ragico
Post by ragico »
quietvoid wrote: Sat Jul 16, 2022 2:59 pm
ragico wrote: Sat Jul 16, 2022 2:26 pm cmv29.mp4 - all works, rpu works (DV)
cmv40.mp4 - L2 does not work. L1, L3 and L8 works and rpu works. (DV)
I don't know what these means, someone could explain these results?
CM v4.x replaces L2 with L8, so L2 is only used when the device doesn't support L8.
It's expected behaviour.
Thanks for the explanation.
Please can you share your latest kodi build for Firestick?
Many thanks.
sw5163
Post by sw5163 »
ragico wrote: Sat Jul 16, 2022 2:26 pm cmv40.mp4 - L2 does not work. L1, L3 and L8 works and rpu works. (DV)
Some official document: https://professionalsupport.dolby.com/s ... uage=en_US
sw5163
Post by sw5163 »
ragico wrote: Sat Jul 16, 2022 2:26 pm Also Plex triggers Dolby Vision playing Profile 8 ts movies. Is it fake or real DV?
One possible way to find out is to remux those sample files provide by quietvoid.
quietvoid wrote: Wed Jun 08, 2022 1:51 am You can try the files here: https://mega.nz/file/xNcAVQhJ#ldoifbK6D ... dXkzw2HYgs
Im guessing tsmuxer can mux them to P8 ts, but I don't know how.
quietvoid
Post by quietvoid »
ragico wrote: Sat Jul 16, 2022 3:27 pm Please can you share your latest kodi build for Firestick?
Many thanks.
This is the last I built: https://mega.nz/file/NN9GADIL#8aizfPA8M ... k6_PNiTLJc
Post by Manixx2020beyound »
sw5163 wrote: Sat Jul 16, 2022 3:34 pm
Got a cmv question?
Let’s say master move was done in cmv2
When that master churns out a p5 I assume it’s now cmv4, I’m I correct in saying most original P5s are cmv4 this is what I’m seeing on my end please correct me if I’m wrong.
Manixx2020beyound wrote: Sat Jul 16, 2022 3:52 pm I’m I correct in saying most original P5s are cmv4 this is what I’m seeing on my end please correct me if I’m wrong.
no, most movies are V2.9 (95%+)
Strangely, The Black Phone Movies Anywhere P5 web-dl has two frames on V4.x and the rest on V2.9
Summary:
Frames: 148739
Profile: 8
DM version: 1 + 2 (CM 2.9 and 4.x)
v2.9 count: 148739
v4.x count: 2
Scene/shot count: 1390
quietvoid
Post by quietvoid »
RESET_9999 wrote: Sat Jul 16, 2022 3:57 pm Strangely, The Black Phone Movies Anywhere P5 web-dl has two frames on V4.x and the rest on V2.9
Most Movies Anywhere samples I looked at were like that.
sw5163
Post by sw5163 »
Manixx2020beyound wrote: Sat Jul 16, 2022 3:52 pm Got a cmv question?
Packing P8->P5 only changes profile. All the RPU data won't be changed. CM version will also not change. If that's what you are asking.
ragico
Post by ragico »
quietvoid wrote: Sat Jul 16, 2022 3:49 pm
Many thanks.
Thanks a lot.
sw5163
Post by sw5163 »
RESET_9999 wrote: Sat Jul 16, 2022 3:57 pm no, most movies are V2.9 (95%+)
Do you have a file with a lot of cmv40 data?
According to saindriches, cmv4 seems to have a problem on Apple platform. I want to give it a test but I don't know what file is FEL with cmv40.
屏幕截图 2022-07-16 120548.png (32.79 KiB) Viewed 22998 times
sw5163 wrote: Sat Jul 16, 2022 4:19 pm Do you have a file with a lot of cmv40 data?
you can check out the movie Hitman's Wife's Bodyguard. And I think you can remove cmv4.x with the dovi_tool
    "cmv40_metadata": {
      "num_ext_blocks": 4,
      "ext_metadata_blocks": [
          "Level3": {
            "min_pq_offset": 2048,
            "max_pq_offset": 2048,
            "avg_pq_offset": 1313
          "Level8": {
            "length": 25,
            "target_display_index": 1,
            "trim_slope": 1886,
            "trim_offset": 2108,
            "trim_power": 2380,
            "trim_chroma_weight": 1638,
            "trim_saturation_gain": 1638,
            "ms_weight": 2048,
            "target_mid_contrast": 1946,
            "clip_trim": 2048,
            "saturation_vector_field0": 128,
            "saturation_vector_field1": 102,
            "saturation_vector_field2": 128,
            "saturation_vector_field3": 128,
            "saturation_vector_field4": 128,
            "saturation_vector_field5": 128,
            "hue_vector_field0": 128,
            "hue_vector_field1": 96,
            "hue_vector_field2": 128,
            "hue_vector_field3": 128,
            "hue_vector_field4": 128,
            "hue_vector_field5": 128
          "Level9": {
            "length": 1,
            "source_primary_index": 0
          "Level254": {
            "dm_mode": 0,
            "dm_version_index": 2
  "rpu_data_crc32": 2447853315
ragico
Post by ragico »
sw5163 wrote: Sat Jul 16, 2022 3:47 pm
Those files, provided by @quietvoid are mkv.
So I remuxed them in Ts muxer.
In Plex both mkv and ts remuxed files do not work. No rpu.
So, to answer my question, P8 ts files in Plex are fake DV.
sw5163
Post by sw5163 »
RESET_9999 wrote: Sat Jul 16, 2022 4:22 pm
Thanks, I'm going to give it a test.
ragico wrote: Sat Jul 16, 2022 4:40 pm Those files, provided by @quietvoid are mkv.
ok so
fake p5 TS = no go
p8 ts =no go
p8 mkv = no go as well I guess?
one last thing to try,
fake p5 mkv: https://drive.google.com/file/d/1H_edhc ... sp=sharing
ragico
Post by ragico »
RESET_9999 wrote: Sat Jul 16, 2022 4:45 pm
ok so
fake p5 TS = no go
p8 ts =no go
The file cant be played in Plex.
