sw5163
#6871 Post by sw5163 » Sat Jul 16, 2022 4:14 pm
Manixx2020beyound wrote:
Sat Jul 16, 2022 3:52 pm
Got a cmv question?
Let’s say master move was done in cmv2
When that master churns out a p5 I assume it’s now cmv4, I’m I correct in saying most original P5s are cmv4 this is what I’m seeing on my end please correct me if I’m wrong.
Packing P8->P5 only changes profile. All the RPU data won't be changed. CM version will also not change. If that's what you are asking.
ragico
#6872 Post by ragico » Sat Jul 16, 2022 4:15 pm
quietvoid wrote:
Sat Jul 16, 2022 3:49 pm
ragico wrote:
Sat Jul 16, 2022 3:27 pm
Please can you share your latest kodi build for Firestick?
Many thanks.
This is the last I built: https://mega.nz/file/NN9GADIL#8aizfPA8M ... k6_PNiTLJc
Thanks a lot.
sw5163
#6873 Post by sw5163 » Sat Jul 16, 2022 4:19 pm
RESET_9999 wrote:
Sat Jul 16, 2022 3:57 pm
no, most movies are V2.9 (95%+)
Do you have a file with a lot of cmv40 data?
According to saindriches, cmv4 seems to have a problem on Apple platform. I want to give it a test but I don't know what file is FEL with cmv40.
屏幕截图 2022-07-16 120548.png (32.79 KiB) Viewed 15970 times
#6874 Post by RESET_9999 » Sat Jul 16, 2022 4:22 pm
you can check out the movie Hitman's Wife's Bodyguard. And I think you can remove cmv4.x with the dovi_tool
    "cmv40_metadata": {
      "num_ext_blocks": 4,
      "ext_metadata_blocks": [
          "Level3": {
            "min_pq_offset": 2048,
            "max_pq_offset": 2048,
            "avg_pq_offset": 1313
          "Level8": {
            "length": 25,
            "target_display_index": 1,
            "trim_slope": 1886,
            "trim_offset": 2108,
            "trim_power": 2380,
            "trim_chroma_weight": 1638,
            "trim_saturation_gain": 1638,
            "ms_weight": 2048,
            "target_mid_contrast": 1946,
            "clip_trim": 2048,
            "saturation_vector_field0": 128,
            "saturation_vector_field1": 102,
            "saturation_vector_field2": 128,
            "saturation_vector_field3": 128,
            "saturation_vector_field4": 128,
            "saturation_vector_field5": 128,
            "hue_vector_field0": 128,
            "hue_vector_field1": 96,
            "hue_vector_field2": 128,
            "hue_vector_field3": 128,
            "hue_vector_field4": 128,
            "hue_vector_field5": 128
          "Level9": {
            "length": 1,
            "source_primary_index": 0
          "Level254": {
            "dm_mode": 0,
            "dm_version_index": 2
  "rpu_data_crc32": 2447853315
ragico
#6875 Post by ragico » Sat Jul 16, 2022 4:40 pm
sw5163 wrote:
Sat Jul 16, 2022 3:47 pm
ragico wrote:
Sat Jul 16, 2022 2:26 pm
Also Plex triggers Dolby Vision playing Profile 8 ts movies. Is it fake or real DV?
One possible way to find out is to remux those sample files provide by quietvoid.
quietvoid wrote:
Wed Jun 08, 2022 1:51 am
You can try the files here: https://mega.nz/file/xNcAVQhJ#ldoifbK6D ... dXkzw2HYgs
Im guessing tsmuxer can mux them to P8 ts, but I don't know how.
Those files, provided by @quietvoid are mkv.
So I remuxed them in Ts muxer.
In Plex both mkv and ts remuxed files do not work. No rpu.
So, to answer my question, P8 ts files in Plex are fake DV.
sw5163
#6876 Post by sw5163 » Sat Jul 16, 2022 4:42 pm
Thanks, I'm going to give it a test.
#6877 Post by RESET_9999 » Sat Jul 16, 2022 4:45 pm
ok so
fake p5 TS = no go
p8 ts =no go
p8 mkv = no go as well I guess?
one last thing to try,
fake p5 mkv: https://drive.google.com/file/d/1H_edhc ... sp=sharing
ragico
#6878 Post by ragico » Sat Jul 16, 2022 5:09 pm
ok so
fake p5 TS = no go
p8 ts =no go
The file cant be played in Plex.
sofakng
#6879 Post by sofakng » Sat Jul 16, 2022 5:48 pm
Is it possible to decode and play Dolby Vision movies on a PC monitor?
For example, the Alienware AW3423DW (34" Ultrawide, QD-OLED, "HDR") doesn't support Dolby Vision but can software decode the Dolby Vision and display it instead of having the monitor decode it?
quietvoid
#6880 Post by quietvoid » Sat Jul 16, 2022 6:03 pm
Not completely supported as if it was played in real Dolby Vision.
At best you can playback profile 5 in HDR10, with no extra dynamic tone mapping using the metadata.
mpv supports partial processing of profile 7/8 as well, but that might be inaccurate in comparison.
As the processing isn't complete (FEL, for example).
sw5163
#6881 Post by sw5163 » Sat Jul 16, 2022 6:35 pm
Sorry could you please explain more of this? Is it still HDR10 when RPU levels can make a difference?
Can windows have the correct display brightness and pass that to DV extension and produce proper tone mapped image? In that case, would it be equivalent to HDR10+?
quietvoid
#6882 Post by quietvoid » Sat Jul 16, 2022 6:39 pm
The dynamic metadata from the RPU isn't used, so what you get as output is HDR10 + whatever processing your video player does.
No, you have to rely on your player to do the tone mapping, or the HDR10 passthrough.
sw5163
#6883 Post by sw5163 » Sat Jul 16, 2022 7:14 pm
Sorry I’m a little confused, what do you mean by “dynamic metadata”? RPU level in your samples make a difference on DV extension on windows. Is there something more in p8 RPU besides null reshaping and those levels? I thought if I can see dynamic brightness change it will be dynamic mapping. Maybe I’m wrong, which I always am.
What’s the difference between let DV extension handle mapping(if it works correctly) and proper lldv?
sw5163
#6884 Post by sw5163 » Sat Jul 16, 2022 7:19 pm
ok so
fake p5 TS = no go
p8 ts =no go
Guess fake P5 mp4 will be the only way.
quietvoid
#6885 Post by quietvoid » Sat Jul 16, 2022 7:29 pm
The original post asked about HDR playback.
What you're talking about is the Windows app, which only outputs SDR.
That does dynamic tone mapping but no HDR output.
