quietvoid
#6856 Post by quietvoid » Sat Jul 16, 2022 2:59 pm
ragico wrote: Sat Jul 16, 2022 2:26 pm cmv29.mp4 - all works, rpu works (DV)
cmv40.mp4 - L2 does not work. L1, L3 and L8 works and rpu works. (DV)
I don't know what these means, someone could explain these results?
CM v4.x replaces L2 with L8, so L2 is only used when the device doesn't support L8.
It's expected behaviour.
#6857 Post by Manixx2020beyound » Sat Jul 16, 2022 3:04 pm
sw5163 wrote: Sat Jul 16, 2022 2:36 pm
ragico wrote: Sat Jul 16, 2022 2:07 pm Yes, Infuse triggers DV but no Rpu.
That's strange, it seems Manixx2020beyound played them by infuse and plex.
Manixx2020beyound wrote: Mon Jun 27, 2022 11:17 pm
sw5163 wrote: Mon Jun 27, 2022 11:04 pm
Sorry to bother, but could you please tell me how did you stream video from pc(windows?) to Apple?
Im currently using file sharing through SMB, but I don't know if there is a better way.
Infuse
Plex
I've just tried the latest infuse on my iPad, no RPU either.
Looks like infuse cannot handle them properly.
No wonder I got banned for posting this on infuse forum.
That’s strange infuse works both on my end on iPhones iPad & appletv with the trims.
Don’t know if LLDV mode played a part as that is what set too on appletv/vertex2
ragico
#6858 Post by ragico » Sat Jul 16, 2022 3:25 pm
RESET_9999 wrote: Sat Jul 16, 2022 2:55 pm
thanks for testing...
it means the ATV supports the newest CMV4.0 DV.
can you test this TS P5 file and see if the RPU is processed please:
https://drive.google.com/file/d/1ze3VfN ... sp=sharing
This file cannot be played trough Atv native player as it supports only .mp4 files.
Cannot be played in Plex as Plex does not support ts p5
Infuse plays as hdr so ...............
ragico
#6859 Post by ragico » Sat Jul 16, 2022 3:27 pm
quietvoid wrote: Sat Jul 16, 2022 2:59 pm
Thanks for the explanation.
Please can you share your latest kodi build for Firestick?
Many thanks.
sw5163
#6860 Post by sw5163 » Sat Jul 16, 2022 3:34 pm
ragico wrote: Sat Jul 16, 2022 2:26 pm cmv40.mp4 - L2 does not work. L1, L3 and L8 works and rpu works. (DV)
Some official document: https://professionalsupport.dolby.com/s ... uage=en_US
sw5163
#6861 Post by sw5163 » Sat Jul 16, 2022 3:47 pm
ragico wrote: Sat Jul 16, 2022 2:26 pm Also Plex triggers Dolby Vision playing Profile 8 ts movies. Is it fake or real DV?
One possible way to find out is to remux those sample files provide by quietvoid.
quietvoid wrote: Wed Jun 08, 2022 1:51 am You can try the files here: https://mega.nz/file/xNcAVQhJ#ldoifbK6D ... dXkzw2HYgs
Im guessing tsmuxer can mux them to P8 ts, but I don't know how.
quietvoid
#6862 Post by quietvoid » Sat Jul 16, 2022 3:49 pm
ragico wrote: Sat Jul 16, 2022 3:27 pm Please can you share your latest kodi build for Firestick?
Many thanks.
This is the last I built: https://mega.nz/file/NN9GADIL#8aizfPA8M ... k6_PNiTLJc
#6863 Post by Manixx2020beyound » Sat Jul 16, 2022 3:52 pm
sw5163 wrote: Sat Jul 16, 2022 3:34 pm
Got a cmv question?
Let’s say master move was done in cmv2
When that master churns out a p5 I assume it’s now cmv4, I’m I correct in saying most original P5s are cmv4 this is what I’m seeing on my end please correct me if I’m wrong.
