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '5662310400'
Failed to save title 0 to file /Users/mediaserver/To Be Encoded/Game Of Thrones Season 1 Disc 3_t00.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00045.m2ts' at offset '9870114816'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9870114816'
Failed to save title 1 to file /Users/mediaserver/To Be Encoded/Game Of Thrones Season 1 Disc 3_t01.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00044.m2ts' at offset '0'
Failed to save title 2 to file /Users/mediaserver/To Be Encoded/Game Of Thrones Season 1 Disc 3_t02.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 3 failed
Post by Billycar11 » Wed Jul 20, 2022 9:41 pm
Drive or disc problem
Clean the disc
Replace the disc
Clean drive
Replace drive with BU40N
MediaLibrary
Post by MediaLibrary » Wed Jul 20, 2022 10:34 pm
It only happens on Disc 3 of five of the seasons. I have cleaned the discs before but they were virgin discs out of the wrapper when I tried...
  • ASUS BW-16DIHT
  • LG WH16NS60
They fail with the same error messages at the same point. I have been able to backup 22 out of the 27 dscs in the complete series.
I ordered a BU40N for shits and giggles and I'll try it but I expect the same results. It should be here tomorrow so I'll have another update. Also I have backed up 200 other titles without failure as informational data.
Post by Billycar11 » Thu Jul 21, 2022 1:04 am
MediaLibrary wrote: Wed Jul 20, 2022 10:34 pm Image
  • ASUS BW-16DIHT
  • LG WH16NS60
i recommend you exchange the discs first but ok
MediaLibrary
Post by MediaLibrary » Sun Jul 24, 2022 6:36 pm
I found a new copy on the shelves, bought it and sure enough it ripped no issues. I have no why but thank you fro the suggestion.
lfoust
Post by lfoust » Wed Jul 27, 2022 3:59 pm
I was able to rip the entire series on 4K. Here is how all the discs layed out for me: https://thediscdb.com/series/game-of-th ... lection-4k
Hope this helps.
audiom3
Post by audiom3 » Mon Oct 24, 2022 11:18 pm
lfoust wrote: Wed Jul 27, 2022 3:59 pm I was able to rip the entire series on 4K. Here is how all the discs layed out for me: https://thediscdb.com/series/game-of-th ... lection-4k
Hope this helps.
Thanks for posting this. I bought a collector's metal edition and ripping them now... I know for a fact that you cannot always trust the mpls sequence but at least I know now with GoT, you can. For anyone reading this, trust that 00800.mpls, 00801.mpls and 00802.mpls are the correct sequential order across all discs. I believe that all discs have 3 episodes unless there is a single episode on said disc. That single episode will be 00800.mpls. But if I am wrong and there are two, then they will be 00800.mpls (next episode in series) and 00801.mpls (next episode in series after previous 00800.mpls).
xunil76
Post by xunil76 » Wed Oct 26, 2022 2:36 am
I had a TON of problems with ripping this whole series, purchased on Amazon U.S. Probably MORE than 1/2 of the discs initially had read errors, but I was able to clean the discs (sometimes it took more than one cleaning per disc), and eventually got all but 4 of the discs to backup.
Did a return on that set and got it replaced with another one, but didn't send the old one back until I got the new one. Made sure the 4 discs that couldn't be read from the first set were able to be read from set #2 (still took 1-2 cleanings per disc in the new set), swapped in the "good" ones from set #2 into set #1, then returned the one that contained all the discs that could not be read.
This was a HUGE PITA for me, because each time I ripped a disc, it would almost always wait until at least 50% before it prompted about the read error, which took at least 45 mins each time...so I'd have to cancel it, clean the disc, then try again. Some discs actually took 4 tries before they could be read. At the time, I had 5x drives in total that I knew were working (had several more laying around yet to be tested), but I THOUGHT only 1 of them was UHD-friendly...ended up buying 4 more that were UHD-friendly...then as it turns out, several of the ones I already had (they were mounted in my desktop system, which was on the fritz at the time, so they were not usable) were able to be flashed to be friendly as well.
I now have 13x blu-ray drives in total, with 9x UHD-friendly. 6x UHD-friendly are in my new desktop system that I just built, with 2x UHD, 1x regular blu-ray, and 1x HD-DVD/Blu-ray combo drive (LG GGC-H20L) all mounted in external USB enclosures that I can use right now, leaving 3 drives not installed at the moment and not usable. But I also do have a slim blu-ray drive (not UHD-friendly) installed in one of my old laptops as well, so technically 14x drives in total. I will never go through the pain that I went through ripping this series, EVER again! LOL :D :D :D :D
DC-2187
Post by DC-2187 » Wed Jan 18, 2023 12:48 am
Hope this helps.
Thank you so much for this. I have never seen the show and decided to pick up this set. I wanted watch this on my media server without using the discs but had no idea how to name the episodes.
madeby
Post by madeby » Thu Feb 16, 2023 7:44 pm
ok ok ok,
this might seen weird, but i think i found a workaround for the problem.
Ive got all the same errors with all the Disks3s of the UHD collection.
if i try to open any of the Disks 3 in makeMKV it wont apear - if i try to open it in handbrake first (witch will end in a error message), then try to read it in makeMKV, it´ll shows up and work!
can someone replicate this?
cheers
Post by Billycar11 » Thu Feb 16, 2023 8:16 pm
madeby wrote: Thu Feb 16, 2023 7:44 pm ok ok ok,
cheers
What if you just let explorer see the disc first then open makemkv only after it sees the disc name
madeby
Post by madeby » Sat Feb 18, 2023 2:28 pm
...yeah well,
that works too :)
razy60
Post by razy60 » Sun Aug 06, 2023 1:29 pm
cheers
I know its a bit late but been trying to do this and finaly thanks to @madeby it works, cheers
