Baer2021
#6961 Post by Baer2021 » Wed Jul 20, 2022 2:30 pm
Is this only an issue with player-led Dolby Vision? Can the C2 perform TV-led Dolby Vision while still using the x700 to avoid the issues with L1?
#6962 Post by RESET_9999 » Wed Jul 20, 2022 2:38 pm
those video are TV-led
it's also an issue with LLDV and it's actually a lot worse because not even L2 works with player-led TV.
see: https://www.avsforum.com/threads/offici ... t-61830407
chros
#6963 Post by chros » Wed Jul 20, 2022 2:46 pm
My Oppo was set to TV-led specifically.
sergonnn111
#6964 Post by sergonnn111 » Wed Jul 20, 2022 3:43 pm
Hi guys i did dolby vision file in TS container with ts muxer nightly from mkv container and this mkv file from bd dolby vision , did i get true dolby vision for my LG OLLED E8 2018 ? And one more dolby vision is great on my lg oled e8 but i don t see subtitles ?
#6965 Post by RESET_9999 » Wed Jul 20, 2022 4:27 pm
yes
subtitles must be external SRT and filename the same as the TS.
example:
Movie.Name.ts
Movie.Name.ENG.FORCED.srt
I dont know about the native LG player but it works in PLEX
sofakng
#6966 Post by sofakng » Wed Jul 20, 2022 4:31 pm
Can anybody with an oppo (or clone) test this?
Does it also have the bug?
#6967 Post by RESET_9999 » Wed Jul 20, 2022 4:33 pm
yep same bug.. Confirmed on C1 and probably CX too :(
viewtopic.php?p=124746#p124746
sofakng
#6968 Post by sofakng » Wed Jul 20, 2022 4:36 pm
Darn! I've just ordered an oppo-clone but now I guess I should cancel it before it ships? :(
#6969 Post by RESET_9999 » Wed Jul 20, 2022 4:37 pm
if you have a CX or newer, yes i would try to cancel.
sofakng
#6970 Post by sofakng » Wed Jul 20, 2022 4:42 pm
Thanks ... hopefully it hasn't shipped yet.
I purchased both an x800m2 (received from Amazon) and oppo-clone (m9201, not yet shipped).
I have an LG CX and LG C1 but they don't support DTS or any lossless, right?
I've been trying to understand everything to get a "complete" UHD playback setup but it now seems impossible?
#6971 Post by RESET_9999 » Wed Jul 20, 2022 5:01 pm
correct, no dts support nor truehd via internal player. I convert to EAC3 5.1 1536kbps and get good quality (ARC).
EAC3 7.1 doesnt work on my end via ARC.
I wonder if this would allow me to play DV TS + LPCM 7.1 via EARC to my ARC AVR.
https://www.thenaudio.com/product/zone- ... processor/
magnetoeric
#6972 Post by magnetoeric » Wed Jul 20, 2022 5:15 pm
Thank you so much Reset for these findings. I was so close to purchasing x800m2 after going through your excel file sheet about all the players and its capabilities. I even had it in my cart :lol: But I guess I should be satisified with my shield pro and lg cx.
sofakng
#6973 Post by sofakng » Wed Jul 20, 2022 5:20 pm
I have almost the same exact product (SHARC v1) but I haven't used it yet. I ordered it a while ago but never used it on my LG CX but I'm going to try on my new LG C1. I'll let you know how it works.
Now that the x800m2/700/Oppo have a known bug, what is the next best method for playing FEL movies?
#6974 Post by RESET_9999 » Wed Jul 20, 2022 5:25 pm
I don't think there are any FEL devices that support cmv4.x unfortunately...
maybe the expensive Panasonic?
chros
#6975 Post by chros » Wed Jul 20, 2022 6:56 pm
Your Mutli_pattern_dv_p8 sample looks weird on Plex, but OK on Oppo :) (take a look at the bottom, clipping, conversion)
