The Northman UHD
comicscodedavid
The Northman UHD
Post by comicscodedavid »
Is anyone else having problems ripping the new Northman UHD disk? It seems to be unable to even open the disk. I'm pretty new to all of this. It's saying something about being unable to recognize the key.
Re: The Northman UHD
Post by d00zah »
The UHD FAQ (linked in my sig) may hold the answer.
Blackcape
Post by Blackcape »
comicscodedavid wrote:
Tue Jul 19, 2022 6:12 pm
I just ripped this the other day and did NOT have an issue. I can snag the UPC if that is helpful...
NotSoCryptic
Post by NotSoCryptic »
I'm having issues with the Northman UHD as well, I'm on 1.17.1 (beta) with a full key.
Using an ASUS BW-16D1HT with custom firmware applied for LibreDrive (already flashed to latest as of 2 months ago). Drive it's self is connected via a USB 3.1 drive shell.
Logs attached. This isn't my first UHD Rip either aside from Back to the Future UHD set.
MakeMKV-Northmanlog.txt
(30.14 KiB) Downloaded 428 times
This looks like the relevant part of your log:
Saving 1 titles into directory E:/Encoding/Video
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00057.m2ts' at offset '873461760'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '873461760'
DEBUG: Code 3221225488 at qfmN#a{sFwgf"zj2mo:213131502
DEBUG: Code 101000192 at qfmN#a{sFwgf"zj2mo:213131502
It sorta seems like your drive disappeared from Windows while MakeMKV was ripping.
NotSoCryptic
Odd that it only seems to happen with The Northman and not my other UHDs. I guess I could use my backup drive and tap right into SATA 6.0 and see if that helps at all. Actually in the middle of GoT rip and just finished 2 other movies since.
NotSoCryptic
After trying 3 drives, two asus, and another model recommended on another thread and 3 replacement discs from amazon later, I finally managed to get it to rip. Same version of hte software. This seems to be a reoccuring them with UHD discs. Drive replacements fixed issues I was having with back to the future trilogy, though it took frankensteining two sets first before settling on one disc being the drives fault and a different disc being the discs fault. Had similar issues with Game of Thrones and had to frankenstein 3 different sets together and use two different drives.
Keep in mind most of the time my Asus drives have no issues (of which I have 2) each of them exibiting their own quirks, but still manage to read the data off.
Point I'm getting at here is the discs are at times to blame, but I think it would be worth consideration to re-asses these drives, the custom firmwares, and even MakeMKV as I don't think the drives themeselves are the actual problem, seems like a software control error. Might be worth updating the LibraDrive thread to reflect some of this information, doesn't seem like anyone's maintianing this, though probably a bit much to expect anyone to do so. So I'm without an actual workable solution.
Anyway glad I got my UHD's on my server. Thank you for the help.
lfoust
Post by lfoust »
Here is how the discs mapped out for me: https://thediscdb.com/movie/the-northma ... edition-4k
Stalyoni
Post by Stalyoni »
Tried backing it up with the three libre drives I have on my system with no luck as well.
External drive in a Vantec USB 3.0 Slim SATA Optical Drive Enclosure (NST-510S3-BK), 9.5 mm (Slim)
OS device name: \Device\CdRom2
Product: BD-RE BU50N
Revision: 1.00
Serial number: 906HS007100
Firmware date: 2117-11-21 10:06
Highest AACS version: 76
Firmware version: 1.00
Drive 2
OS device name: H:
Product: BD-RE BH16NS55
Revision: 1.02
Serial number: KLLL5RE1143
Firmware date: 2115-12-11 14:40
Firmware version: 1.02
Drive 3
OS device name: E:
Product: BD-RE BH14NS40
Revision: 1.03
Serial number: K9BC6KG1848
Firmware date: 2114-05-07 10:12
Drive platform: MT1939
Firmware version: 1.03
BD raw metadata read: Partial
52.7 GB (56,639,881,216 bytes) with the BD-RE BU50N uncompleted file
49.8 GB (53,519,319,040 bytes) with the BD-RE BH16NS55 uncompleted file
The BD-RE BH14NS40 wouldn't even read it at all. Spins up for ages but never actually reads the disc.
The disc is brand new and never even been put into a Blu-ray player and there are no visible signs of scratches. What's the secret of backing up this disc please guys? Obviously if you guys are having issues then there's more at stake here. Also, if you need to see my logs then let me know how to get that to you. Thanks
Stalyoni wrote:
Sat Jan 21, 2023 11:55 am
Revision: 1.00
Drive 2
OS device name: H:
Revision: 1.02
Drive 3
OS device name: E:
Revision: 1.03
clean the disc
replace the disc
you already have multiple drives proving the disc is the issue there are bad discs out there
Stalyoni
Post by Stalyoni »
There sending me a replacement so we will see if your correct. If it's that specific disk. Billycar11 one of newer LG libre Bluray drives is yours anyways (bought it from you). Like I bought it frpmSo we shall what we will see when it turns up mang.
Stalyoni
Post by Stalyoni »
received the new copy yesterday and it ripped fine in both makeMKV and dvdFAB. I have included pics of the original and new one. The original is still in the case, new copy is sitting on my office desk without the case. Yes, I realize that the original has fingerprints on it, but it was literally new straight out of the case when I tried to copy it. Picture was taken of the original disc after many failed attempts of backing it up. I think given that the file size is almost 70gb so the slightest little mark on the disc would affect the dual or triple layers. Anyways have a new copy now and it backed up fine. But just thought I would follow up and share my experience. Thanks all for the help. Have a great weekend.