#6864 Post by RESET_9999 » Sat Jul 16, 2022 3:57 pm
Manixx2020beyound wrote: Sat Jul 16, 2022 3:52 pm I’m I correct in saying most original P5s are cmv4 this is what I’m seeing on my end please correct me if I’m wrong.
no, most movies are V2.9 (95%+)
Strangely, The Black Phone Movies Anywhere P5 web-dl has two frames on V4.x and the rest on V2.9
Summary:
Frames: 148739
Profile: 8
DM version: 1 + 2 (CM 2.9 and 4.x)
v2.9 count: 148739
v4.x count: 2
Scene/shot count: 1390
quietvoid
#6865 Post by quietvoid » Sat Jul 16, 2022 4:13 pm
RESET_9999 wrote: Sat Jul 16, 2022 3:57 pm Strangely, The Black Phone Movies Anywhere P5 web-dl has two frames on V4.x and the rest on V2.9
Most Movies Anywhere samples I looked at were like that.
sw5163
#6866 Post by sw5163 » Sat Jul 16, 2022 4:14 pm
Manixx2020beyound wrote: Sat Jul 16, 2022 3:52 pm Got a cmv question?
Packing P8->P5 only changes profile. All the RPU data won't be changed. CM version will also not change. If that's what you are asking.
ragico
#6867 Post by ragico » Sat Jul 16, 2022 4:15 pm
quietvoid wrote: Sat Jul 16, 2022 3:49 pm
Many thanks.
Thanks a lot.
sw5163
#6868 Post by sw5163 » Sat Jul 16, 2022 4:19 pm
RESET_9999 wrote: Sat Jul 16, 2022 3:57 pm no, most movies are V2.9 (95%+)
Do you have a file with a lot of cmv40 data?
According to saindriches, cmv4 seems to have a problem on Apple platform. I want to give it a test but I don't know what file is FEL with cmv40.
屏幕截图 2022-07-16 120548.png (32.79 KiB) Viewed 21979 times
#6869 Post by RESET_9999 » Sat Jul 16, 2022 4:22 pm
sw5163 wrote: Sat Jul 16, 2022 4:19 pm Do you have a file with a lot of cmv40 data?
you can check out the movie Hitman's Wife's Bodyguard. And I think you can remove cmv4.x with the dovi_tool
    "cmv40_metadata": {
      "num_ext_blocks": 4,
      "ext_metadata_blocks": [
          "Level3": {
            "min_pq_offset": 2048,
            "max_pq_offset": 2048,
            "avg_pq_offset": 1313
          "Level8": {
            "length": 25,
            "target_display_index": 1,
            "trim_slope": 1886,
            "trim_offset": 2108,
            "trim_power": 2380,
            "trim_chroma_weight": 1638,
            "trim_saturation_gain": 1638,
            "ms_weight": 2048,
            "target_mid_contrast": 1946,
            "clip_trim": 2048,
            "saturation_vector_field0": 128,
            "saturation_vector_field1": 102,
            "saturation_vector_field2": 128,
            "saturation_vector_field3": 128,
            "saturation_vector_field4": 128,
            "saturation_vector_field5": 128,
            "hue_vector_field0": 128,
            "hue_vector_field1": 96,
            "hue_vector_field2": 128,
            "hue_vector_field3": 128,
            "hue_vector_field4": 128,
            "hue_vector_field5": 128
          "Level9": {
            "length": 1,
            "source_primary_index": 0
          "Level254": {
            "dm_mode": 0,
            "dm_version_index": 2
  "rpu_data_crc32": 2447853315
ragico
#6870 Post by ragico » Sat Jul 16, 2022 4:40 pm
sw5163 wrote: Sat Jul 16, 2022 3:47 pm
Those files, provided by @quietvoid are mkv.
So I remuxed them in Ts muxer.
In Plex both mkv and ts remuxed files do not work. No rpu.
So, to answer my question, P8 ts files in Plex are fake DV.
