#6946 Post by RESET_9999 » Wed Jul 20, 2022 12:52 pm
chros wrote: Wed Jul 20, 2022 12:24 pm Hmm, I'm not happy either about L1. Do you know if it is used frequently on UHD BD discs?
o yeah, L1 is mandatory for DV. L2 trims are optional and a lot of movies have only a 600nits trim pass and I'm pretty sure our 900nits TVs are not getting it so in this case it totally rely only on L1.
plus L2 is only really useful when the content is brighter than your TV capabilities.
https://slow.pics/c/sfjqSNwC
quietvoid
#6947 Post by quietvoid » Wed Jul 20, 2022 1:04 pm
RESET_9999 wrote: Wed Jul 20, 2022 3:46 amsure, here are videos showing exactly what I'm talking about. There's clearly something wrong.
I'm curious about your firestick...
Both of the FireTV sticks are the same.
Only "L1 higher contrast" does not clip like the C2 internal player, "L1 lower contrast" is just dimming the sky.
It's not really clear which is correct behaviour.
As the C2 player makes it clip out detail while external devices seem to tone map to a minimum peak limit.
It would have to be tested with a higher and lower brightness clip, to see if it reacts differently.
The Sony still seems to not work for "L1 lower contrast" either, but the sticks do.
Is the sky clipping all the time with the Sony? It looks like that in the video.
The sticks never clip.
#6948 Post by RESET_9999 » Wed Jul 20, 2022 1:35 pm
quietvoid wrote: Wed Jul 20, 2022 1:04 pm The Sony still seems to not work for "L1 lower contrast" either, but the sticks do.
I see a slight change for every L1 but it's almost unnoticeable if I'm not 1 feet close to the TV. I was more focussed on the brightness changes but IIRCC both sony dont clip at all.
I think the C2 internal player clip more than the C8 internal player though.
I dont know about the firestick but In my mind, there's no doubt the x800/x700/oppo are wrong. It's quite obvious in the madvr out sync version of SM clip i did.
theres a lot more clipping on the x800 than with the C2 internal player.
https://drive.google.com/file/d/1CuWlHK ... sp=sharing
quietvoid
#6949 Post by quietvoid » Wed Jul 20, 2022 1:46 pm
RESET_9999 wrote: Wed Jul 20, 2022 1:35 pmI dont know about the firestick but In my mind, there's no doubt the x800/x700/oppo are wrong. It's quite obvious in the madvr out sync version of SM clip i did.
Yeah that doesn't look right at all.
ragico
#6950 Post by ragico » Wed Jul 20, 2022 2:07 pm
I confirm your findings. there is a lot more clipping on the x700 than on CX internal player.
#6951 Post by RESET_9999 » Wed Jul 20, 2022 2:12 pm
ragico wrote: Wed Jul 20, 2022 2:07 pm I confirm your findings. there is a lot more clipping on the x700 than on C1 internal player.
thanks so it's not only a C2 issue and it very much looks like an issue with V2.9 vs v4.0 since the shield happens to have the newer DV engine too and behave properly.
Baer2021
#6952 Post by Baer2021 » Wed Jul 20, 2022 2:30 pm
Is this only an issue with player-led Dolby Vision? Can the C2 perform TV-led Dolby Vision while still using the x700 to avoid the issues with L1?
#6953 Post by RESET_9999 » Wed Jul 20, 2022 2:38 pm
Baer2021 wrote: Wed Jul 20, 2022 2:30 pm Is this only an issue with player-led Dolby Vision? Can the C2 perform TV-led Dolby Vision while still using the x700 to avoid the issues with L1?
those video are TV-led
it's also an issue with LLDV and it's actually a lot worse because not even L2 works with player-led TV.
see: https://www.avsforum.com/threads/offici ... t-61830407
chros
#6954 Post by chros » Wed Jul 20, 2022 2:46 pm
My Oppo was set to TV-led specifically.
sergonnn111
#6955 Post by sergonnn111 » Wed Jul 20, 2022 3:43 pm
Hi guys i did dolby vision file in TS container with ts muxer nightly from mkv container and this mkv file from bd dolby vision , did i get true dolby vision for my LG OLLED E8 2018 ? And one more dolby vision is great on my lg oled e8 but i don t see subtitles ?
#6956 Post by RESET_9999 » Wed Jul 20, 2022 4:27 pm
sergonnn111 wrote: Wed Jul 20, 2022 3:43 pm did i get true dolby vision for my LG OLLED E8 2018 ? And one more dolby vision is great on my lg oled e8 but i don t see subtitles ?
yes
sergonnn111 wrote: Wed Jul 20, 2022 3:43 pm dolby vision is great on my lg oled e8 but i don t see subtitles ?
subtitles must be external SRT and filename the same as the TS.
example:
Movie.Name.ts
Movie.Name.ENG.FORCED.srt
I dont know about the native LG player but it works in PLEX
sofakng
#6957 Post by sofakng » Wed Jul 20, 2022 4:31 pm
Can anybody with an oppo (or clone) test this?
Does it also have the bug?
#6958 Post by RESET_9999 » Wed Jul 20, 2022 4:33 pm
yep same bug.. Confirmed on C1 and probably CX too :(
viewtopic.php?p=124746#p124746
sofakng
#6959 Post by sofakng » Wed Jul 20, 2022 4:36 pm
Darn! I've just ordered an oppo-clone but now I guess I should cancel it before it ships? :(
#6960 Post by RESET_9999 » Wed Jul 20, 2022 4:37 pm
sofakng wrote: Wed Jul 20, 2022 4:36 pm Darn! I've just ordered an oppo-clone but now I guess I should cancel it before it ships? :(
if you have a CX or newer, yes i would try to cancel.
